Post by theodoric on Mar 29, 2013 23:54:53 GMT 1
Fitted the bars, levers, new grips and bar ends I was going great guns. Was being the pivotal word. Decided to bleed the brakes as I have rebuilt calipers and master cylinder. For some strange reason the fluid just would not leave the master cylinder so I stupidly drained as much as I could with rags everywhere as a precaution but guess I left a gap. Fcuking brake fluid all over the new paint job on the rear wheel. Not only can I still not bleed the brakes but 6 hours later I'm still fuming I made such a bloody stupid error. I could have sety fire to the bike if the tank had of been fitted. What a w**ker.
Post by speedysquires on Mar 30, 2013 1:04:09 GMT 1
Stripped the paint off the Allspeeds, fitted some hytech reeds and found out that the YPVS reed block spacers I got off ebay are for a 350LC.....
Post by steve h on Mar 30, 2013 1:46:30 GMT 1
It happens theodoric, Its not worth getting the BP up ;D Just step back and put it down to sod's law!!!
Post by steeley on Mar 30, 2013 6:56:46 GMT 1
just recently i have been useing vht caliper paint.its a satin finish got some heat resistance and is chemical resistant.mind you i am now useing automek brake fluid ,paint safe bloody expensive 36 quid a ltr.
Post by sundaytimes on Mar 30, 2013 15:18:58 GMT 1
Got my 500 out today for the first time in 4 months, adjusted the chain, topped up the 2 stroke, did the tyres, and then out for 20 minute run. Started after about 5 kicks so happy with that.
Post by flames on Mar 30, 2013 18:18:43 GMT 1
Stripped the paint off the Allspeeds, fitted some hytech reeds and found out that the YPVS reed block spacers I got off ebay are for a 350LC..... are they a differant size then? you can fit the pv rubbers onto an lc if you cut the wings off apparently,so i thought the holes would line up?
Post by flames on Mar 30, 2013 18:19:42 GMT 1
drained oil and water ready to pull the motor again.pulled carbs etc.
Post by marsbar350 on Mar 30, 2013 18:28:43 GMT 1
refitted me standard pipes after some fooker pinched me TSas then a 80 mile trip for johnnie bicks fundraiser ;D an hour cleaning the white coat off the bike ended up getting
Post by steeley on Mar 30, 2013 19:26:21 GMT 1
f##k sake thats crap.only hope the dirt bag dosent jet up and buggers the engine .better still wheelies into a cop car.
Post by marsbar350 on Mar 30, 2013 19:49:10 GMT 1
f##k sake thats crap.only hope the dirt bag dosent jet up and buggers the engine .better still wheelies into a cop car. steeley the pinched bits about the pipes was tongue in cheek have leased for a test ;D
Post by flames on Mar 30, 2013 21:36:44 GMT 1
lol,check muttsnuts thread in help and advice steeley.all will be revealed.
Post by Deleted on Mar 31, 2013 2:27:51 GMT 1
Bugger all... Is a warm and sunny day so have been blasting up and down the padock on the Yammy 100 with my little daughter! She stinks of 2 stroke oil now, so my wife will be pleased. lol
Post by Paul Dawkins on Mar 31, 2013 19:05:29 GMT 1
I rebuilt the engine on my Candy blue in November, ran it up to make sure it was OK and have not started it since. I cant bare the thought of running the furker in.
Post by oldelsieboy on Mar 31, 2013 19:50:32 GMT 1
Not a "proper" Giuliari, where's the tag OEB
Post by oldelsieboy on Mar 31, 2013 19:54:31 GMT 1
Rebuilt & bled my 4L0 brake calipers ready for MOT next week ................................................................................................. hopefully OEB
Post by Deleted on Mar 31, 2013 19:56:08 GMT 1
Not a "proper" Giuliari, where's the tag OEB not all gully seats had tags
Post by muttsnuts on Mar 31, 2013 19:57:54 GMT 1
refitted me standard pipes after some fooker pinched me TSas t> your not wrong, you don't think your getting them back now do you !!! I'll need to pinch some ear defenders to go with them though...... ;D
Post by oldelsieboy on Mar 31, 2013 20:06:10 GMT 1
Not a "proper" Giuliari, where's the tag OEB not all gully seats had tags "Proper" ones did OEB
Post by scoobytoo on Mar 31, 2013 20:14:33 GMT 1
Didn't all have tags !
Post by oldelsieboy on Mar 31, 2013 20:20:20 GMT 1
Post by flames on Mar 31, 2013 21:04:44 GMT 1
pulled the motor out,and stripped it down ready for rebuild due to motor getting hungry and eating left hand piston.got 2 groves on crankshaft on l/h/s where seal sits.dont know whether it was drawing air in because of this,or maybe i had the seal fitted the wrong way round.it ran well until the eating thing.will get the timing sorted this time aswell,and measure combustion volume etc before rebuild.
Post by steve h on Mar 31, 2013 21:21:22 GMT 1
More ABS slurry work on sidepanels. And am now spraying handlebars satin (thanks OEB!)
Post by The Pirate on Mar 31, 2013 23:58:05 GMT 1
Post by raven13 on Apr 1, 2013 0:11:14 GMT 1
rode it to work and back, then once home fitted new tax disk.
Post by fatfastroger on Apr 1, 2013 8:34:00 GMT 1
collected the powder coated frame and ordered some of Kenny's pipes
Post by marsbar350 on Apr 1, 2013 9:38:43 GMT 1
refittted centre stand helicoiled tie bar bolt hole in crankcase hope fully sorted an oil leak i have been chasing round the bike for months
Post by flames on Apr 1, 2013 13:21:20 GMT 1
today i arr bin trimming and edging.last time out i had 6mm reed spacers fitted,and noticed an improvement in the 'hole' at 5-6k.wanted to try the valve rubber and balance pipe thing,but didnt want to completely remove the wings,as i guess yammy made them the shape for a reason.so i trimmed my gaskets to fit over the wings on the valve rubbers,fitd 2 gaskets to the rubbers with the 6mm spacer over top,then trimmed the end of the wings flush with the spacer,so now my lc reeds will but up nicely,and only had to remove 1.5mm from the ends of the wings.
Post by speedysquires on Apr 1, 2013 13:40:31 GMT 1
Stripped the paint off the Allspeeds, fitted some hytech reeds and found out that the YPVS reed block spacers I got off ebay are for a 350LC..... are they a differant size then? you can fit the pv rubbers onto an lc if you cut the wings off apparently,so i thought the holes would line up? The internal dimensions are different, YPVS will fit the LC but not the other way round
Post by flames on Apr 1, 2013 13:47:21 GMT 1
ok.i bought some off e bay for the lc and have been having a play as you can see from above.they dont fit around the o ring part of pv rubbers,but nor do they the lc ones,but they fit over the wings,so i figured on using a gasket and seeing how we go.mine were advertised as lc spacers,but i spose they could have been made for pv,s.
Post by kentracer on Apr 1, 2013 14:40:06 GMT 1
Just de-snorkeled my airbox...and tried... Approuved ! Even if I was near to fall down on the mud lost by a farmer ... Would have been if my tsa pipes were damaged
