Post by tipfinchy on May 22, 2021 13:21:35 GMT 1
Put newly cerakoted pipes back on and fitted silencers , having a cuppa before the swearing and finger skinning starts fitting the belly pan back on 🙄 Mart
cnkxu1
Post by cnkxu1 on May 22, 2021 23:36:47 GMT 1
Vapour blasted the paint off the brake calipers Did not notice much grit while I was rinsing off after blasting the first caliper and then saw my glass beads needed replenishing. Added some fresh stuff and the second was done in half the time.
Now some masking and paint.
Post by midlifecrisisrd on May 29, 2021 12:39:23 GMT 1
Apparently after a few beers with a mate last night I agreed to buy back my RZ250 3hm1 🤣
Post by deano4lo on May 29, 2021 17:33:51 GMT 1
Picked up wheels from cj ward yesterday, top work for decent money, new bearings fitted today, now waiting on tyres....
Post by petehodges on May 30, 2021 21:44:53 GMT 1
Dug mine out the cave today had a little clean & polish Next up mot 🤞
fubars
Post by fubars on May 31, 2021 11:28:33 GMT 1
Not a lot 🤔
Post by rbridd on May 31, 2021 14:49:57 GMT 1
I have been clipping old wires out, and crimping new wires into the wiring loom which will go on the project bike. some of the wires from the old loom were black, (instead of nice bright copper), when the insulation was stripped back, so I re-learned a bit of chemistry, and gave them a bath...
Post by 29davyt on May 31, 2021 17:02:18 GMT 1
Post by tacky1 on May 31, 2021 20:15:47 GMT 1
Spent all day yesterday working on the 450, 10 years of abuse was taking its toll, Back wheel was cracked and front bent, so new wheels, tyres, HD tubes, brake pads, chain, oil filter and new air filter, plug, cam clearances checked, Took off all the plastics, removed the old sticker kit and cleaned them up, heat gunned the scratches out, new front muddy, new stickers and I believe its good to go
Post by JonW on Jun 3, 2021 2:34:08 GMT 1
I have been clipping old wires out, and crimping new wires into the wiring loom which will go on the project bike. some of the wires from the old loom were black, (instead of nice bright copper), when the insulation was stripped back, so I re-learned a bit of chemistry, and gave them a bath... Good work! Whats in the bath? some kind of acid? Do be careful whatever youve used doesnt travel up inside the sheething. One bit of advice. Where you can, try and stagger the cuts when repairing looms so that you dont end up with a thick lump when its re-taped.
Post by JonW on Jun 3, 2021 2:36:22 GMT 1
I do love this time of year when you lot in the Northern Hemisphere pull your bikes out and prep them for another season of riding. Always nice to see them sparkle in the sun!
Post by rbridd on Jun 4, 2021 16:31:28 GMT 1
I have been clipping old wires out, and crimping new wires into the wiring loom which will go on the project bike. some of the wires from the old loom were black, (instead of nice bright copper), when the insulation was stripped back, so I re-learned a bit of chemistry, and gave them a bath... Good work! Whats in the bath? some kind of acid? Do be careful whatever youve used doesnt travel up inside the sheething. One bit of advice. Where you can, try and stagger the cuts when repairing looms so that you dont end up with a thick lump when its re-taped. Acid (vinegar and table salt solution) in the first... Alkali (Baking powder solution) in the second. Once its finished fizzing in the alkali, dry off, and spray with brake cleaner before crimping.
Post by rbridd on Jun 4, 2021 16:34:53 GMT 1
Today I have been repairing a temperature sender. While waiting for various parts to arrive in the post, I thought to overcome a small problem that I’m sure all LC owners have to deal with from time to time. The spade connector atop the temperature sender is apt to snap off. This one from the donor bike has. In the past I have soldered a wire to the top of the sender and connected to the loom that way, but it has always been a bit fragile. This time I was determined to find a better solution. Using a spade connector from the electrical repairs box… Clean up the little knob on the top of the sender with a dremmel. Scrub the whole top of the sender clean with brake cleaner and a toothbrush. Cut down the new spade connector and drill a 3mm hole in it. Tin the top of the sender using copious amounts of flux. Tin the spade connector using copious amounts of flux. Place the hole over the knob, and heat until the solder flows. job done I’ll put a blob of epoxy adhesive on top later, and paint it green.
Post by donkeychomp on Jun 4, 2021 21:14:31 GMT 1
Great fix!
Post by geoffb on Jun 5, 2021 15:23:28 GMT 1
Fitted a set of silver Renthal 758 bars.
Post by hudtm60 on Jun 7, 2021 1:39:19 GMT 1
Bikes always on battery tender, yet was dead as a door nail today. It’s an old school acid version from Jan 2020. Took it out…. And it was dry… And I mean…this dry… I blame this new fangled battery tender…. Genius my arse….Pretty lights though.
fubars
Post by fubars on Jun 7, 2021 17:05:28 GMT 1
Bikes always on battery tender, yet was dead as a door nail today. It’s an old school acid version from Jan 2020. Took it out…. And it was dry… And I mean…this dry… I blame this new fangled battery tender…. Genius my arse….Pretty lights though. Bet it looks nice in the dark 😎
Post by copper99 on Jun 7, 2021 17:12:04 GMT 1
Out for the first spin of the year on the YSR today, carb needs some tweaks for the spannie but its huge fun. ysr lane 4 by Bryan Griffin, on Flickr
Post by dougw on Jun 8, 2021 23:09:26 GMT 1
Clocked up 500 running in miles on the rebuilt 4L0 and ran it to around 8 through the gears on local bypass, runs well. Gradually introducing the engine to higher revs now.
mt
Member is Online
Post by mt on Jun 9, 2021 10:51:15 GMT 1
Post by mick858 on Jun 9, 2021 11:11:29 GMT 1
Just been out for a smoke. Early morning, mid week and there are still a few bikes in Squires!
Post by 29davyt on Jun 9, 2021 12:25:02 GMT 1
haj
Post by haj on Jun 9, 2021 13:13:53 GMT 1
I'm not as such using mine as I'm so silly busy at the moment. However I did get the engine back together with a new idle gear bush, and it seems to have worked. I also had a slipping clutch problem when the engine isn't quite warm enough. I checked the clutch plates and they are within spec. I suspected the 10/40w oil was to blame so I've switched to silkolene light gear oil - but it still seems to slip after a 6km test ride so I don't know. Perhaps the springs are too soft. I'm not that anal about it being totally tip-top. I'm just using it for some fun rides once in a while so as long as it's working when it's warmed up properly I'll be happy Going for a 150km ride friday
Post by JonW on Jun 9, 2021 13:39:21 GMT 1
I'm not as such using mine as I'm so silly busy at the moment. However I did get the engine back together with a new idle gear bush, and it seems to have worked. I also had a slipping clutch problem when the engine isn't quite warm enough. I checked the clutch plates and they are within spec. I suspected the 10/40w oil was to blame so I've switched to silkolene light gear oil - but it still seems to slip after a 6km test ride so I don't know. Perhaps the springs are too soft. I'm not that anal about it being totally tip-top. I'm just using it for some fun rides once in a while so as long as it's working when it's warmed up properly I'll be happy Going for a 150km ride friday if youve not changed the springs, then they are often the culprit as they get slack quickly, cheap enough to swap with OEMs.
Post by Tobyjugs on Jun 9, 2021 18:05:00 GMT 1
I'm Not using my bike much as it seems to be attracting the attention of the police a bit too much lately. In the last 2 weeks or so i have been stopped 3 times. Speeding (ouch), no indicators and the last time was no mirrors. The lack of mirrors and the indicators are not ilegal due to the age of the bike. I think because it's a 250 you have to rev it a bit harder and thats whats attracting them.
Post by 29davyt on Jun 9, 2021 18:38:50 GMT 1
I like to Rev mine harder coz it’s got Allspeeds on , can’t beat a bit of environmental noise abuse 😂
ajh
Post by ajh on Jun 9, 2021 19:18:20 GMT 1
I'm not as such using mine as I'm so silly busy at the moment. However I did get the engine back together with a new idle gear bush, and it seems to have worked. I also had a slipping clutch problem when the engine isn't quite warm enough. I checked the clutch plates and they are within spec. I suspected the 10/40w oil was to blame so I've switched to silkolene light gear oil - but it still seems to slip after a 6km test ride so I don't know. Perhaps the springs are too soft. I'm not that anal about it being totally tip-top. I'm just using it for some fun rides once in a while so as long as it's working when it's warmed up properly I'll be happy Going for a 150km ride friday Id of thought gear oil would make it worse if it slipped less with warmer oil. Also make sure your oil is the wet clutch spec - think its MA2
mt
Member is Online
Post by mt on Jun 10, 2021 12:28:29 GMT 1
Post by blaine on Jun 10, 2021 17:37:39 GMT 1
Trial fitted different wheels. Not keen on them. 🤔 So started stripping the paint off the other wheels, keeps me warm!
jam911
Post by jam911 on Jun 11, 2021 20:06:03 GMT 1
Petrol and 2 Stroke oil for tomorrows thrashing...
