Post by andy748 on Feb 6, 2021 22:34:06 GMT 1
Post by JonW on Feb 6, 2021 22:35:33 GMT 1
Looking good Chris! The airfilter makes you wonder what else you will find that needs doing, tho to be fair I think youve got it covered with this work. It'll ride much better with this stuff done. Loving the small platform lift, I must be one of those.
Post by trappena on Feb 7, 2021 18:57:36 GMT 1
Thanks Arrow! Was just thinking about you as I was adjusting the oil pump. If your tackling the oil supply you might want to invest in inline oil check valves (if not fitted already). My two cents. Cheers.
Post by geoffb on Feb 7, 2021 19:18:43 GMT 1
Post by fletche36 on Feb 14, 2021 16:00:52 GMT 1
Fitted a pair of reed block spacers today to try and dial out the final bit of the flat spot, nothing too radical at 5mm thick, which is just thick enough to make the carbs a swine to refit i dont know how people go on with 8 or 10 mm spacers ! Anyway i cant test it today as its just started raining , so thats tomorrows job.
Post by fletche36 on Feb 16, 2021 17:30:04 GMT 1
So today i tested it and its no better so i fitted the standard pipes again and lo and behold , it rides how i wanted it too. at least i know everything else is fine
Post by fletche36 on Feb 16, 2021 17:30:14 GMT 1
Post by 3tj6 on Feb 16, 2021 18:36:35 GMT 1
Painted tank side panels tail piece and front mudguard , tank ok , all plastics have 1 or 2 big pop marks in them 🤬put some lacquer into the pops before baking, still popped, so will be painting them again 🤯
Post by andy748 on Feb 17, 2021 10:25:25 GMT 1
Post by itsnick350 on Feb 17, 2021 20:04:00 GMT 1
Finally fabricated some brackets out of tent pegs to hold my 31k belly pan secure and away from the allspeed pipes. Shame I have not mastered uploading pictures but think about a “s” shape with both ends curled so that they are held in place by bolts and nuts. The key was finding a material both strong enough but could also be bent easily. Wicks, £3 for a bunch of pegs, recommended
Post by JonW on Feb 17, 2021 23:56:43 GMT 1
Shame I have not mastered uploading pictures... I put up a pic of how to use imagur before, just do that. not hard.
Post by itsnick350 on Feb 18, 2021 0:40:29 GMT 1
Thanks, I’ll try and find it and see if a numpty like me can get some pictures to share
Post by JonW on Feb 18, 2021 0:48:11 GMT 1
Thanks, I’ll try and find it and see if a numpty like me can get some pictures to share I just used search on the word imgur to find the pic i put up. go to imgur.com, drag in the pic. then click the copy button i show with the arrow, then paste into your post on the forum. It doesnt get easier n that.
Post by markrd250lc on Feb 20, 2021 18:43:16 GMT 1
Fitted bigger main jets, new rear sprocket (shinny to replace the black one) and new rear shoes, plus cleaning and greasing as i go, hoping for a cheeky ride tomorrow if it stays dry
Post by andy748 on Feb 20, 2021 21:43:42 GMT 1
Post by 3tj6 on Feb 20, 2021 22:23:45 GMT 1
What you building Andy? 392 ?
Post by mouse on Feb 20, 2021 22:47:44 GMT 1
Fitted more titanium bolts!
Mouse
Post by andy748 on Feb 20, 2021 23:00:03 GMT 1
What you building Andy? 392 ? No Mate, standard 64mm barrels with 115mm long rod crank and Wiseco ultra stroker pistons, so 370ish cc, we'll see how it goes? Andy.
Post by Tobyjugs on Feb 21, 2021 9:57:52 GMT 1
I had a restless night with clutch plates marching around in my head after testing my 8 plate clutch yesterday. I ended up putting the six gorilla grip springs into the clutch.
Time to start measuring everything again.
Post by Tobyjugs on Feb 21, 2021 21:16:48 GMT 1
Went out for a short spin on the 250 powered LC. Got nicked for speeding. The police clocked me at 154 kmh in a 100 zone. With correction it came just under the 150 limit. Above this is an automatic ban. Phew!
Post by JonW on Feb 21, 2021 22:57:46 GMT 1
Went out for a short spin on the 250 powered LC. Got nicked for speeding. The police clocked me at 154 kmh in a 100 zone. With correction it came just under the 150 limit. Above this is an automatic ban. Phew! Ooops!
Post by tipfinchy on Feb 21, 2021 23:53:50 GMT 1
Went out for a short spin on the 250 powered LC. Got nicked for speeding. The police clocked me at 154 kmh in a 100 zone. With correction it came just under the 150 limit. Above this is an automatic ban. Phew! nice one , i take it its running fairly good then mart
Post by steven on Feb 22, 2021 1:39:28 GMT 1
Went out for a short spin on the 250 powered LC. Got nicked for speeding. The police clocked me at 154 kmh in a 100 zone. With correction it came just under the 150 limit. Above this is an automatic ban. Phew! Fu**in Hooligan !
Post by Tobyjugs on Feb 22, 2021 9:47:39 GMT 1
Went out for a short spin on the 250 powered LC. Got nicked for speeding. The police clocked me at 154 kmh in a 100 zone. With correction it came just under the 150 limit. Above this is an automatic ban. Phew! nice one , i take it its running fairly good then mart Almost as it doesn't quite pull through in top. I was just thinking I need to go one tooth up on the back sprocket when the police car came flying past me and pulled into my lane almost driving into the car in front of me.
Post by tipfinchy on Feb 22, 2021 14:46:05 GMT 1
Finally got round to fitting new stator cover with trans support Mart
Post by oldbritguy on Feb 23, 2021 8:34:18 GMT 1
Well yesterday actually Took advantage of my mates lathe again and machined a new anchor pin for my rear brake torque arm. Turned and threaded a 12mm stainless clevis pin to fit the metmachex arm mount, which is slightly thicker than std
Post by Chewie01 on Feb 23, 2021 23:08:53 GMT 1
I removed the engine from my F2 today. The can of worms is about to be opened.
Post by hudtm60 on Feb 24, 2021 2:27:30 GMT 1
this time last week...the city was blanketed with snow and ice....now it's gone...and warm enough for an evening shopping run
Post by JonW on Feb 24, 2021 6:32:55 GMT 1
this time last week...the city was blanketed with snow and ice....now it's gone...and warm enough for an evening shopping run Looking good Chris, running better and not marking its territory now? Fantastic pic too!
