Post by gazzatt2 on Feb 16, 2019 21:55:59 GMT 1
MOT passed
Post by alankelly on Feb 16, 2019 22:18:18 GMT 1
Checked wheel alignment in the xmas project
Bu99er it looked like it needs correcting😁😁
Post by 1966baz on Feb 17, 2019 9:13:53 GMT 1
Cleaned carbs , checked tyre pressures and rode the black and grey F2 for its 1st proper spin from a bare crankcase and frame build. The TSA's sound great !
Post by tipfinchy on Feb 17, 2019 13:52:02 GMT 1
Post by Tobyjugs on Feb 17, 2019 15:39:21 GMT 1
Just refitted my cylinder head as it was weeping.
Post by panzermatt on Feb 17, 2019 16:16:09 GMT 1
Just refitted my cylinder head as it was weeping. is that a length of garden hose i see?
Post by oldbritguy on Feb 17, 2019 16:33:24 GMT 1
Just refitted my cylinder head as it was weeping. Nice looking working machine there Toby Intrigued at the reed block/carb adaptor set up. looks purposeful. J
Post by stusco on Feb 17, 2019 16:50:13 GMT 1
Refurbished the clocks on my rg
Post by Mr Kipling on Feb 17, 2019 17:23:49 GMT 1
Pulled the hybrid out into the sun too get some pics.....
Post by Tobyjugs on Feb 17, 2019 17:25:09 GMT 1
Just refitted my cylinder head as it was weeping. Nice looking working machine there Toby Intrigued at the reed block/carb adaptor set up. looks purposeful. J The reeds are kept close to the barrels for top end and the green balance pipe was specially developed by GGRC it looks a bit amateurish but it works well. I don't think GGRC are that well known
Post by 1966baz on Feb 17, 2019 17:49:18 GMT 1
What rear brake caliper and carrier are you using mate and torque arm.I'd love to see a close up shot as I'm doing a similar set upon my Marsbar with JMC arm and belgarda wheel. Nice bike there mate.
Post by tipfinchy on Feb 17, 2019 18:27:33 GMT 1
What rear brake caliper and carrier are you using mate and torque arm.I'd love to see a close up shot as I'm doing a similar set upon my Marsbar with JMC arm and belgarda wheel. Nice bike there mate. hello mate , the caliper is Brembo and the carrier/hanger is Tyga , and both from jap4performance , no torque arm as vj22 fitment if you clickon the pic you canthen zoom in a bit found this , mart 20181127_173015 by martin finch, on Flickr
Post by 1966baz on Feb 17, 2019 18:57:48 GMT 1
Thanks Mart, that's very helpful.
Post by Tobyjugs on Feb 17, 2019 19:41:24 GMT 1
Just refitted my cylinder head as it was weeping. is that a length of garden hose i see? Hi Panzermatt i missed your post it's a special balance pipe from GGRC.
Post by panzermatt on Feb 17, 2019 21:00:26 GMT 1
ggrc??
Post by doohanno1 on Feb 17, 2019 21:12:08 GMT 1
Great Gardeners Recreational Club.
Post by wangwang on Feb 17, 2019 22:16:31 GMT 1
I quite like that, might be able to do something with it.
Post by Tobyjugs on Feb 17, 2019 22:20:45 GMT 1
Great Gardeners Recreational Club. Ha Ha not far off. Garden Gnomes Racing Corporation. They also use fishing line for chassis alignment purposes
Post by hudtm60 on Feb 18, 2019 17:29:00 GMT 1
Busy weekend. Started building a leakdown kit. Hopinh a water pressure gauge will work.
Post by hudtm60 on Feb 18, 2019 17:34:53 GMT 1
Post by hudtm60 on Feb 18, 2019 17:45:58 GMT 1
and got the clutch in...this is actually the first attempt...imagine my surprise while basking in my success of actually getting the order right (rubber-friction-steel, rubber-friction-steel and ending with the correct (friction) plate, I later read that I'd done the locking washer all wrong. So far I think I've done about everything twice. And by the way: the copper pipe rules....don't use rags to lock the engine...them gears are sharp and shred the toughest cloth into tiny pieces which may later find themselves in the wrong places.
Post by JonW on Feb 18, 2019 22:40:26 GMT 1
Chris, if you fancy a third go, no one uses the rubber rings now... I'll get me coat
Post by midlifecrisisrd on Feb 22, 2019 23:10:02 GMT 1
Wasted an hour of my life swapping the guts out a ypvs servo
The one I fitted had a good case but whined even when not moving
Another 2 were the same
Found a silent one but case was broken
Thankfully done now, fiddly little buggers
Post by wassy06 on Feb 22, 2019 23:30:53 GMT 1
Thought I’d take the N1 for a spin but petrol pissing out of left carb so spent the afternoon removing the seized needle valve ( thanks for the advice Dave ).
Post by rigga on Feb 23, 2019 0:01:43 GMT 1
I quite like that, might be able to do something with it. I quite like mine, but then I like red bits
Post by Tobyjugs on Feb 23, 2019 17:11:46 GMT 1
I put the bike on the dyno today with the thought, check the effect of using the correctly adjusted cylinder head and maybe one jet up or down.
AAAAAARRGH back to square one, more head scratching.
I hate jetting
Post by alankelly on Feb 23, 2019 17:18:44 GMT 1
Did nothing as took my lad fishing
Post by stusco on Feb 23, 2019 17:31:08 GMT 1
Checked it can still wheelie in third
Post by doohanno1 on Feb 23, 2019 17:50:48 GMT 1
Checked it can still wheelie in third Pics or it didn't happen..🤔
Post by peddrotzr on Feb 23, 2019 18:18:20 GMT 1
It's not an RD, but it is an LC. Finally got round to doing a bit on the old girl, cleaned up & fitted the forks and continued with the build. First time on her wheels since May 1980.
