Post by icklepob on Aug 6, 2018 10:02:30 GMT 1
Welded and painted my cracked standard pipes, ready to go to the classic TT
Post by dazzle on Aug 9, 2018 21:20:00 GMT 1
Started on the paint stage of my tank underside rubbed down, haven’t got a sandblasted so wire wheel and hand sanding leaves very small oxidization in indents in steel, so hydrate 80 rust cure to convert any remaining rust. ![](https://i.lensdump.com/i/855Y92.md.jpg) 2 costs cured ![](https://i.lensdump.com/i/855MW9.md.jpg) Next epoxy liner
Post by donkeychomp on Aug 9, 2018 21:50:39 GMT 1
That rust killer looks better than the stuff I use. Going to get some!
Post by dazzle on Aug 9, 2018 22:25:01 GMT 1
Bilt hamber hydrate 80, I've used it on jeep,sills and winch bumpers bought a bumper for my Cherokee the add said needs a little work, anyway 3mm steel but looked like it came from the Mary rose when it arrived, treated with flap wheel so pitted, treated inside and out with this stuff, didn't get bumper painted for a year due to too many other jobs, not a bit of rust broke through. Can be sanded and primed and top coated too.
Post by andy748 on Aug 10, 2018 9:34:50 GMT 1
Cheers Dazzle, gonna try that on my merc wings. Andy.
Post by peter007 on Aug 10, 2018 18:57:03 GMT 1
Started on the paint stage of my tank underside rubbed down, haven’t got a sandblasted so wire wheel and hand sanding leaves very small oxidization in indents in steel, so hydrate 80 rust cure to convert any remaining rust. ![](https://i.lensdump.com/i/855Y92.md.jpg) c 2 costs cured ![](https://i.lensdump.com/i/855MW9.md.jpg) Next epoxy liner
Post by peter007 on Aug 10, 2018 18:57:55 GMT 1
could this hydrate 80 be used on the inside of a tank ?
Post by dazzle on Aug 10, 2018 20:37:59 GMT 1
No it’s waterbased definetly not petrol proof. I’m using Caswell epoxy liner I have silver soldered a couple of larger rust holes but the heat causes heat distortion which need repairing, still a small pin hole I missed
Post by beardy on Aug 16, 2018 7:18:02 GMT 1
fed up looking at my petrol stained carbs. so new float valves and gaskets and japanese oem fuel tap from norbo. float heights adjusted, actually with new float valves they were fine.the old float valve springy bit just closed up when the carbs were inverted and the weight of the float was on it. brass balls removed and a damm good cleaning of carbs. ooh what a difference. it now wont start without choke, ticks over when cold and doesnt smell of fuel.
f2kev
![*](//storage.proboards.com/forum/images/stars/star_black.png)
Post by f2kev on Aug 16, 2018 18:01:17 GMT 1
loaded it up in the van ready for two weeks at the classic tt
Post by hudtm60 on Aug 16, 2018 19:33:52 GMT 1
Two weeks holidays- what's that like? Got bits back from the blasters- now have to educate myself how to do these sliders 'factory style'....something about ScotchBrite... ![](https://photos.smugmug.com/photos/i-TmBbzL7/0/dba84fe7/L/i-TmBbzL7-L.jpg) ![](https://photos.smugmug.com/photos/i-QwGzDbV/0/49c7b9c0/L/i-QwGzDbV-L.jpg)
Post by paulincayman on Aug 20, 2018 1:48:20 GMT 1
Just bought a 31k tranny set on the bay..fingers crossed.
Post by beardy on Aug 21, 2018 7:42:21 GMT 1
yesterday i fitted a yss shock to my 4lo that i bought of dave (muttsnuts). i hope to get out on it today and see the differences between this and a 37 year old standard shock.
Post by hudtm60 on Aug 21, 2018 17:00:49 GMT 1
Post by copper99 on Aug 21, 2018 21:41:54 GMT 1
Not sure about the music but thats a nice wee set up and collection you have there mate.. ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Post by hudtm60 on Aug 22, 2018 4:41:04 GMT 1
thanks copper..a little compact and bijou..and a bit embarrassing really now I look at it- that was just the radio....not sure why I put it up other than I think everyone can identify with the the fact that it was the weekend and sometimes there's just no better time than to be in your own place....alone with the bikes...
Post by ftm73 on Aug 22, 2018 12:46:01 GMT 1
Dropped of my leaking tank at Cupar Bike Paints to get the rubbish Kreem liner removed, relined and painted again. flic.kr/p/2akpopV
Post by andy748 on Aug 26, 2018 9:26:47 GMT 1
Post by Tobyjugs on Aug 26, 2018 9:41:29 GMT 1
I like the YPVS its been modded but looks standard like it came from yamaha
Post by Tobyjugs on Sept 2, 2018 21:10:11 GMT 1
Went for a Sunday ride? ![](https://farm2.staticflickr.com/1842/42622900890_ca31b6be76_h.jpg)
![](https://farm2.staticflickr.com/1844/44383671662_818e5e9d5a_b.jpg)
Post by mikee on Sept 2, 2018 21:17:48 GMT 1
Sorted the yammagamma gearshift
Mike
Post by copper99 on Sept 2, 2018 22:19:35 GMT 1
![](https://farm2.staticflickr.com/1844/44383671662_818e5e9d5a_b.jpg) Fantastic!
Post by hudtm60 on Sept 3, 2018 4:09:31 GMT 1
Went for the factory look on the sliders- not 100% convinced.......but when you stand back a bit....heh.....not three bad. it's hard to tell from the pics but... above: vapor blasted- (yes I know- maybe could've/should've just left them like that) below: attacked by a red scotchbrite wheel and then calmed down with a light rubbing of 000 rated steel wool and then....a cloth. will probably go over it once more to get a more uniform brush look and then at some point spray it with 2k matt clear. or not. jury's out on that part. ![](https://www.chrishudsonphotography.net/Motorcycles/1982-RD350LC/n-g3wnnB/i-LMHwDjP/A) ![](https://photos.smugmug.com/photos/i-LMHwDjP/1/0b9ffd19/XL/i-LMHwDjP-XL.jpg)
Post by Deleted on Sept 4, 2018 11:48:59 GMT 1
Finally... nearly 6 years after I bought a basket case LC, it's finished and booked in for a road worthy next week! It runs a bloody treat, and everything is done bar the paint job as I'm buggered if I can decide what colour, so it's flat white for now. Happy days ahead!
Post by andrel on Sept 4, 2018 20:02:55 GMT 1
Finished spray painting my frame - etch primer, 2k white coat followed by 3 coats of 2K red.
Stood back admiring my handiwork when it slowly dawned on me that i will have to strip everything down to the bare metal and start from scratch again.
You see, in my zen-like state behind the spraygun - i managed to continously mix 2 parts paint, 1 part thinners and 10% hardener.
At least i managed to get a nice flow going without orange peel.
Post by Deleted on Sept 5, 2018 11:36:02 GMT 1
Finally... nearly 6 years after I bought a basket case LC, it's finished and booked in for a road worthy next week! It runs a bloody treat, and everything is done bar the paint job as I'm buggered if I can decide what colour, so it's flat white for now. Happy days ahead! Good one Duncan. Lets see a few piccies when ya done old chap.
Post by steven on Sept 8, 2018 18:57:08 GMT 1
Drove it ! ![:o](//storage.proboards.com/forum/images/smiley/shocked.png)
Post by beardy on Sept 9, 2018 17:14:28 GMT 1
Just got back from a weekend rally held by the Solent MC. Was the only LC there until Saturday afternoon when a couple on a 2 @ 350 turned up. Racked up about 220 miles
Post by hudtm60 on Sept 10, 2018 17:17:57 GMT 1
Fixed the flat spot. Went back in time. ![](https://photos.smugmug.com/photos/i-LNHjSVJ/0/4f24da1f/XL/i-LNHjSVJ-XL.jpg)
Post by Tobyjugs on Sept 10, 2018 18:36:18 GMT 1
This week end i went for a ride on the speedway track in Lelystad. It looks fast but in reality i am captain slow. ![???](//storage.proboards.com/forum/images/smiley/huh.png) Clipons and limited steering help to keep things interesting. There was also a nice bonfire Saturday night. ![](https://farm2.staticflickr.com/1845/29661121907_417582fe09_h.jpg) ![](https://farm2.staticflickr.com/1893/44548734632_a73a774b5b_b.jpg)
![](https://farm2.staticflickr.com/1856/44600311751_8b95f85c6e_b.jpg) Kees and me waiting to go out on the track Weather permitting next bit of fun will be on the circuit in Zolder. Then its time to do some maintenance on the engine.
