Post by seanrd on Sept 23, 2012 18:20:31 GMT 1
jonniebick
Nice Bike...How fast duz it goo mister????
Post by jonniebick on Sept 23, 2012 18:49:35 GMT 1
Post by bare on Sept 26, 2012 18:37:24 GMT 1
That Plastic Valvie case cover will need trimming to fit the LC frame. Suggest using the Ali LC one.. it's prettier as well :-0 IMO I'd Fit the LC type shock. Adding a shock hoop to the Ali swinger to do so. The Motocross shocker arrangement offers No advantage in real life beyond perceived looks. Following on the looks thought: the Old Skool TZ look is far more elegant imo.
Post by hardhatharry on Sept 29, 2012 21:01:39 GMT 1
Well swingarm is in the frame lowerbar repaired and bottom shock mounting in with strengthing gussets
Post by hardhatharry on Sept 30, 2012 22:00:58 GMT 1
Bugger, schoolboy error was cracking on and didnt realise the head races where different thickness put the thicker one in top. Can only see welding something to it will get it out?
Post by billy on Oct 2, 2012 1:42:23 GMT 1
Can't you just tap it out from the bottom, using a long steel rod or something?
Post by hardhatharry on Oct 2, 2012 12:03:02 GMT 1
Sorted it last night, there isnt much of a lip to get purchase on but after some swearing its out and in the right place
Post by hardhatharry on Oct 2, 2012 12:03:35 GMT 1
need to take a picture of the top shock mount and post that
Post by hardhatharry on Oct 2, 2012 14:09:26 GMT 1
Well here is a picture of the top shock mount, just need to find a SRAD nut on eBay to finish it off.
Post by copper99 on Oct 2, 2012 21:58:04 GMT 1
Nice work mate...
Post by hardhatharry on Oct 6, 2012 21:57:06 GMT 1
Hopefully tomorrow I shall be lathing some delrin bearings for the swingarm and as I cant get hold of 16 x 42 x 12 bearings for a sensible price (£18+ each) I will be fitting 22 x 42 x 12 and machining captive spacers so I can fit NC29 wheels with GSXR forks and sprindle
Post by kennyroberts on Oct 6, 2012 22:40:23 GMT 1
Sweet work. .....ill be sure to post that cable.!!
Post by hardhatharry on Nov 6, 2012 17:47:36 GMT 1
Post by hardhatharry on Nov 6, 2012 18:14:44 GMT 1
While I am waiting the next care package from Norbo I will space out the wheels so everything is in line. Also these arrived the other day too
Post by jessy03 on Nov 6, 2012 19:15:24 GMT 1
Nice job, I've seen those pipes before are they off - I think johny 485s hybrid Jess
Post by hardhatharry on Nov 6, 2012 19:23:58 GMT 1
Got them from John Hay
Post by hardhatharry on Nov 8, 2012 22:37:25 GMT 1
Well Norbos care package arrived today mostly grommets to keep the side panels in place, fitting kit for the radiator, fitting kit for tail grab and carb rubbers. Anyway tank on, tail rail, rad and carbs in. Some measuring and I now have a plan for the front wheel spacers Unfortunately my boring tool and cutting tools are worn and I cant be bothered sharpening them (carbide tipped) so I've ordered indexable ones from Evilbay hopefully they will be here tomorrow so I can start the spacers
Post by hardhatharry on Nov 10, 2012 21:49:21 GMT 1
Managed to get a couple of hours on the lathe today so got one captive front wheelcspacer done.
artie
Post by artie on Nov 10, 2012 22:42:10 GMT 1
Just caught up with this thread,superb job,the things you guys can do makes my head spin
Post by flames on Nov 11, 2012 22:40:19 GMT 1
loving your build dude.
Post by hardhatharry on Nov 14, 2012 22:41:59 GMT 1
Well finished the spacers so the front wheel is back in and central but now I understand why Nigel at NK said I will need to machine the brake calipers to fit Rear left hand spacer in too so I can line up the rear and front sprocket and see if some tweeks are needed. Need to source a rear caliper and bracket (back to evilbay for a GSXR one) before I can space the right side out. The mighty lathe has been busy I was going to go to the gym but ended up hacksawing that 52mm aluminium bar in the vice to source the metal for the rear spacer, knackered after doing that.
Post by Norbo on Nov 15, 2012 9:22:06 GMT 1
Looks like you have started early on the tincel decorations on that lathe
Post by hardhatharry on Nov 18, 2012 21:28:55 GMT 1
Ok lining up the front and rear wheel today and I am 90% sure the frame is twisted at the headstock. First I was using florescent tubes as straight edges against the rim of the rear wheel (without tyre) and measuring the gap between the front wheel and the tube but the tube always hit the front wheel rim, hmmmm. So I got a laser pointer and when I hold it against the rear wheel with sprocket carrier without any spaces pushed as far to the left it can go on the spindle, the laser pen dot hits the edge of the front tyre on the left hand side.
Post by hardhatharry on Nov 20, 2012 14:32:39 GMT 1
Yep front is definetly p*ssed speaking to a frame guy this week about straightening on a motoliner jig
Post by hardhatharry on Nov 24, 2012 16:32:43 GMT 1
momentous day the LC is off the stands and on its own wheel. Off to the frame benders on Monday The pipes wouldn't fit so they have been sold on
Post by hardhatharry on Jan 3, 2013 22:47:01 GMT 1
Not been on for a while so here is the update: - The frame straightening bloke did me a deal on a new frame with V5 so swapped everything onto the new frame. Missus got me a welding helmet with flames for Xmas Also stumbled on a boxing day bargain 130 amp welder not as good as my 170 amp welder next to it but I'll get it working good and flog it on So it was rude not to use the new helmet to make a bracket for the powervalve motor and snot it onto the frame. Also made a template in cardboard and then in ply for the rear brake bracket. Off to my mate who has a milling machine to make in ally.
Post by hardhatharry on Jan 15, 2013 13:32:24 GMT 1
OK more build updates Sprocket carrier needed machining down, here is a before and after pic Next the sprocket nuts needed cleaning and zinc plating Before After Nice one off sprocket machined by Renthal and the chain fettled and we have a rather sexy backend and to finish things off I installed garage entertainment system V2.0
Post by billy on Jan 15, 2013 19:08:04 GMT 1
Nice work mate.
Post by leaky on Jan 15, 2013 19:55:21 GMT 1
Great build thread, full marks to ya .
Post by Yogi on Jan 15, 2013 20:04:47 GMT 1
Keep up the good work mate
