Post by marsbar350 on Feb 5, 2013 15:56:30 GMT 1
your mate must have deep pockets bry! nearly done
Post by bryan on Feb 5, 2013 16:58:22 GMT 1
its costing so much to restore to origonal now, think is going to be a trailer Queen going to shows! Got in contact with Simon5 finnaly today about sorting the lock set on to 1 key. Have a new ignition switch, got an origonal off set petrol cap and a new pair of seat locks that i sold to a forum member in 2008 but he didnt use on his rebuild, the lock is NLA. Fitted with origonal replated in yellow passivate screews.
Post by tout on Feb 5, 2013 19:12:05 GMT 1
Hope the rear sprocket has a penguin on it looking good
Post by spenerone350 on Feb 5, 2013 20:37:58 GMT 1
HI ,YOUR PROJECT IS LOOKING SPOT ON ,CANT WAIT TO GET MINE ON THE WAY ,JUST WONDERED HAS THE FRAME BEEN POWDER COATED IF SO WHO DID YOU USE .THANKS CHRIS
Post by bryan on Feb 5, 2013 20:38:18 GMT 1
youve lost me ther Tout!
Post by bryan on Feb 5, 2013 20:42:56 GMT 1
HI ,YOUR PROJECT IS LOOKING SPOT ON ,CANT WAIT TO GET MINE ON THE WAY ,JUST WONDERED HAS THE FRAME BEEN POWDER COATED IF SO WHO DID YOU USE .THANKS CHRIS yes it is, was done by Maldon Shotblasting and Powdercoating, was £144 plus vat in 2011 with zinc coat first and with the swingarm.
Post by kostas on Feb 5, 2013 22:01:30 GMT 1
Hi Bryan,
Had a look at you build, very nice work!, What did you do with the mudguards and air filter box and got them so shiny?
Mine are faded, what the secret?
Thanks
Kostas
Post by bryan on Feb 5, 2013 22:17:19 GMT 1
Think I just cleaned with soapy water and polished a few times with bumper black. The sides of the airbox were cleaned up with fine wire wool and done with bumper black, will also be doing the petrol cap that way too. I think its all in this post.
Post by bryan on Feb 10, 2013 22:56:03 GMT 1
cleaned and sprayed the exhausts today. As PJ1 is NLA Ive used the stuff Yambist is selling. Ive left the back of the hanger on 1 of the pipes as I want to reproduce the Orange paint spot. I think is a better match than PJ1, Noticed in this pic I posted a few pages back, that I hadnt done the clock nuts. stuck them on a bolt, wire wheeled them on the bench grinder, and a few coats of black, job done. Got given this as it was missing on the bike, coat of black and new screw and washer.
Post by arrow on Feb 10, 2013 23:00:19 GMT 1
The last photo of the bracket thingy, where does that go?
Post by marsbar350 on Feb 10, 2013 23:05:25 GMT 1
clock to headlight
Post by arrow on Feb 10, 2013 23:06:43 GMT 1
Don't remember seein' one of them.
Post by marsbar350 on Feb 10, 2013 23:08:23 GMT 1
philips screw goes in the headlight bowl and the other end screws into the clock bracket
Post by bryan on Feb 10, 2013 23:12:31 GMT 1
and the top is screwed in to the clock bracket, lots of LCs have em missing.
Post by arrow on Feb 10, 2013 23:15:45 GMT 1
Cheers for that. Fantastic resto.
Post by bryan on Feb 11, 2013 0:25:01 GMT 1
got this cleaned up and painted tonight too. I think thats all the re finnishing done, just waiting on the chrome to get back from the platers.
Post by steelerd on Feb 11, 2013 0:27:49 GMT 1
what paint did you use on the sidecase ? the yambits satin stuff ? looks lush
Post by bryan on Feb 11, 2013 0:51:28 GMT 1
no, thats the last can of PJ1 on the planet, got 2 cans of the Yambits case paint just incase I ran out and had to spray the other one to match.
Post by tout on Feb 11, 2013 22:30:57 GMT 1
Post by bryan on Feb 11, 2013 22:57:12 GMT 1
The last photo of the bracket thingy, where does that go? this is where it lives.
Post by bryan on Feb 14, 2013 22:38:21 GMT 1
Finnishing off the inside of the tank b4 bodywork goes off to Norbo to get painted. Inside was a bit rusty, but hopefully will be ok. first part is Marine Clean and fish tank gravel. mix it with hot water and shake about for ages, rinse it out and do it again. Then its the Prep and Ready which kills rust and leave a Zinc Phospate coating preventing rust. And it ends up alot cleaner. Not using the epoxy sealer as its a good tank, lets hope!
Post by marsbar350 on Feb 15, 2013 0:32:16 GMT 1
nice job on the tank bryan mines as clean always put a dash of redex in to keep things a touch oily and rust free
Post by bryan on Feb 15, 2013 15:07:32 GMT 1
They only rust when there is no petrol in them, as oxidisation needs air. Already starting to sow light rust since I rinsed the Prep and Ready with hot water.
Post by bryan on Feb 16, 2013 17:24:01 GMT 1
Got a little done today. New replacement air box strips in place, oiled filter and fitted the lid. Head on and torqued down, temp sender, rear hose and new clamps fitted. Also new plugs and caps. I fitted engine case, kick start and an exhaust just for a pic.
Post by Deleted on Feb 17, 2013 4:58:31 GMT 1
I've just spent an hour reading through this thread, Bryan... It's pretty damned informative. Keep up the great work, can't wait to see the finished bike.
Post by scoobytoo on Feb 17, 2013 14:07:56 GMT 1
TOUT, stop teasing and sell it... To me please as I'm still lookingy;)
Post by bryan on Feb 17, 2013 22:40:20 GMT 1
Today's job was to get the clutch and cover sorted, fitted new fiber clutch plates and replacement steel plates, oil pump and pipes to carb, and water pump. Waterpump gasket and oil pipe from tank should be here in a few days so I can fit it.
Post by bryan on Feb 18, 2013 19:02:58 GMT 1
Had to make 2 washers to take the usual slack in the exhaust headers, had a bit of flat plate alloy and just need to do a bit more filing. :cry:
Post by billy on Feb 19, 2013 5:00:30 GMT 1
Ugh.. I hate doing those kind of jobs in aluminum, especially that kind of alloy. It clogs up the files in no time and it's fecking tough to work with! I'd much rather do a part in steel than in aluminum (at least when hand shaping it). I wonder if there are flap discs made for aluminum hmmm? Flap discs works great for shaping steel but it's pointless trying it on aluminum, except maybe cast aluminum, but even that can clog the disc up badly.
Post by bryan on Feb 19, 2013 10:42:46 GMT 1
isn a pain, but its all ive got here. Got 1 finnished last night and its taken most of the moovement out and should be fine will gasket sealer on all the joints.
