Post by adgix92 on Jan 5, 2022 20:52:38 GMT 1
Hello, just joined and looking forward learning from you guys. So my build is in its infancy and forgive me if I've posted in the wrong place! I have just acquired a Q reg rd250lc frame and would like to do a hybrid build! Nothing crazy and I've seen pics of completed bikes but none on how they got there. Im after fitting a yzfr125 swingarm in ( i have a complete swinger/wheel/shock/caliper etc, im after some advice on how best to fit this and whats involved? If anyone has done this before? Abit of guidance really π
Cheers
Adam
Post by dusty350 on Jan 5, 2022 21:02:25 GMT 1
Hi Adam Welcome to the forum You are in the right place. Loads of high quality hybrids and standard builds here. Spend some time reading through. Lots of threads are very "in depth" and provide lots of vital info and "how to's" Let guys know roughly where you live and they may be able to guide you to local engineers/specialists should you need mods doing. Pretty sure the Yzf arm has been done before and nothing is impossible (usually!!) Regards Dusty
Post by dusty350 on Jan 5, 2022 21:07:12 GMT 1
Forgot to add, the search function at the top of the page makes it easier to find relevant info Dusty
Post by adgix92 on Jan 5, 2022 21:07:44 GMT 1
Hi Dusty,
Thanks for the welcome. Im based on the isle of wight! I have a guy here that i used a few years ago here that has a machine shop when i have some bits made for my old trackbike but haven't been in contact with him recently. Yeah I've seen pics of LC's with the yzf swinger in and few posts saying its a common option but nothing in between! Sure you guys can fill in the blanks . using an rs125 front end which just bolts right up! But as per many builds, rolling chassis first, worry about the rest later...
Post by dusty350 on Jan 5, 2022 21:12:51 GMT 1
Internal measurement across the swingarm pivot on an Lc frame is 200mm if I remember correctly. Measure the Yzf width - the difference (if any) is your first issue. Spindle diameter next. Then you'll be looking at how you get the Lc shock to mount on the swingarm, and then it's chain alignment - hope you've got an engine ! Dusty
Post by sidney81 on Jan 5, 2022 21:13:41 GMT 1
Hi Adam , welcome π
Post by 4l04ever on Jan 5, 2022 21:17:14 GMT 1
Welcome in :-) Get on Tapatalk and post some pics.
Post by adgix92 on Jan 5, 2022 21:18:27 GMT 1
Thank you π Dusty, the swing arm has a gap either side when offered into the frame so i assume im going to have to shim the gap with spacers, and i have a yzf swingarm spindle en route and a friend with an RD one to use as reference. Think the biggest thing is figuring out if the top mount is going to offer up using the yzf suspension linkages. I do have an engine waiting in the wings, although its not paid for yet, but available for reference for aligning etc
Post by adgix92 on Jan 5, 2022 21:20:43 GMT 1
Welcome in :-) Get on Tapatalk and post some pics. Thanks bud, will get on that asap. Will start getting some pics over the weekend and see what ya think.
Post by dusty350 on Jan 5, 2022 21:25:31 GMT 1
Having done a quick search, it seems the Yzf arm is approx 4" longer than stock, which isn't ideal, but wont be a deal breaker. Rgv arms are 4" longer than stock too, but plenty of guys use them with no issues. I think Alex - Donkeychomp on here, had an aircooled with a Yzf rear end in it - the aircooled and Lc swingarm dimensions are the same. And yes, shims/spacers needed to take up the slack if it slots in and leaves a gap.
Post by adgix92 on Jan 5, 2022 21:31:03 GMT 1
I think i saw that post shortly before i joined on here, but i think the top shock mount is different on the aircooled frames? Im wondering if its mods to the frame and or swinger to fit, hoping it will become apparent when this swingarm bolt arrives so i can start mocking up properly. I think the shock fitting is going to be the spanner in The works, however i will adapt and overcome haha
Post by dusty350 on Jan 5, 2022 21:47:27 GMT 1
Post by adgix92 on Jan 5, 2022 21:56:11 GMT 1
Wow that's incredible looks as good as factory!! I may well send a message and see if this is something he could take on for me! Thanks dusty!
Post by donkeychomp on Jan 5, 2022 22:05:15 GMT 1
You beat me to it Dusty! Yes a YZF will fit (anything can with time/patience/money) but you do need spacers and of course some serious mods to the swing arm shock mounting position.
And welcome to the forum!
Post by adgix92 on Jan 5, 2022 22:07:48 GMT 1
You beat me to it Dusty! Yes a YZF will fit (anything can with time/patience/money) but you do need spacers and of course some serious mods to the swing arm shock mounting position. And welcome to the forum! Alex Hi Alex, Looking at your thread with that swingarm conversion, that the nuts!! I've messaged Chris to pick his brains and see about how to go about this. Thanks for the welcome, be sure to keep you all informed! Adam
Post by arrdy350 on Jan 5, 2022 22:26:13 GMT 1
Welcome to the forum π
Post by Tobyjugs on Jan 5, 2022 23:06:01 GMT 1
Hi Adam welcome to the forum. Thats an interesting choice for a 250 LC, am i correect in thinking its a 4L1 model. The reason i ask is because its a very long swing arm for the LC 4L1 type bike. A standard 4L1 swing arm measures 46cm from center wheel spindle grooove to center swing arm pivot. The YZF arm is 100mm longer for the same measuring points. If you are using the standard seat and tail piece this might look odd. I just thought i would point this out in case you have not thought about it as i see you mention you only have a frame in your first post. Good look with the project what ever you decide and post lots of pictures. We like pictures Tony
Post by donkeychomp on Jan 5, 2022 23:13:47 GMT 1
Another thing...why not use a YZF front end, if anything for a bit of symmetry? And that does bolt straight on...well it did on an RD anyway!
Post by adgix92 on Jan 5, 2022 23:17:15 GMT 1
Hi Adam welcome to the forum. Thats an interesting choice for a 250 LC, am i correect in thinking its a 4L1 model. The reason i ask is because its a very long swing arm for the LC 4L1 type bike. A standard 4L1 swing arm measures 46cm from center wheel spindle grooove to center swing arm pivot. The YZF arm is 100mm longer for the same measuring points. If you are using the standard seat and tail piece this might look odd. I just thought i would point this out in case you have not thought about it as i see you mention you only have a frame in your first post. Good look with the project what ever you decide and post lots of pictures. We like picturesΒ Tony Thanks Toby, I have only seen pictures of bikes that have had this done and like the way it looks but yes i will look to fit standard seat etc. Not to sure on frame lingo yet as abit of a novice when it comes to particulars but definitely an rd250lc frame. Adam
Post by adgix92 on Jan 5, 2022 23:20:03 GMT 1
Another thing...why not use a YZF front end, if anything for a bit of symmetry? And that does bolt straight on...well it did on an RD anyway! Alex I have a front from a rs125 with a top yoke that's been converted with risers for handle bars but may look into fitting yzf front wheel (so they match) or rs rear wheel, whatever's easiest! Adam
Post by yamark on Jan 6, 2022 12:32:55 GMT 1
Looking forward to this build, and welcome in Adam
Cheers, Mark
Post by Mr Kipling on Jan 6, 2022 15:12:11 GMT 1
Hi and a warm welcome enjoy the forum and enjoy your build...
Post by evochris on Jan 6, 2022 16:53:15 GMT 1
Welcome to the board, you will find and from above already seen a very informative and friendly bunch.
Post by andy748 on Jan 6, 2022 17:11:46 GMT 1
Hi Adam, welcome in mate, get some pictures uploaded, loads of help here. Andy.
Post by adgix92 on Jan 6, 2022 19:39:41 GMT 1
Thank you all for the warm welcome. In all honesty this will be a slow burner as baby on the way (ya know how it goes!) But il be sure to post some pics hopefully over the weekend and keep you all updated. So today whilst looking through the scrap pile in my workshop, i found an old gsxr1000 shock from my old trackbike, i was looking at the fitting at the bottom and thought that might well be suited as a top mount on this yzf swinger so.....cut it off and offered up think it could well work nice welded into position. Only an idea but looks good and suits the rd250lc shock eyelets well so with abit more of a jig about tomorrow we will see. Pics to follow!
Cheers
Adam
Post by arrow on Jan 6, 2022 19:47:06 GMT 1
Hi, welcome to the forum.
Post by mouse on Jan 6, 2022 19:58:02 GMT 1
Hi, this sounds interesting, any pics?
Mouse
Post by adgix92 on Jan 6, 2022 20:06:25 GMT 1
Hi, this sounds interesting, any pics? Mouse Mouse, I will get some over the weekend Cheers π
Post by mak595 on Jan 9, 2022 4:29:02 GMT 1
zebec
Post by zebec on Jan 9, 2022 13:40:36 GMT 1
Hey... I live in Ryde, Isle of Wight and ride a 250LC Happy to meet, chat or swap ideas
