Post by midlifecrisisrd on Jan 2, 2023 17:39:56 GMT 1
Spent half an hour on the loom 😒
They are usually manky round about the oil tank but FFS this one is manky all over.
Been at it with a rag and acetone and cut all the loose tape off. What a sticky mess
Its never going to look like new but most wires seem intact
Healight bulb connector is knackered, one wire out and 1 wire broken/missing
Twin horn loom shagged too. I'll patch the tape and see if I can persuade it onto the bike
Post by lcmarky on Jan 3, 2023 9:38:07 GMT 1
Spent half an hour on the loom 😒 They are usually manky round about the oil tank but FFS this one is manky all over. Been at it with a rag and acetone and cut all the loose tape off. What a sticky mess Its never going to look like new but most wires seem intact Healight bulb connector is knackered, one wire out and 1 wire broken/missing Twin horn loom shagged too. I'll patch the tape and see if I can persuade it onto the bike Steve I've put manky looms in my ultrasonic cleaner before & they've come out well. nice clean fluid with some good detergent is all you need. Obviously hang up to dry afterwards!!
Post by JonW on Jan 5, 2023 1:12:46 GMT 1
Spent half an hour on the loom 😒 They are usually manky round about the oil tank but FFS this one is manky all over. Been at it with a rag and acetone and cut all the loose tape off. What a sticky mess Its never going to look like new but most wires seem intact Healight bulb connector is knackered, one wire out and 1 wire broken/missing Twin horn loom shagged too. I'll patch the tape and see if I can persuade it onto the bike Steve Doesnt sound impossible. Ive had to repair worse and it all worked fine when complete and Im not the sparky you are Steve
Post by midlifecrisisrd on Jan 8, 2023 19:03:06 GMT 1
Retaped and fitted the loom today, battery box and oil tank Seem to be short of the oil tank top fixing ☹ Steve
Post by midlifecrisisrd on Jan 15, 2023 17:59:14 GMT 1
Oil tank fittings from Norbo arrived Also stripped, sanded and painted the tail light backplate. The earth spade connector broke so another little job needed 🙄 Steve
Post by Tobyjugs on Jan 22, 2023 13:43:57 GMT 1
Is that one of Norbo's tail tidy's?
Post by midlifecrisisrd on Jan 22, 2023 13:56:18 GMT 1
Is that one of Norbo's tail tidy's? Yes, sure is Steve
Post by midlifecrisisrd on Feb 3, 2023 17:39:08 GMT 1
Decided I better make a start on sorting the rear disc alignment Need a 6mm disc spacer so took a slab of 10mm alloy plate and started cutting it down to size OD needs to be just under 150mm so cut out a square, drilled a centre hole then machined the corners off Next I'll have to work out how to mount it on a faceplate and get it on the lathe to make it round lol Steve
Post by stusco on Feb 3, 2023 18:29:16 GMT 1
How big is the chuck on your lathe? Do the dogs reverse? Mind you 5 mm isn’t much to grip if they do
Post by midlifecrisisrd on Feb 3, 2023 19:15:28 GMT 1
How big is the chuck on your lathe? Do the dogs reverse? Mind you 5 mm isn’t much to grip if they do I have internal and external jaws for the chuck but it isn't big enough to grab the outside Once I cut the inside hole it would probably go on the chuck to cut the outer My plan was to remove the chuck and fit the face plate. I drilled the centre hole so I could centre it on the faceplate using the tailstock centre then clamp the octagonal bit of 10mm plate to the faceplate I eed a recess on the inner hub side to locate onto the hub and a lip on the outer face to locate the disc onto hence why I'm using 10mm plate for a 6mm spacer Hopefully the chuck will unscrew easily 🤣 I was looking for a bigger chuck for the lathe but wasn't sure which fitted as not sure of the thread size The other option I thought of was to buy a rotary table and chuck for the mill I'll work it out in the end lol Steve
Post by muttsnuts on Feb 3, 2023 19:35:18 GMT 1
make a dummy shaft up and put it through the centre of the plate, put some big washers either side and then tighten it up, I normally use a set bolt or allen bolt, then hold that in the jaws of the lathe and turn the outside down to size - hope that is clear ? good to see the old miller working
Post by midlifecrisisrd on Feb 3, 2023 20:16:41 GMT 1
make a dummy shaft up and put it through the centre of the plate, put some big washers either side and then tighten it up, I normally use a set bolt or allen bolt, then hold that in the jaws of the lathe and turn the outside down to size - hope that is clear ? good to see the old miller working Makes perfect sense I had a brief though of drilling the centre and tapping to M10, sticking a bolt in it then sticking it in the chuck but wasn't sure if it would grip enough I'll have a play when I get more time 👍 Mill is working well, this week has been thefirst time clamping stuff down so another bit learned Steve
Post by muttsnuts on Feb 3, 2023 20:26:44 GMT 1
if you know what size the centre hole is going to be then make it that size so you can make the biggest shaft/bolt possible, that way you can tighen it better so less chance of it slipping, just take small cuts and it will be fine
Post by masonmart on Feb 4, 2023 10:30:30 GMT 1
Reading this and Chris's articles could have had the effect of making me give up but I'm going to harness it. Incredible work Steve
Post by midlifecrisisrd on Feb 5, 2023 17:38:28 GMT 1
Messed around a little with the lathe today Removed the chuck and fitted the faceplate Jammed the workpiece against the faceplate with a revolving centre to see how it was going to work Started gently cutting the outer edge to make it round, nearly there The bad news is that there is a run out on my faceplate so I won't be able to cut the face down to 6mm this way Steve
Post by jon on Feb 19, 2023 11:16:34 GMT 1
Plan for today was to trial fit the forks/yokes onto the bike to check the lock stops Pressed the bearing onto the bottom yoke then found the bottom of the frame headstock hits the yoke so a spacer is needed under the bearing Very steep learning curve as I switched the lathe on and set about making a 3mm spacer Drilled a 17mm hole in the centre then opened up to 30mm with a boring bar before cutting 3mm off That sounds easy but took over an hour 🤣 Was still quicker than either buying a 5mm one then having to wait for post or getting one made Steve I’ve only just noticed this you naughty boy. Disconnected interlock tut tut. Jon
Post by midlifecrisisrd on Feb 19, 2023 11:33:42 GMT 1
Plan for today was to trial fit the forks/yokes onto the bike to check the lock stops Pressed the bearing onto the bottom yoke then found the bottom of the frame headstock hits the yoke so a spacer is needed under the bearing Very steep learning curve as I switched the lathe on and set about making a 3mm spacer Drilled a 17mm hole in the centre then opened up to 30mm with a boring bar before cutting 3mm off That sounds easy but took over an hour 🤣 Was still quicker than either buying a 5mm one then having to wait for post or getting one made Steve I’ve only just noticed this you naughty boy. Disconnected interlock tut tut. Jon Lol That's when I first got it and had issues with the overload tripping out so I bypassed everything and wired the 415v straight onto the direction switch 😬 A new motor later it is all reinstated, overload and all 4 safety switches 😁 If you look at the pic in the post before yours you can see the switch is functional... ...I've just stuck a cable tie on it 🤣 Steve
Post by jon on Feb 19, 2023 11:38:03 GMT 1
Yes I saw that too. Don’t let our SHE manager at work see that or you’ll be in trouble 🤣
Post by midlifecrisisrd on Feb 19, 2023 11:50:03 GMT 1
Yes I saw that too. Don’t let our SHE manager at work see that or you’ll be in trouble 🤣 Jon The problem is that when you are working close to the chuck the safety guard gets in the way of the cross slide One other thing the old school lathe does us give you a heat off the angle poise lamp Good old 24v tungsten filament lamp gives off as much heat as light 😆 Steve
Post by jon on Feb 19, 2023 11:58:06 GMT 1
I’ve got a 240v 120w spot lamp above mine. Below it is a shelf for tools. If you leave a tool there for any length of time next time you pick it up you have to throw it in the coolant tray quick.🤣
Post by JonW on Feb 19, 2023 12:54:27 GMT 1
LOL, I have an LED above mine... defo dont need anything heat related here lol
Post by midlifecrisisrd on Mar 1, 2023 18:48:46 GMT 1
Finally got round to ordering bigger main jets for the Swarbrick pipes so managed to get the carbs fitted Only had enough pink tube for the vents so ordered more for the overflows Need to order some genuine fuel pipe too Steve
Post by midlifecrisisrd on Mar 1, 2023 20:18:08 GMT 1
One lesson I did learn today
Fit the 2 lower airbox mount bolts before fitting the inner guard and swinger 🙈
Post by arrdy350 on Mar 1, 2023 20:20:12 GMT 1
Hi Steve Bike build is looking good 👍 Where do you get Genuine fuel pipe from as I need some for my YPVS?
Post by midlifecrisisrd on Mar 1, 2023 20:25:33 GMT 1
Hi Steve Bike build is looking good 👍 Where do you get Genuine fuel pipe from as I need some for my YPVS? I'd have to double check the part number as LC stuff is smaller 2 mins Steve
Post by midlifecrisisrd on Mar 1, 2023 20:29:50 GMT 1
Hi Steve Bike build is looking good 👍 Where do you get Genuine fuel pipe from as I need some for my YPVS? Think the Yam part number 90445-116K9 Fowler list it at about £14 for 400mm It's on ebay too under that part number Steve
Post by dusty350 on Mar 1, 2023 21:03:12 GMT 1
Looking great Steve Funny - I ordered some Lc fuel pipe from Fowlers today - 90445 090F6 £6.58 plus Vat Dusty
Post by midlifecrisisrd on Mar 1, 2023 21:08:11 GMT 1
Looking great Steve Funny - I ordered some Lc fuel pipe from Fowlers today - 90445 090F6 £6.58 plus Vat Dusty Lol I'm debating whether to order some stuff from Fowlers but I've overspent this month 😂 Suzuki expert do it on ebay at £9.95 delivered so my wallet may wimp out and go there 🙈 Steve
Post by dusty350 on Mar 1, 2023 21:19:35 GMT 1
I ordered a few bits - wheel bearing seals, new clutch cable, oil hose, and a couple of other bits - come to £80 ! Free next day shipping over £70 though These aren't getting any cheaper to build, that's for sure Dusty
Post by arrdy350 on Mar 1, 2023 21:45:29 GMT 1
Hi Steve Bike build is looking good 👍 Where do you get Genuine fuel pipe from as I need some for my YPVS? Think the Yam part number 90445-116K9 Fowler list it at about £14 for 400mm It's on ebay too under that part number Steve Thanks Steve 😀👍 I will put it on the list every time I think I have got all I need, I keep finding more parts to order 🤣
