Post by midlifecrisisrd on May 25, 2021 16:12:21 GMT 1
Had bits of this one since January since it was dropped off Progress is slow especially now I'm back at work full time Frame is a UK 4L0 but it's had some abuse and some bodges Its an early non tie bar frame but someone had added tie bars but totally hopeless job. Pigeon sh1t welding onto the side rails only so no actual support. They had been removed from the donor frame with an angle grinder so too much meat lost to make them work Here's the frame as it is just now
Post by midlifecrisisrd on May 25, 2021 16:15:00 GMT 1
Here is the tie bar area now Thankfully I also found someone chopping a frame so donor bits sorted
Post by midlifecrisisrd on May 25, 2021 16:24:18 GMT 1
Next bit of abuse is the centre stand rail which is totally fecked Again thankfully I have a frame section
Post by midlifecrisisrd on May 25, 2021 16:28:19 GMT 1
Made a start on the stand rail replacement by cutting slots with a dremel down the tubes, I'll cut the frame section to match Doing it that way so it goes in at the right angle
Post by midlifecrisisrd on May 25, 2021 16:36:56 GMT 1
Bottom yoke will be fazer 600 and top yoke xjr400 Forks are also xjr400. Stanchions are with All Bike Engineering getting a new pair made 30mm shorter. Been delayed due to him struggling to get the tubing and chroming Swingarm is CBR400 NC23 tri arm which arrived back from NK today Steve
Post by midlifecrisisrd on May 25, 2021 16:59:22 GMT 1
Engine is already done as I built it last year Mutts sorted the basics. Exhaust stud holes welded up and redrilled/tapped, bored to 0.25, new pistons, crank rebuilt etc Andy did the vapour blasting and I assembled it all Steve
Post by donkeychomp on May 25, 2021 21:53:03 GMT 1
Looks like a great start! I do like that swingarm.
Post by midlifecrisisrd on May 26, 2021 14:51:40 GMT 1
Cheers Alex Got another hour on it yesterday Stand rail cut out and old tie bar remains removed Steve
Post by sidney81 on May 26, 2021 17:45:20 GMT 1
Cool ,this will be a good build 🙂👍
Post by midlifecrisisrd on Jun 3, 2021 19:49:38 GMT 1
Decided to see how the rear hub fitted in the arm It will have spoked wheels, had 3 hub options One TDR250 hub, one RD400 hub and took a gamble and bought a billet cnc'd hub made for a DRZ400sm with a cush drive First choice was the billet one as it was 20mm spindle like the swing arm Reckon there is plenty of room in the arm. At least with a spoked wheel you can get the rim laced on offset to give an extra few mm if needed but think it will be ok Luckily the DRZ sprocket is 520 and available cheaply as a 41t Steve
Post by JonW on Jun 4, 2021 4:12:45 GMT 1
that hub looks a great choice Steve. nice work as ever mate.
Post by midlifecrisisrd on Jun 30, 2021 17:55:45 GMT 1
Did the bit I'd been dreading, cut the centre stand rail to fit I was a bit concerned the newly converted swing arm didn't fit, 1 or 2mm too wide Now I'm not doubting Nigel at NK so I suspected the frame had been pinched a bit. At first I suspected the swing arm had been horsed up without any shims but when I compared the stand frame rail the twisting had pulled it in a bit An hour with a hydraulic jack and an angle grinder I think it is ready to tack in Steve
Post by oldbritguy on Jun 30, 2021 19:12:25 GMT 1
Nice work Steve. That is some impressive cutting. Are you gonna do the welding yourself now that you have been dabbling with the sparky thing? 😎 John
Post by midlifecrisisrd on Jun 30, 2021 19:45:17 GMT 1
Nice work Steve. That is some impressive cutting. Are you gonna do the welding yourself now that you have been dabbling with the sparky thing? 😎 John Cheers John, was putting it off for ages but I'll soon have to send the hubs away to get built so need to be able to mock up a rolling chassis Welding wise I've just tacked it in just now Need to make a bigger tab for the steering stop then fit a set of engine cases temporarily so I can tack in tie bar brackets I'll have another practice with the welder on cut offs from an LC frame then decide whether to do it myself or take to a mate Steve
Post by donkeychomp on Jun 30, 2021 21:25:25 GMT 1
Brave lad for doing the cutting but looks like you've sorted it all out, so I doff my cap to you sir.
Post by midlifecrisisrd on Jun 30, 2021 21:30:07 GMT 1
Cheers Alex, I just had to put my big boy pants on and get on with it lol
Post by shaunthe2nd on Jun 30, 2021 23:19:18 GMT 1
Good progress Steve. Had to do some chopping on my project frame so know how you felt. I don't have a welder so used local garage for that bit, wasn't a lot of money and at least I knew it was done to a high standard.
Post by JonW on Jul 1, 2021 1:46:17 GMT 1
Sadly this is the kind of work we are going to have to do now that the bottom of the barrel has been reached for bikes to rebuild. I did a similar big frame repair on my F2 frame so know the effort that is behind these pics to not only check everything is in place but also work out where to cut and how much etc. Its quite mentally taxing really, but the results are worth it I think. Good progress mate!
Post by midlifecrisisrd on Aug 5, 2021 8:24:24 GMT 1
I tacked the centre stand rail in a while ago but last night I cut the engine tie bar mount brackets to size and tacked them in Popping by a mates today who is going to weld it all up Don't want to risk my welding on structural stuff Dropped the front hub off to get ceramic coated black. When it's back I'll get the wheels away to get rims laced on Steve
Post by Tobyjugs on Aug 5, 2021 14:09:31 GMT 1
That's a nice swing arm Steve.
Post by midlifecrisisrd on Aug 5, 2021 17:46:25 GMT 1
That's a nice swing arm Steve. If it was easier to convert I'd have had one in a ypvs lol Its a bit different than the usual suspects Frame all welded up now, even got a welding lesson which was appreciated, cheers Rod 👍 Steve
Post by tacky1 on Aug 6, 2021 0:23:32 GMT 1
I really like the Swingarm you’re using. Going to look great all back together
Post by midlifecrisisrd on Aug 6, 2021 18:26:43 GMT 1
Front hub back from ceramic coating 😎
Post by midlifecrisisrd on Sept 6, 2021 15:58:27 GMT 1
A call from Hagon and £719 lighter the wheels are on their way back to me 😀
Post by Yogi on Sept 6, 2021 18:09:08 GMT 1
A call from Hagon and £719 lighter the wheels are on their way back to me 😀 Steve OUCH 🥺
Post by midlifecrisisrd on Sept 6, 2021 18:13:34 GMT 1
A call from Hagon and £719 lighter the wheels are on their way back to me 😀 Steve OUCH 🥺Tell me about it 🤨 Prices have gone up since I last did them. And is it just me or have tyre prices shot up ☹ Steve
Post by Yogi on Sept 6, 2021 18:15:26 GMT 1
Tell me about it 🤨 Prices have gone up since I last did them. And is it just me or have tyre prices shot up ☹ Steve Everything has rocketed 😤
Post by mouse on Sept 6, 2021 20:17:25 GMT 1
Yes tyres too! And you cannot get specific tyres at the moment, have been waiting for months to get a supercorsa rear, Pirelli now say November!
Sprockets too, Renthal seem to have nothing!
Aaaaaarh!
Mouse
Post by midlifecrisisrd on Sept 6, 2021 20:51:28 GMT 1
Only thing that seems an option is either Avon AM26's or Bridgestone BT090's ☹
Post by mouse on Sept 7, 2021 2:20:08 GMT 1
Only thing that seems an option is either Avon AM26's or Bridgestone BT090's ☹ Steve Actually, i put some AM26's on my standard 4LO earlier this year and i think they are superb, i much prefer them to the previous BT45's, cannot comment on the Bridgestone's as i have never used them but they have been around for a while. Mouse
