Post by midlifecrisisrd on Jan 12, 2022 20:04:45 GMT 1
It's like you are reading my mind 😆 I'd seen the engineer I used dressing the edges with one and had it on my list of things to do Cheers for the link 👍 Steve
Post by yamark on Jan 12, 2022 20:10:36 GMT 1
Looking good Steve
Post by Mr Kipling on Jan 13, 2022 18:36:50 GMT 1
coming along nicely....
Post by midlifecrisisrd on Jan 23, 2022 18:10:01 GMT 1
Grabbed an hour or so today to do some work on the frame lock stop tab Need to do a little more dressing but sides built up with weld then dressed back Also reinforced the joint onto the headstock Once I mill the top yoke ignition switch tabs I'll sort the final steering travel and trim the upper tab to suit the steering lock pin Steve
Post by oldbritguy on Jan 23, 2022 20:27:12 GMT 1
Mill!! I remember the days when all you needed was a hacksaw and a file. Them fancy tools you have now have to earn their keep. 😉 Looking forward to seeing how you get on with the latest acquisition John
Post by midlifecrisisrd on Jan 23, 2022 20:39:32 GMT 1
Mill!! I remember the days when all you needed was a hacksaw and a file. Them fancy tools you have now have to earn their keep. 😉 Looking forward to seeing how you get on with the latest acquisition John Not got the mill yet lol I'm happily waiting for Mutts as he needs a window of time so he can stick it on a pallet and shift it to the door If my bloody new car with towbar had arrived I'd just have nipped down with a trailer 😭 I may just cheat and use a milling bit in my bench drill, set the depth and nibble away at the 2 ignition switch mounts. I have a rear master cylinder bracket now but looking at maybe welding it in 🤔 Steve
Post by JonW on Jan 24, 2022 0:21:04 GMT 1
Steve, the new 'upped game' suits you mate. Loving the work.
Post by sidney81 on Jan 24, 2022 11:59:20 GMT 1
Post by midlifecrisisrd on Jan 29, 2022 17:48:29 GMT 1
Needed to work out the front wheel spacers so fitted RD Speedo drive tab, retainer and oil seal along with an XJR400 Speedo drive Easier to centre the wheel in the forks with the discs in so fitted 3mm disc spacers behind the discs to allow the calipers to clear Worked out I need a 10mm spacer for the Speedo side and I need to make the fazer spacer I had in the other side 6mm longer Steve
Post by midlifecrisisrd on Mar 7, 2022 13:52:21 GMT 1
Front wheel spacers are made, honest 😬 Finally had a go with the new milling machine First job was to take 12mm off the XJR top yoke ignition mounts, drill a 5mm hole in them and tap to m6 I'm no longer a milling virgin 😆 Steve
Post by midlifecrisisrd on Mar 8, 2022 19:33:15 GMT 1
Got another hour today Front end on and off a few times grinding back the frame tab till I've got 5mm clearance each side between the top yoke and the tank Then marked up and cut back the top tab for the ignition switch lock to locate onto Steve
Post by yamark on Mar 13, 2022 19:55:07 GMT 1
Front wheel spacers are made, honest 😬 Finally had a go with the new milling machine First job was to take 12mm off the XJR top yoke ignition mounts, drill a 5mm hole in them and tap to m6 I'm no longer a milling virgin 😆 Steve You look like a milling prostitute! Great work, looks awesome
Post by midlifecrisisrd on Mar 23, 2022 20:50:23 GMT 1
Got an hour today. Next issue is getting the rear caliper bracket to locate in the arm. Due to the hub being narrower than the cbr400 wheel it misses by 15mm Bought some 15mm x 38mm flat bar and milled the required 16mm slot in it. I'll cut a 5mm recess in the rear so it will sit over the original mount then get it welded on Steve
Post by muttsnuts on Mar 24, 2022 10:25:57 GMT 1
there's no stopping you now, bet you wish you'd got a milling machine years ago now ! - glad you are finding it useful - project looking good too
Post by midlifecrisisrd on Mar 24, 2022 10:45:34 GMT 1
there's no stopping you now, bet you wish you'd got a milling machine years ago now ! - glad you are finding it useful - project looking good too I know 🙄 Makes it so much more straight forward doing it yourself. No wasted time trying to draw and explain to someone what you want 😆 Got the DRO working too. Spent £4 on new plug casings and it worked. Sockets in back of panel were fine Got £600 odd quid from the courier for the damage so ordering a new power feed unit now 😀 Steve
Post by muttsnuts on Mar 24, 2022 11:05:44 GMT 1
cool, good result in the end - well chuffed for you - did you clock the X,Y and Z to make sure its all square and true ?
Post by midlifecrisisrd on Mar 24, 2022 11:50:18 GMT 1
cool, good result in the end - well chuffed for you - did you clock the X,Y and Z to make sure its all square and true ? Not yet as was only doing non critical stuff and learning the basics Need to buy a decent dial gauge anyway so will get round to it Steve
Post by Tobyjugs on Mar 24, 2022 23:31:40 GMT 1
Looks like i need to send you the drawings for my brake pedal stop. Its fun doing small projects like this and the best bit is you dont have to wait on somebody. "Looks like i need to send you the drawings for my brake pedal stop." Oh no I've changed my mind i want within the next four weeks.
Post by midlifecrisisrd on Mar 25, 2022 9:43:06 GMT 1
You know me too well 🤣
Post by midlifecrisisrd on Mar 28, 2022 21:03:20 GMT 1
Been back on the mill Milled 5mm out the rear of the bracket then nibbled another 1mm out around the edge so it would sit on the chamfer of the old slot Then took 3mm off the top end to stop it looking so chunky Need to double check it lines up ok then get it welded on Steve
Post by sidney81 on Mar 29, 2022 10:41:08 GMT 1
Nice work Steve 😎
Post by midlifecrisisrd on Apr 12, 2022 11:24:14 GMT 1
Picked up the swing arm after having the brake caliper bracket welded on Steve
Post by evochris on Apr 12, 2022 12:56:59 GMT 1
Very nice bit of welding, i don't think that will move in hurry Worth chamfering the edge with a fine file for a nicer finish.
Post by oldbritguy on Apr 12, 2022 13:04:01 GMT 1
Nice job there Steve. Welding done locally? John
Post by midlifecrisisrd on Apr 12, 2022 13:55:28 GMT 1
Nice job there Steve. Welding done locally? John Yes, Polar Weld over at Westfield Ind Est This is toy town compared to his usual stuff lol Steve
Post by midlifecrisisrd on Apr 27, 2022 22:57:39 GMT 1
Dropped the swinger, top yoke, bar risers, tie bar brackets, grab rail and engine mounts off for powder the other week, collected it yesterday I'd originally thought silver for the arm but it looks mighty fine in black 😋 Steve
Post by mouse on Apr 28, 2022 6:03:52 GMT 1
That does look terrific!
Mouse
Post by dusty350 on Apr 28, 2022 6:43:40 GMT 1
Love that swingarm - seriously chunky Great work mate
Post by JonW on Apr 28, 2022 14:37:31 GMT 1
great work Steve!
Post by abar121 on Apr 28, 2022 15:01:24 GMT 1
Looking wonderful. Love the black swing arm.
