Post by midlifecrisisrd on May 20, 2022 21:55:28 GMT 1
Got a couple of hours tonight so got a few jobs done Cleaned the powder coat from where it shouldn't be on the top yoke and fitted the risers Next was to fit the bearings into the swing arm. Strange set up as needle roller on the left side but 2 roller bearings on the other side held in with a circlip and a top hat spacer so all secured on the right hand side Steve
Post by midlifecrisisrd on May 20, 2022 22:00:27 GMT 1
Next job is mocking up the rolling chassis to check the wheels are in line and the frame is straight Fitted the yokes/forks and the swing arm. Thankfully the arm fits in Steve
Post by Tobyjugs on May 23, 2022 14:56:04 GMT 1
Hi Steve why is the bottom rear shock mount slotted?
Post by midlifecrisisrd on May 23, 2022 18:15:48 GMT 1
Hi Steve why is the bottom rear shock mount slotted? It's the way NK does his conversions. There are rectangular inserts that go in the slots. You get 2 pairs, one with the pin hole in the centre, the other offset so you get 3 ride height choices Steve
Post by midlifecrisisrd on Jun 14, 2022 19:07:13 GMT 1
Progressing slowly Frame is away for powder coating so a couple of small jobs done Cleaned up and painted the speedo drive and got the front tyre fitted Leaving the rear tyre off untill I get the engine in and see the chain alignment in case I need to change the offset of the rim on the hub Steve
Post by JonW on Jun 17, 2022 2:14:07 GMT 1
That wheel and disk combo makes me weak at the knees Steve... I'd snaffle those for a motard when youre not looking if i was in your shed
Post by dusty350 on Jun 17, 2022 6:41:48 GMT 1
Not normally a fan of spokes Steve, but they do look magnificent You have a very lucky mate Dusty
zed
Post by zed on Jun 17, 2022 8:14:44 GMT 1
I agree with Dusty they do look great π, I'm not a fan of cleaning them though.
Post by midlifecrisisrd on Jun 17, 2022 8:44:44 GMT 1
That wheel and disk combo makes me weak at the knees Steve... I'd snaffle those for a motard when youre not looking if i was in your shed Lol They are reminding me why I liked "spokey" so much (my 31k retro hybrid build) I'm waiting to see how this looks before I decide whether to do the same with my planned 250 lc ypvs as got a nice set of Yam 17" 3 spokes as well as 2 pairs of spoked hubs There deffo will be a "spokey 2, it spoke again" 31k π Got all the bits for that π Steve
Post by midlifecrisisrd on Jun 20, 2022 13:33:19 GMT 1
Powder coated parts in the sun π Steve
Post by midlifecrisisrd on Jun 20, 2022 20:47:44 GMT 1
Set my old folding work bench in the car port and clamped my bench polisher to it with a grey scotchbrite wheel on it and finished the fork legs Steve
Post by 17again on Jul 3, 2022 16:06:34 GMT 1
they look great : )
Post by JonW on Jul 5, 2022 1:00:54 GMT 1
+1, stunning Steve!
Post by midlifecrisisrd on Aug 1, 2022 20:57:12 GMT 1
Yokes/forks fitted the other week Tonight I trimmed down the chain guide on the arm, fitted the inner muddy, the arm and a new YSS shock Steve
Post by midlifecrisisrd on Aug 2, 2022 10:22:06 GMT 1
And just to prove the forks are fitted π Steve
Post by arrdy350 on Aug 2, 2022 14:27:36 GMT 1
Great job keep the pics coming π
Post by midlifecrisisrd on Nov 17, 2022 14:53:48 GMT 1
Managed a bit more on this Had to strip the back end off as the inner muddy needed surgery to get it to clear the front of the arm Also got the engine fitted. I had built it about 3 years ago. New 0.5 over rebore, newly built crank etc Remembered to fit the lower airbox before fitting the engine π
Post by midlifecrisisrd on Nov 17, 2022 17:42:00 GMT 1
Also fitted the rear subframe, tail tidy and lift handle Then fitted the headlight brackets and a new Yam disc on the clutch cover Steve
Post by Yogi on Nov 17, 2022 18:07:35 GMT 1
Looking good Stevo π
Post by dusty350 on Nov 17, 2022 18:09:19 GMT 1
+1 on that, looking great Dusty
Post by pdxjim on Nov 17, 2022 18:40:00 GMT 1
Fantastic work!
Post by midlifecrisisrd on Nov 26, 2022 17:45:06 GMT 1
Little job done, front calipers stripped ready for blasting. I'll try and do the rear tomorrow Steve
Post by Gunny on Nov 27, 2022 15:06:18 GMT 1
Mot on Tuesday ?
Post by midlifecrisisrd on Nov 28, 2022 21:09:06 GMT 1
Ok, I'm a day late lol All stripped surprisingly easy but did have to use a puller to get the piston out Steve
Post by midlifecrisisrd on Dec 29, 2022 13:51:30 GMT 1
Didn't get a call before Crimbo to say the calipers are ready but I'll chase up next week
Tackled a little but import and job that I'd stomped off in a huff over
I had checked everything was ok before the frame was powdered but when I fitted the yokes and forks the steering lock would not go on with the bars to the right
I tried removing the powder coat off the frame tab and painting instead and the same with the lock tab and still no joy
Finally got the dremel out and trimmed 1mm off the lock frame tab and it now fits π
Painted the cdi too as it was looking sorry for itself
Just about to tackle my favourite (not) job and fit a rubber to the replated kick start lever π
Post by donkeychomp on Dec 29, 2022 22:45:25 GMT 1
Put the rubber in boiling water for 2 minutes then (carefully) slide it on. This method works really well Steve.
Post by JonW on Dec 30, 2022 13:21:34 GMT 1
If that fails, use some Armorall or other vinyl juice and then bang it on something that wont mark it and also twist it a bit now and then. It'll slip on a treat in the end but its tight.
Post by midlifecrisisrd on Dec 30, 2022 14:00:14 GMT 1
It actually went on ok
Cup of boiling water, bit of spit for lube and it went on not too bad
My hands ain't so good, don't laugh but I've used KY Jelly before π³
Slippery but washes away and dries π
Just bought some pvc tape for the loose bits of the loom so that can get some attention
Steve π
Post by jon on Dec 30, 2022 15:30:39 GMT 1
midlifecrisisrd in future try and nick some of the missesβ hair spray while sheβs out. It lubes while wet then dries sticky. I use this for stuff like that all the time such as handlebar grips. Jon
Post by midlifecrisisrd on Dec 30, 2022 16:29:59 GMT 1
Ah, forgot about that, I use it for grips too
