Post by donkeychomp on Mar 1, 2023 22:44:39 GMT 1
Ain't that the truth!
Post by midlifecrisisrd on Mar 12, 2023 17:54:05 GMT 1
Fitted the carb drain hose, the airbox clamps (don't laugh, bought them from Yambits as couldn't find any elsewhere) and replaced one of the carb top rubbers as it had split Then started making the rear disc spacer Steve
Post by oldbritguy on Mar 12, 2023 22:39:16 GMT 1
Coming along nicely Steve. ð If I bundle all my bits in the boot and drop them off, would you bolt the all together for me please ð I am sure you have loads of spare time on your hands ðð John
Post by midlifecrisisrd on Mar 13, 2023 9:47:00 GMT 1
Coming along nicely Steve. ð If I bundle all my bits in the boot and drop them off, would you bolt the all together for me please ð I am sure you have loads of spare time on your hands ðð John That made me laugh, thanks ð Yes, too much time, not enough projects over here ðĪĢ Steve
Post by midlifecrisisrd on Mar 13, 2023 11:08:38 GMT 1
Front face cut with inner lip to locate the disc onto
Post by midlifecrisisrd on Mar 13, 2023 11:12:17 GMT 1
Rear face trued up. The cutting process must warp the plate slightly as it had a bevel Inner recess cut to match the lip on the hub Steve
Post by midlifecrisisrd on Mar 14, 2023 11:37:20 GMT 1
Parted it off last night, ready to drill out the bolt holes on the mill now Steve
Post by Mr Kipling on Mar 14, 2023 12:15:05 GMT 1
Nice work Steve, coming along nicely...
Post by sidney81 on Mar 14, 2023 17:03:54 GMT 1
Great work Steve,nice to get on the machine's ð
Post by midlifecrisisrd on Mar 20, 2023 13:57:05 GMT 1
And drillled
Post by Yogi on Mar 20, 2023 14:42:36 GMT 1
Nice work Stevo ðthereâs no stopping you now
Post by midlifecrisisrd on Mar 20, 2023 15:11:17 GMT 1
Cheers Matt
Need to cut 6mm off the LH wheel spacer now then make a new RH one 6mm longer
I'll try and get the rear tyre fitted this week so I can permanently fit the wheel and get the chain on
Post by midlifecrisisrd on Mar 23, 2023 17:55:23 GMT 1
Got the tyre fitted and balanced yesterday and sorted the spacers last night
Post by Tobyjugs on Mar 23, 2023 17:56:40 GMT 1
Got the tyre fitted and balanced yesterday and sorted the spacers last night Very nice.
Post by dusty350 on Mar 23, 2023 19:28:40 GMT 1
Blingy bling
Post by abar121 on Mar 23, 2023 20:56:41 GMT 1
Lovely and shinny! Looking great.
Post by sidney81 on Mar 23, 2023 22:42:12 GMT 1
Cool ððð
Post by midlifecrisisrd on Mar 24, 2023 21:26:42 GMT 1
Helps if you make the correct spacer 6mm wider ðĪŠ Was supposed to be the one between the caliper bracket and the wheel, not the one between the arm and bracket. Anyway, new spacer made and wheel finally in
Post by midlifecrisisrd on Mar 24, 2023 21:31:30 GMT 1
Next was to fit the clocks. I had previously refurbished these. Original cases, just fitted a mph face and changed he odo gears to miles. Mounting bracket holes are 124mm centre to centre, XJR yoke clock mounts are 120mm so ovalled each hole 2mm inward with a small round file and they are on
Post by midlifecrisisrd on Mar 24, 2023 21:34:55 GMT 1
Next was a trial fit of the handlebars. Guy I'm building it for wanted Renthals with the cross bar for the old school look but they are wiiiiiide Going to cut a bit off each end to reduce a little but still think I'll have to use an lc2 throttle cable
Post by midlifecrisisrd on Mar 24, 2023 21:37:47 GMT 1
Next was to fit the side stand. Replaced bolt and a new spring Had a look at footplate spacing after that. Doesn't need as much as I originally thought. 10 or 12mm should do it That's enough for tonight Steve
Post by sidney81 on Mar 24, 2023 21:42:14 GMT 1
Nice to see this on its wheels Steve ð
Post by Yogi on Mar 24, 2023 22:27:47 GMT 1
Clean the flywheel up Stevo ð
Dusty will have a breakdown if he sees that ð
Post by dusty350 on Mar 24, 2023 22:31:38 GMT 1
Too late ! I'm seeing a therapist on Monday morning ! Looking good Steve, another top job fella
Post by midlifecrisisrd on Mar 24, 2023 22:39:01 GMT 1
Lol
I'll get a scotchbrite pad on it once it's running ðĪĢ
Post by dusty350 on Mar 24, 2023 23:12:23 GMT 1
Therapist cancelled !!
Post by midlifecrisisrd on Apr 20, 2023 14:53:36 GMT 1
Few little jobs done as I've had 10 minutes here and there Stripped the rear footpegs down and had a heavy conversation with them via a hammer and a vice and they are now ready to go for powder coating. I have new peg bars and rubbers for when they are ready I have countersunk the rear of the holes to mount them in the hanger to help with clearance on the swing arm Made some spacers on the lathe to space the hangers out and bought some nice Ti flanged bolts to mount them on the frame. Need to sort the front pegs and fit next Got a gear change peg kit and rear brake clip/washer/spring on the way from Norbo too Other side more complex as I need to get the rear naster bracket powder coated and modify the pedal to suit Steve
Post by davecroucher57v on Apr 21, 2023 20:51:20 GMT 1
love them rims.
Post by midlifecrisisrd on May 10, 2023 15:25:07 GMT 1
Been doing some work on the RH hanger and brake set up Pedal needs modded to work the disc rear Took some measurements the milled off the weld around the pedal pivot so the new actuator would sit flush Then drilled and tapped an m6 hole in the centre so I could "adjust" before finally welding it Then made a tab for the pedal return spring to relocate onto. It needs to move inward to avoid the push rod for the master cylinder Steve
Post by midlifecrisisrd on May 10, 2023 16:05:58 GMT 1
Paint will be on a budget for this one. Tank already in primer and got new plastics from Rob Took advantage of the warmer weather so wiped down the panels with acetone to remove any residues, keyed with scotchbrite and blew down with compressed air 2 coats of adhesion promoter then 3 coats of primer Steve
