Post by sidney81 on Aug 15, 2021 16:47:48 GMT 1
You will need to make sure your chain clears everywhere. I run a 130/70/17 and my chain clears, so that is always an option for you. Hi Rob yes it dose clear I can get away with a 150 but it's close the 140 gives that extra ,I will need a offset front but apart from that it all looks good π
Post by sidney81 on Aug 15, 2021 16:52:42 GMT 1
Hi Chris I had the same wheels on a Ypvs hybrid I built some years back. They came off a Tzr125r Belgarda. As you say, a wider spoke design. I quite liked it but the front wheel only had a single disc and I would prefer the balance of twin discs up front; DSCN3808 by dusty miller, on Flickr Not sure if there is a Brembo front with twin discs that would match ? Dusty Hi dusty cool picture π, the other 3.5 rears are now hard to come buy Andy who I got my last 2 from can't get them anymore he used to hey them in Europe somewhere!! .a different front might be a possibility ! The width matches the fzr front it's just that line that doesn't . Like I said it could be filled or I could blend it in ,not to much of a problem for now π
Post by dusty350 on Aug 15, 2021 17:04:50 GMT 1
The Belgarda front looks quite trick and is USD forks, but it depends on whether you want twin discs or not. Not sure if the SZR660 did a twin disc model - most I've seen are single disc, but had Brembo wheels I believe; DSCN3582 - Copy by dusty miller, on Flickr May give you options Dusty
Post by 4l04ever on Aug 15, 2021 17:14:04 GMT 1
The TZR125 4HW/4FL rear wheel is not a Brembo one, but is the same size as the 4DL wheel you have (3.5 x 17"). They do not have the step in the spokes, but are hard to find...
Post by sidney81 on Aug 15, 2021 17:45:24 GMT 1
The TZR125 4HW/4FL rear wheel is not a Brembo one, but is the same size as the 4DL wheel you have (3.5 x 17"). They do not have the step in the spokes, but are hard to find... Yes Rob that is what I have in my tzr and my air-cooled !! My mate used to get them for the ypm boys but are really hard to get now ,I got this wheel for a really good price .
Post by sidney81 on Aug 15, 2021 17:46:20 GMT 1
The Belgarda front looks quite trick and is USD forks, but it depends on whether you want twin discs or not. Not sure if the SZR660 did a twin disc model - most I've seen are single disc, but had Brembo wheels I believe; DSCN3582 - Copy by dusty miller, on Flickr May give you options Dusty Cool ,I will do some more investigation dusty ,if not I'll go with the brembo and sort the spokes out π
Post by 3tj6 on Aug 15, 2021 18:58:38 GMT 1
I have a brembo szr 660 rear wheel in my hybrid, i sanded the spokes down to make it smooth to match the fzr 3tj wheel in the front π
Post by sidney81 on Aug 15, 2021 19:00:07 GMT 1
I have a brembo szr 660 rear wheel in my hybrid, i sanded the spokes down to make it smooth to match the fzr 3tj wheel in the front π Hi , cool that's what I'm thinking πhave you got a picture ? I'd love to see it ? Thanks
Post by 3tj6 on Aug 15, 2021 19:52:27 GMT 1
I have some pictures mate , i have a build tread on the pb forum but struggle with putting pics on here , try having a look on pb forum or pm me your mobile number and i will send you some π
Post by donkeychomp on Aug 15, 2021 21:14:27 GMT 1
I never knew Brembo made wheels. Having that stamped on it makes it rather special to me.
Post by sidney81 on Aug 24, 2021 12:06:24 GMT 1
Post by dusty350 on Aug 24, 2021 19:07:47 GMT 1
That's an expensive part of the jigsaw crossed off the list then Chris And they look in great condition. Was that the Farming fella you told me about ? Dusty
Post by sidney81 on Aug 24, 2021 19:29:08 GMT 1
That's an expensive part of the jigsaw crossed off the list then Chris And they look in great condition. Was that the Farming fella you told me about ? Dusty hi dusty ,no not him this is another friend I have ,he's got a 250 LC ,I asked him a month or so ago about some parts and clocks and he has 3 sets of the buggers one set was for his bike though ,I'm really chuffed π
Post by dusty350 on Aug 24, 2021 20:05:12 GMT 1
A good friend to have Dusty
Post by sidney81 on Aug 27, 2021 15:22:08 GMT 1
Hi everyone. I've been looking at the clocks and how to mount them ,I think the clocks work well with the fzr top yoke the LC ignition fits in perfect where the fzr one goes so that's good ,thers room to get the cables etc ,I'm going to make some bits of alloy tube and weld on and use LC damper rubbers so they will bolt to the fzr yoke just like they do on the LC . Oh I'm not using clip ons I'm going to use bar riser's πChris
Post by Tobyjugs on Aug 27, 2021 20:50:40 GMT 1
Hi sidney i did the same with my R6 yokes. I did have to lower the LC ignition to make sure it didn't interfere with the clocks
Post by dusty350 on Aug 27, 2021 21:36:51 GMT 1
I've had the same with some yokes too. Works well with the Lc damper rubbers Dusty
Post by JonW on Sept 2, 2021 2:04:27 GMT 1
Thats what I did with my RGV top yoke on my 421, not easy to see here, but i recessed them half into the top yoke as well.
Post by sidney81 on Sept 8, 2021 20:32:04 GMT 1
Post by dusty350 on Sept 8, 2021 20:42:35 GMT 1
Looks spot on to me Chris. On a standard Lc, the clock mount bolts below your spacer and not on top, but I always bolt mine on top coz (a) mine aren't standard, and (b) I prefer the clocks sat up a bit. Wont make any difference to you welding on those alloy mounting points though Dusty
Post by sidney81 on Sept 8, 2021 21:04:09 GMT 1
Looks spot on to me Chris. On a standard Lc, the clock mount bolts below your spacer and not on top, but I always bolt mine on top coz (a) mine aren't standard, and (b) I prefer the clocks sat up a bit. Wont make any difference to you welding on those alloy mounting points though Dusty hi dusty ,cool that's good ,I think they will be good there to ! But as you say they could be mounted underneath if need be π,thanks π
Post by headcoats on Sept 9, 2021 0:19:46 GMT 1
Put ignition switch in too to try for clearance
Post by jon on Sept 9, 2021 7:13:11 GMT 1
From memory those aluminium spacers are too long. Surely the inner steel ferrule should be just proud of the spacer once the rubbers are in. That way the bolt tightens against the inner ferrule, but there is still some rubber damping.
Post by JonW on Sept 9, 2021 14:29:50 GMT 1
+1 for what Jon said.
Post by badger1 on Sept 9, 2021 16:10:30 GMT 1
If that was mine I would sort the headlight brackets out, mount the headlight bucket and then sort the clocks out, heights and gaps.
Post by sidney81 on Sept 9, 2021 21:18:23 GMT 1
From memory those aluminium spacers are too long. Surely the inner steel ferrule should be just proud of the spacer once the rubbers are in. That way the bolt tightens against the inner ferrule, but there is still some rubber damping. Jon hi Jon ,well spotted ,yes they should ,there not finished I've left them long to get an idea of how there going to sit π
Post by sidney81 on Sept 9, 2021 21:18:50 GMT 1
Put ignition switch in too to try for clearance haven't got one π
Post by sidney81 on Sept 9, 2021 21:19:23 GMT 1
If that was mine I would sort the headlight brackets out, mount the headlight bucket and then sort the clocks out, heights and gaps. yep that's not a bad Idea to π
Post by sidney81 on Sept 28, 2021 20:30:01 GMT 1
Post by Yogi on Sept 28, 2021 20:40:02 GMT 1
Some mighty fine work going on there Chris π
Them 370 Faron motors are well quick too π
Matt π»
