Post by sidney81 on Sept 28, 2021 20:41:39 GMT 1
Some mighty fine work going on there Chris π Them 370 Faron motors are well quick too π Matt π» Thanks Matt , yes I've read they go well π and it will make use of my 250 top ππ
Post by donkeychomp on Sept 28, 2021 21:28:40 GMT 1
Always thought the Fahron 370 idea was the best bet. But I do wonder what's involved...do they rebore to 370 and supply pistons? As I can't see the 250 liking that much metal machined out. Also I guess you'll need a 350 oil pump too. And carbs. Or is it a lot simpler than that?
Post by spacejunkie on Sept 28, 2021 21:38:21 GMT 1
I have had this done to 250lc barrels and Ron supplies everything. He does a great job as well lovely bloke
Post by spacejunkie on Sept 28, 2021 21:46:24 GMT 1
Post by sidney81 on Sept 28, 2021 22:22:09 GMT 1
cool nice to see a set done !! How dose it run ? He was very helpful in the phone to
Post by spacejunkie on Sept 28, 2021 22:23:18 GMT 1
Itβs not running yet but Iβam very close
Post by dusty350 on Sept 29, 2021 7:06:01 GMT 1
A few guys here have the Fahron 370 conversion. It gets good feedback. Ron has been doing them for years and his work is top notch. Yea, bit of a wait, but the good guys are always busy Good news on the condition of the engine Chris - makes for a great start Dusty
Post by oldbritguy on Sept 29, 2021 7:26:50 GMT 1
Chris If your barrels are on a good standard bore it might be worth selling them on and sourcing a worn out set for conversion. You can pick up a rough set of barrels cheap enough as Ron will be boring out the old liners and replacing with new. He also machines the chambers in the head for the 66mm bores. His work is spot on Cash from the good barrels would get a rough set for machining plus a 350 pump and worm drive. Just a thought John
Post by sidney81 on Sept 29, 2021 8:37:26 GMT 1
Chris If your barrels are on a good standard bore it might be worth selling them on and sourcing a worn out set for conversion. You can pick up a rough set of barrels cheap enough as Ron will be boring out the old liners and replacing with new. He also machines the chambers in the head for the 66mm bores. His work is spot on Cash from the good barrels would get a rough set for machining plus a 350 pump and worm drive. Just a thought John I've thought this but are good 250 barrels worth much ?? Would it be just more hassle to sell then try to find a cheep worn out set??? I don't know π€you may be right
Post by sidney81 on Sept 29, 2021 8:38:32 GMT 1
A few guys here have the Fahron 370 conversion. It gets good feedback. Ron has been doing them for years and his work is top notch. Yea, bit of a wait, but the good guys are always busy Good news on the condition of the engine Chris - makes for a great start Dusty Yep seems to have a good response dusty , just makes sense to me to get it done , especially with prices of 350 top
Post by sidney81 on Oct 20, 2021 20:52:42 GMT 1
Hi everyone ,I'm back working on the LC now I've finished Alex's swing arm .well I've changed my mind on the front end ,I have picked up of a mate who brake's bike's a complete Yamaha 600 Fazer Front end ,comes with really good condition discs and blue spot callipers,front muddy yokes,even front break master cylinder,I got it for a great price so I had to have it . I'm not going to use the cranked back bar riser's I've got some I brought for the fzr front end .the forks are 41 mm the fzr are 38 mm so the fazers are more chunky and the fazer Front wheel matches my rear wheel (once I've sanded out the lines in the spokes). So today I pressed the stem out cut 20 mm out from it ,made a internal sleave up ,prepped the ends pressed the sleave in then welded it back together with a root ,hot pass and cap ,sorted ! And it fits a treat so the front end is in happy days π I've also been getting the rear wheel in the centre so I can get measurements for the spacers ,I used a plump line and Lazer level took some fafing but it got it spot on them got the measurements I needed so tommrow I will make them on the lathe πthanks Chris
Post by dusty350 on Oct 20, 2021 21:01:46 GMT 1
Great work Chris That's a good looking front end Dusty
Post by sidney81 on Oct 20, 2021 21:10:45 GMT 1
Thanks dusty πI'm pleased with it I will do away with the little fork protectors I'm not keen on them , the forks will need a re chrome as they have pitting but so did the fzr ones ,it's difficult to find a mint set of stantions .
Post by donkeychomp on Oct 20, 2021 21:22:50 GMT 1
That looks great Chris. Sorry I kept you away from your bike for so long!
Post by sidney81 on Oct 20, 2021 21:28:48 GMT 1
That looks great Chris. Sorry I kept you away from your bike for so long! Alex Ha ha it's no problem π I really enjoyed working on the swing arm mate π
Post by donkeychomp on Oct 20, 2021 22:05:04 GMT 1
Post by 3tj6 on Oct 20, 2021 23:00:45 GMT 1
Looking good mate ππ
Post by sidney81 on Oct 21, 2021 7:00:11 GMT 1
Looking good mate ππ Thanks bud π
Rob123
Post by Rob123 on Oct 21, 2021 8:07:30 GMT 1
Looking good Chris lovely welding skills, great idea using a laser to get things lined up π I was told by nigel at nk racing the only place he uses to level the frame was the swingarm pivot not sure if that's any help to you,I know These frames are hard to get reference points from. The rgv arm I used are 5mm higher at one side at the rear I thought it was twisted but nigel said there all like that it was driving me mad π. It is satisfying getting everything lined up well worth the time and effort π Rob
Post by sidney81 on Oct 21, 2021 10:08:52 GMT 1
Looking good Chris lovely welding skills, great idea using a laser to get things lined up π I was told by nigel at nk racing the only place he uses to level the frame was the swingarm pivot not sure if that's any help to you,I know These frames are hard to get reference points from. The rgv arm I used are 5mm higher at one side at the rear I thought it was twisted but nigel said there all like that it was driving me mad π. It is satisfying getting everything lined up well worth the time and effort π Rob hi Rob thanks for the nice comment , yes there a pain I do also use that center point as a reference , I did use a line bob to and it all matched up so I must be on the right path π
Post by Yogi on Oct 21, 2021 11:58:30 GMT 1
Great skills Chris π
Keep the pics coming π
Matt π»
Post by sidney81 on Oct 21, 2021 13:10:15 GMT 1
Great skills Chris π Keep the pics coming π Matt π» Thanks Matt ,πwill do ππ
Post by charles13 on Oct 21, 2021 17:26:46 GMT 1
Looking good Chris lovely welding skills, great idea using a laser to get things lined up π I was told by nigel at nk racing the only place he uses to level the frame was the swingarm pivot not sure if that's any help to you,I know These frames are hard to get reference points from. The rgv arm I used are 5mm higher at one side at the rear I thought it was twisted but nigel said there all like that it was driving me mad π. It is satisfying getting everything lined up well worth the time and effort π Rob I donβt understand how this can be fine; if the rear of the swingarm (axle) is 5mm higher the wheel would be tilted to one side!
Rob123
Post by Rob123 on Oct 21, 2021 19:30:58 GMT 1
Hi Charles, it may not be 5mm maybe 3mm but its definitely higher on the left hand side sprocket side, I had it levelled in the frame at the front than when I put a level across the studs at the back it showed to be out. I was concerned the wheel would be tilted also but once all is bolted up its showing to be bang on level and plumb swingarm/wheel it doesn't make sense to me either. It may be a crude way of checking using levels but I mentioned it to nigel and he said when he puts them in a jig and lowers them down one side touches first? I have read somewhere to not to rely on the marks on swingarm when aligning the wheel cause there normally out. Cheers Rob
Post by sidney81 on Oct 21, 2021 20:45:38 GMT 1
Post by donkeychomp on Oct 21, 2021 22:10:57 GMT 1
More cracking work Chris!
Post by sidney81 on Oct 22, 2021 19:54:44 GMT 1
Post by donkeychomp on Oct 22, 2021 21:19:14 GMT 1
More neat and tidy work mate. I'd leave the spacers as is.
Post by sidney81 on Oct 23, 2021 18:15:09 GMT 1
Post by dusty350 on Oct 23, 2021 20:39:03 GMT 1
We'll never get bored of watching this come together Chris Awesome work as always. And it's not easy grinding back the lettering and raised edges on the "spokes", but it makes a massive difference to the finished wheels. Great effort Dusty
