Post by sidney81 on Mar 29, 2021 17:21:29 GMT 1
Hi everyone , well!! I've got a LC !!! Well bits of one π€£but it's a LC ,long story short it was in with the PV s my brother brought ,it's a 350 4LO German frame ,set of 350 wheels ,some crazy seat unit a good tank and a nice set of stock LC pipes .. Also a 250 LC engine which looks in nice condition! I was on edge as it didn't come with a nova ,it's been in the UK since 2011 so before nova and been sat in the guys shed ever since! But it dose have lots of German paperwork ,log book etc and the receipt of when the guy brought it into the UK , I called HMRC and explained this they said send a letter with copy's of the German paperwork etc and where it's been since 2011 ,so I did that and two weeks later I've got a nova number !! It was simple I can't believe it really I'm so pleased as I can now start the build . Plan ! I've got some 350 barrels and head and I'm going to hybrid it ,I have got a fzr 400 swinger ,wheel spindles on the way it's already been modified to fit a LC frame and I got it for a real good price so going to play with that and see where it goes really !! Going to be a slow build as I want the air-cooled finished , and the LC is going to cost !!! π€£Can think of worse ways to spend it !! Few pictures ππ
Post by arrdy350 on Mar 29, 2021 17:45:56 GMT 1
Nice hybrid project. Can't wait to see what you do with it ππ
Post by dusty350 on Mar 29, 2021 18:08:13 GMT 1
Proper bargain Chris. Hard to beat that for valueπ Looking forward to your progressπ
Dustyπ
Post by Yogi on Mar 29, 2021 18:12:19 GMT 1
Happy days π
Post by andy748 on Mar 29, 2021 19:09:49 GMT 1
Nice project Chris, i quite like the seat! Andy.
Post by sidney81 on Mar 29, 2021 20:46:35 GMT 1
Thank you everyone πππ
Post by dusty350 on Mar 29, 2021 20:53:01 GMT 1
I like the seat too - different, and looks good on the Lc Dusty
Post by sidney81 on Apr 14, 2021 21:02:46 GMT 1
Hi everyone ,I've been sorting the running gear for the LC ,!! I've been chatting to Martin Johnson and he had a fzr 400 swinger ,wheel , calliper , bracket spindle , spacer's and it came out of a LC ! one of his mates bike so it's been modded to fit between the LC frame , so that makes life bit easier!! That LC ran with a linkage but I'm going to fabricate and weld on a bracket to take the LC shock in its stock form !! Front end I got of Facebook market place fzr 400 , forks , yokes , wheel, mudguard,clip ons (don't need them) all in good condition ,will need rebuilding ,painting etc. I was going to chill out for a bit and get the air cooled finished ( nearly is) but I can't help it looking for bits π€£LC will be rolling soon ! Using the fzr forks it will keep the look of a LC witch I like I will have to cut the forks Down and re thread them like I did on my air-cooled tzr forks as they will be to long . It will keep my brain busy !! Chris
Post by sidney81 on Apr 17, 2021 8:08:00 GMT 1
Post by dusty350 on Apr 17, 2021 8:15:35 GMT 1
Hi Chris, Could you make an adjustable set up, like on the aircooled frame ? Gives you options for the future I'm sure someone with an Lc will take a measurement for you - say from wheel spindle to bolt holt at end of frame, so you know what the standard dimensions are. I have always jacked my Lc's up a bit at the back, especially when using a 17" rear wheel. Dusty
Post by sidney81 on Apr 17, 2021 8:22:36 GMT 1
Hi Chris, Could you make an adjustable set up, like on the aircooled frame ? Gives you options for the future I'm sure someone with an Lc will take a measurement for you - say from wheel spindle to bolt holt at end of frame, so you know what the standard dimensions are. I have always jacked my Lc's up a bit at the back, especially when using a 17" rear wheel. Dusty Hi bud hope your well π , yes that would be a good idea get a measurement ,be something to work to I then can decide weather to go higher or not ! Adjustable is a option to ππ
Post by oldelsieboy on Apr 17, 2021 8:43:08 GMT 1
Good choice of swingarm, they fit well & look good. OEB
Post by sidney81 on Apr 17, 2021 8:55:37 GMT 1
Good choice of swingarm, they fit well & look good. OEB Hi ,wow what a lovely LC !! That looks brilliant it's good to see a complete bike with the arm in ! Alough it's a bit longer than the LC arm it doesn't look it ! Looks right ! πππ
Post by oldelsieboy on Apr 17, 2021 9:41:51 GMT 1
Good choice of swingarm, they fit well & look good. OEB Hi ,wow what a lovely LC !! That looks brilliant it's good to see a complete bike with the arm in ! Alough it's a bit longer than the LC arm it doesn't look it ! Looks right ! πππ That was the main reason for choosing it, hate to see LC's with overly long swingarms fitted. OEB
Post by sidney81 on Apr 17, 2021 9:51:55 GMT 1
Hi ,wow what a lovely LC !! That looks brilliant it's good to see a complete bike with the arm in ! Alough it's a bit longer than the LC arm it doesn't look it ! Looks right ! πππ That was the main reason for choosing it, hate to see LC's with overly long swingarms fitted. OEB Did you use a linkage? Or the stock LC shock? I'm going for the LC shock ,
Post by oldelsieboy on Apr 17, 2021 9:56:46 GMT 1
That was the main reason for choosing it, hate to see LC's with overly long swingarms fitted. OEB Did you use a linkage? Or the stock LC shock? I'm going for the LC shock , I used the LC shock, the conversion was done by NK Racing (pic from his website of similar arm) OEB
Post by sidney81 on Apr 17, 2021 10:06:49 GMT 1
Did you use a linkage? Or the stock LC shock? I'm going for the LC shock , I used the LC shock, the conversion was done by NK Racing (pic from his website of similar arm) OEB Lovely that's what I'm going to do make a bracket similar to that ,thank you , if you wouldn't mind would you measure from the spindle to a fixed point on the frame so I can get an Idea of the height? If it's not to much hassle, thank you
Post by oldelsieboy on Apr 17, 2021 10:09:54 GMT 1
I used the LC shock, the conversion was done by NK Racing (pic from his website of similar arm) OEB Lovely that's what I'm going to do make a bracket similar to that ,thank you , if you wouldn't mind would you measure from the spindle to a fixed point on the frame so I can get an Idea of the height? If it's not to much hassle, thank you Unfortunately I no longer own the bike, sold it 2-3 years ago. OEB
Post by sidney81 on Apr 17, 2021 10:13:32 GMT 1
Lovely that's what I'm going to do make a bracket similar to that ,thank you , if you wouldn't mind would you measure from the spindle to a fixed point on the frame so I can get an Idea of the height? If it's not to much hassle, thank you Unfortunately I no longer own the bike, sold it 2-3 years ago. OEB Ah ok nevermind thank you anyway π
Post by sidney81 on Apr 19, 2021 19:51:32 GMT 1
Hi everyone!! Been working out how to get the fzr yokes in the LC frame ! Well I've got a f2 bottom yoke and stem and the bearing size (I'd) is the same so tommrow at work I'm going to press the stems out and press and weld the f2 stem into the fzr bottom yoke .the fzr top yoke also fits snug into the f2 stem so it should be straightforward really and then fit nicely in the LC I can then get the front end In. Second picture is the fzr top yoke sitting on the f2 stem fits a treat ππChris
Post by Tobyjugs on Apr 19, 2021 20:02:21 GMT 1
I did almost the same for my R6 forks.
Post by sidney81 on Apr 19, 2021 20:08:00 GMT 1
I did almost the same for my R6 forks. it's nice when things are simple hey π
Post by Tobyjugs on Apr 19, 2021 20:14:35 GMT 1
I was tidying up my spare parts I had lying around and got bored. I was curious about some different Yamaha forks I so tried to fit them in a LC frame. The R1 yokes fitted directly into the headstock. You just need to use a bottom yoke bearing on the top.
Post by sidney81 on Apr 19, 2021 20:22:24 GMT 1
I was tidying up my spare parts I had lying around and got bored. I was curious about some different Yamaha forks I so tried to fit them in a LC frame. The R1 yokes fitted directly into the headstock. You just need to use a bottom yoke bearing on the top. thsts good to know , suppose r6 the same etc
Post by Tobyjugs on Apr 19, 2021 20:24:58 GMT 1
Maybe the newer upside down forks. My 5EB's got the same treatment you mentioned above.
Post by sidney81 on May 12, 2021 10:17:37 GMT 1
Post by flames on May 12, 2021 13:34:12 GMT 1
I thought pv stem was same length as LC and they just swap over? Is the bottom yoke you are fitting thicker than LC/pv? Could be that more stem is in the yoke than if in PV one?
Post by sidney81 on May 12, 2021 13:44:29 GMT 1
I thought pv stem was same length as LC and they just swap over? Is the bottom yoke you are fitting thicker than LC/pv? Could be that more stem is in the yoke than if in PV one? Hi bud , yes it could be that !! I'll have a measure up π€π€good point π
Post by flames on May 12, 2021 18:57:00 GMT 1
My LC stem is 23cm long and pretty much sits flush in bottom of yoke.
Post by flames on May 12, 2021 19:01:58 GMT 1
I thought pv stem was same length as LC and they just swap over? Is the bottom yoke you are fitting thicker than LC/pv? Could be that more stem is in the yoke than if in PV one? Hi bud , yes it could be that !! I'll have a measure up π€π€good point π I never thought to measure how much sits in the yoke while I was out there..... will measure it in a bit if that helps?
