Post by russpuss on Jan 6, 2016 23:24:05 GMT 1
Probably been asked a thousand times, I need the info for white paint with blue stripes please, my painter does cars so any codes for him will help, is the black on the panels Matt / Satin/ Gloss and is everything lacquered afterwards? Going to get imageworks to supply and fit the decals so they should be ok?..
Post by russpuss on Jan 9, 2016 20:24:15 GMT 1
Anyone know?
Post by markhoopy on Jan 9, 2016 23:55:53 GMT 1
Post by LC_BOTT on Jan 11, 2016 8:55:37 GMT 1
Most people now seem to be moving away from 'original' white as it is slightly yellow or creamy, a good match is Ford 'diamond white' you see the difference when side by side, so depends if you want anorak finish or modern bright white (probably any modern white would do (vauxhall white has been mentioned as well, as it is quite bright)
Do you mean the black on the bottom side panels?? if so satin black done after the lacquer (I think), or a satin laquer?? but that's what I assume you're paying the painter for??
Post by russpuss on Jan 11, 2016 13:20:07 GMT 1
Most people now seem to be moving away from 'original' white as it is slightly yellow or creamy, a good match is Ford 'diamond white' you see the difference when side by side, so depends if you want anorak finish or modern bright white (probably any modern white would do (vauxhall white has been mentioned as well, as it is quite bright) Do you mean the black on the bottom side panels?? if so satin black done after the lacquer (I think), or a satin laquer?? but that's what I assume you're paying the painter for?? The guy paints cars, I need to tell him the finish I need, it's the bottom of the side panels, so I'll go a clean white with satin black bottoms and all decals lacquered. Sh1t or bust then eh?!
Post by 4l04ever on Jan 11, 2016 15:23:48 GMT 1
That sounds about right :-) Ford Diamond white is a little creamy, but not as magnolia as the original white used by Yamaha, so is a good compromise. I think it is Vauxhall Glacier White that is a very bright white.
Painting
Jan 11, 2016 17:44:20 GMT 1
via mobile
Post by midlifecrisisrd on Jan 11, 2016 17:44:20 GMT 1
I've hot a car painter to do a couple of ypvs body sets for me in straight white off the mixing station.
Basically it's the white with no tints added
URKI 900 is the code
Post by arrow on Jan 11, 2016 19:54:39 GMT 1
I had Peugeot Bianca white on my LC.
Painting
Jan 11, 2016 21:53:31 GMT 1
via mobile
Post by Delbert on Jan 11, 2016 21:53:31 GMT 1
I've hot a car painter to do a couple of ypvs body sets for me in straight white off the mixing station. Basically it's the white with no tints added URKI 900 is the code K Steve Same here with gloss black on the side panels ,, then decals fitted and all lacquered in ,, looks great I think
Post by russpuss on Feb 17, 2016 21:44:16 GMT 1
Well the car painter can't fit it in, so I've sent mine to Med's and just told him blue stripe on white, so will post the pics when it comes back.
Post by rsvr1000 on Feb 17, 2016 22:16:05 GMT 1
Well the car painter can't fit it in, so I've sent mine to Med's and just told him blue stripe on white, so will post the pics when it comes back. My set is first even thou you tried to smooth talk your way to the front of the line lol
Post by russpuss on Feb 17, 2016 22:19:24 GMT 1
Well the car painter can't fit it in, so I've sent mine to Med's and just told him blue stripe on white, so will post the pics when it comes back. My set is first even thou you tried to smooth talk your way to the front of the line lol He said he didn't like mars bar and mine was deffo 1st, I charmed the pants off him, think the blow up sheep helped though....
Post by rsvr1000 on Feb 17, 2016 22:52:08 GMT 1
