Post by rostrumorhospital on Sept 29, 2016 7:36:25 GMT 1
Thanks for the comments, I will have owned the bike for 3 years in November, knowing that I'm potentially only weeks away from starting the bike after so long working on it, the anticipation is definitely building. Just hope I haven't scudded myself by calling the build thread 'And so it starts' !
twostrokejoe - would be great to meet up with some of the forum members from this side of the pond (and any of the forum members that could make the trip over), the North West 200 would be an ideal place to do it p.s. that's an impressive list of bikes you've got.
Post by twostrokejoe on Sept 29, 2016 9:16:41 GMT 1
I run a race team (r6) so might have an entry for the NW next year. Just finished IOM Manx newcomers with top ten finish . No race plans as of yet. Had Vinny Brennan ride this year. Bought the r6 from Tim Martin. (Martrain) x Dean Harrison machine. Will be at several events north and south so just have to meet up.
Post by rostrumorhospital on Sept 29, 2016 9:28:11 GMT 1
Excellent finish at the IOM, good luck with the racing and will definitely keep an eye out for the team.
Post by rostrumorhospital on Sept 29, 2016 22:47:28 GMT 1
Got the clutch fitted, was waiting on 6 new clutch springs, all plates measured up well within spec but the springs were slightly short, just went for the gen Yamaha ones, kick start mechanisim fitted and side casing on.
Post by rostrumorhospital on Sept 29, 2016 22:50:27 GMT 1
not forgetting the shinny like new oil pump that arrow worked his magic on
Post by rostrumorhospital on Oct 7, 2016 20:50:01 GMT 1
got the top end painted and fitted, my mate came round and helped me with setting the ignition timing, using a DTI set to 1.8 BTDC. put the offset sprocket on along with the longer ypvs collar / spacer, not enough room for the locking washer but will hopefully be reducing the lenght of the collar to line up with the rear sprocket. Just the PWK carbs to go on and its back in the frame. Ive fitted the exhaust collars allong with the gaskets but now think this might hinder the engine goin into the frame. Big thanks to twostrokejoe for sorting me out with the wire clip for the stator cable, very much appreciated
Post by Tobyjugs on Oct 8, 2016 17:44:48 GMT 1
I had the same problem with the sprocket when i put my 4LO engine in my hybrid frame. My sprocket had two holes in it so i cut the locking tab so that two strips of the tab could be bent into the holes. For extra security i used loctite on the nut.
Post by rostrumorhospital on Oct 21, 2016 22:20:33 GMT 1
Finally the engine is in AND RUNNUNG!, have to admit I was quite pleased with myself when the engine fired up first kick, although to counteract that, the head gasket is weaping coolant from one of the bolt heads, there's always something! I stage torqued the head up to 25nm and have run the engine over 3 nights and re-torqued to 28nm but still weaping, its a pattern gasket that Ron supplied with the 370 top end, he assured me before i fitted it he has been using these with no issues, I'm now regretting not using some istant gasket as well. I have also got an issue with the kickstart hitting the footpeg which dusty had given me a heads up about, its also hitting the rear brake lever but on the plus side the engine sounds really crisp and the pipes do sound really well, tried to upload a vid but without success. have got the oil pump bleed, all systems go now to get it on the road
Post by yamark on Oct 22, 2016 8:10:11 GMT 1
Davey, awesome, just awesome. Your attention to detail and finish have made your bike into a show winner. My favourite part is the swing arm, probably the best I've seen. It just looks so right. If you went into production, you'd sell loads
Well done mate, fabulous bike, you should be very proud
ATB Mark
Post by rostrumorhospital on Oct 22, 2016 12:20:13 GMT 1
Kind words Mark, very much appreciated
Post by dusty350 on Oct 22, 2016 12:46:16 GMT 1
+1 on what Mark said That's a really lovely Lc hybrid. Well done on a great build ! Dusty
Post by rostrumorhospital on Oct 22, 2016 13:34:24 GMT 1
Cheers Dusty, cant wait to get her run in and see how it performs. Does your alloy kick start lever give more clearance to the brake lever and does a standard LC footrest have to be flicked up to clear the kick start.
Thanks Davey
Post by oldelsieboy on Oct 22, 2016 13:49:22 GMT 1
Finally the engine is in AND RUNNUNG!, have to admit I was quite pleased with myself when the engine fired up first kick, although to counteract that, the head gasket is weaping coolant from one of the bolt heads, there's always something! I stage torqued the head up to 25nm and have run the engine over 3 nights and re-torqued to 28nm but still weaping, its a pattern gasket that Ron supplied with the 370 top end, he assured me before i fitted it he has been using these with no issues, I'm now regretting not using some istant gasket as well. Checkout Daves (muttsnuts) advise in this thread rdlccrazy.proboards.com/thread/19909/cylinder-head-issueOEB
Post by stusco on Oct 22, 2016 14:20:08 GMT 1
Std lc footrest needs flicking up to clear the kick start The std lc brake pedal is well tucked in to keep it out the way Maybe a short alloy kickstart might help clear your brake pedal ,but it mine worse with tarrozi rearsets so I put the std footrests/hangers back on ,it's now a lot easier to kick when sitting on the bike
Post by rostrumorhospital on Oct 22, 2016 15:32:50 GMT 1
OEB - thanks for that link, will maybe drain the water and give it another nip up, 34NM seams to be the max you want to go to, but suspect it maybe be too late now that the water has breached the gasket.
Stusco - thanks for the info
Post by lcyoungboy on Oct 22, 2016 15:53:06 GMT 1
Any clips of it running Them rd250 stickers look very deceptive ha. I have some 370 1s I had made but never used em..if you want them just let me know and il pop em in the post for you. Dave
Post by rostrumorhospital on Oct 22, 2016 17:25:57 GMT 1
Any clips of it running Them rd250 stickers look very deceptive ha. I have some 370 1s I had made but never used em..if you want them just let me know and il pop em in the post for you. Dave Thanks for the offer but my 250 decals are lacquered over so stayin as a 250 cheers
Post by twostrokebrit on Oct 23, 2016 22:41:28 GMT 1
i used dowty sealing washers under the head nuts . worked like a charm
Post by rostrumorhospital on Nov 6, 2016 22:13:43 GMT 1
Had a bit of a result with the chain allighment, the runout between the front and back sprocket was less than 1mm, that was measured using my chaep lazer tool and double checked with a bit of string! I had previously removed 10mm off the rear sprocket carrier putting the chain in the center of the gap left between the edge of the tyre and the inside of the frame, that allong with the 5mm offset front sprocket and the longer YPVS collar has worked out spot on, i was expecting to have to adjust either the collar behind the front sprocket or the rear sprocket carrier, wonders will never cease! Got a piece of engineering nylon to make the chain sliders for the top / underside of the swingarm, my mate made a crackin job of the top slider, milling the slots for the chain to run, and i made the easier underside protector. gaps to the tyre edge and inside of frame look better than i was expecting considering i have a 150 rear tyre. Have made a 16 point list to sort out before its first outing and MOT
Post by yamanastic on Nov 7, 2016 1:20:47 GMT 1
Just seen your build thread don't know how I missed it, but the bike is looking brilliant and top class work you've done there. Who rebuilt your crank for you, was it someone local?
Post by rostrumorhospital on Nov 7, 2016 1:37:40 GMT 1
Just seen your build thread don't know how I missed it, but the bike is looking brilliant and top class work you've done there. Who rebuilt your crank for you, was it someone local? Thanks for the comments, Yes it was East End Motorcycles (John Borne) on the Newtownards Road that rebuilt the crank, Was recommended by a couple of people and was pleased with the sevice, seamed very knoledgeable
Post by yamanastic on Nov 7, 2016 12:33:00 GMT 1
Did you supply the parts or did they, I forgot about east end m/cycles they rebored my barrels a few years ago, not sure if he's still open as his business is up for sale and he's retiring.
Post by rostrumorhospital on Nov 7, 2016 15:57:51 GMT 1
Did you supply the parts or did they, I forgot about east end m/cycles they rebored my barrels a few years ago, not sure if he's still open as his business is up for sale and he's retiring. Have sent you a PM with the details of East End Motorcycles
Post by Dangerous on Nov 8, 2016 13:30:35 GMT 1
Post by yamark on Nov 8, 2016 19:07:02 GMT 1
Great work. That chain slider looks superb. I can't imagine what the 16 points on the list are
Post by rostrumorhospital on Nov 9, 2016 0:13:50 GMT 1
cheers mark, list getting shorter by the night, still to get new number plate and fit rear reflector, fit belly pan, possibly make chain guard although i believe it is not a requirement for the MOT, but probably advisable specially with the white wheels, fitted new petrol tap tonight, the other one broke the cast alloy when i tightened the bolts! also one of the exhaust springs was rubbing on the underside of the radiator, got that sortd bt removing the spring loop and re welding further round the pipe. Fitted a new head gasket with threebond applied this time, fingers crossed! Hopefully not to far away from her maiden voyage
Post by dusty350 on Nov 9, 2016 7:37:33 GMT 1
Hi Looking fantastic mate I echo Marks thoughts on that chain slider. Perhaps you could send the design to Metmachex - it looks far better than their slider !! Keep going, nearly there. Regards Dusty
Post by rostrumorhospital on Nov 9, 2016 8:33:22 GMT 1
Thanks dusty,
Cant take the credit for the slider, was all my mates work, had asked him to mill the two slots in the top face for the chain to run in but it came back finished! After I drilled and tapped the 3 holes to fit it to the arm it was ridding up on a weld so marked the underside for a diagonal slot and my mate sorted that as well, surprising the amount of work in a wee job like that but have to admit was pleased with how it turned out. Its help like this, along with advice / guidance not to mention parts from forum members that have got me to the stage i'm at, Thanks to all that have taken an interest and helped me in my build, Its very much appreciated.
Post by yamark on Nov 10, 2016 19:14:30 GMT 1
Hi Looking fantastic mate I echo Marks thoughts on that chain slider. Perhaps you could send the design to Metmachex - it looks far better than their slider !! Keep going, nearly there. Regards Dusty I remember that chain slider from Metmachex Dusty. It looked like someone had taken an axe to a plastic chopping board
Post by lrcarl on Nov 10, 2016 22:18:35 GMT 1
ATB Mark +1 looks the biz swinger looks so right on the bike carl
