Post by popeye69 on Feb 27, 2024 21:00:10 GMT 1
New bike. Cleaned carb bowls, sprayed carbs inside. Cleaned fuel tank tap and filter. Replaced front brake fluid. Got indicators working. Dirty Switch.
needs doing...
Look like needs a new battery. Whats best? Anyone gone Lithium?
New tyres.
Clean and lube chain.
Ready for spring, I hope.
1980 Rd350LC.
Post by urbantangleweed on Feb 27, 2024 21:30:32 GMT 1
New bike. Cleaned carb bowls, sprayed carbs inside. Cleaned fuel tank tap and filter. Replaced front brake fluid. Got indicators working. Dirty Switch. needs doing... Look like needs a new battery. Whats best? Anyone gone Lithium? New tyres. Clean and lube chain. Ready for spring, I hope. 1980 Rd350LC. Battery wise, I stick with good old Yuasa lead acid these days. I've tried the Motobatts etc. but old skool seems to be the way to me. Be careful with lithium, many of the old fashioned reg/recs don't know what it is and that might not work out well. They're a bit of a worry to charge too from what I understand, best off with a long extension cable and do it at the bottom of your garden away from trees or anything else combustible.
Post by urbantangleweed on Feb 29, 2024 15:22:50 GMT 1
Just picked up this lovely little lot from the powdercoaters 😊
Post by fletche36 on Feb 29, 2024 16:26:42 GMT 1
Just picked up this lovely little lot from the powdercoaters 😊 What is the going rate for having a casing coated if you dont mind me asking? i may have a couple done myself and dont want fleecing. thanks.
Post by urbantangleweed on Feb 29, 2024 16:30:51 GMT 1
My chap does a great job and is very reasonable on price, that little bundle of joy he blasted, prepped and powdercoated for £45.
Post by fletche36 on Feb 29, 2024 16:47:16 GMT 1
My chap does a great job and is very reasonable on price, that little bundle of joy he blasted, prepped and powdercoated for £45. i could live with that. Thanks.
Post by urbantangleweed on Feb 29, 2024 16:49:46 GMT 1
My chap does a great job and is very reasonable on price, that little bundle of joy he blasted, prepped and powdercoated for £45. i could live with that. Thanks. You can't prep it and paint it yourself for that.....
tezrhc
Post by tezrhc on Feb 29, 2024 19:21:55 GMT 1
Fitting an R6 rad to the ypvs.
Post by urbantangleweed on Mar 3, 2024 11:44:42 GMT 1
Had a bit of tinker time this morning, she's starting to look rather lovely 🙂
Post by tippy on Mar 4, 2024 8:08:48 GMT 1
Fitting an R6 rad to the ypvs. How is that going with hoses and such? Are you running a standard head?
Post by Norbo on Mar 4, 2024 9:40:04 GMT 1
WOWOW THATS A STAY COOL RADIATOR
Post by fletche36 on Mar 5, 2024 19:16:45 GMT 1
productive day today. yesterday i cleaned up a pair of e bay special barrels that had about 3 coats of gloss paint on them, so today i painted them with simoniz tough satin which i know works well. Then i got a delivery from Norbo so i now have the required parts to make up another set of forks. A bonus( or maybe not) with the barrels is that they have been ported and it looks like an excellent job, certainly not a home done one.These were going to be donor barrels if i ever went for a Fahron / mutts 370 job but i may have to test and see how they work as is although they do need a little more cleaning up on the bore yet. IMG_0216 by peter fletcher, on Flickr IMG_0229 by peter fletcher, on Flickr IMG_0226 by peter fletcher, on Flickr
tezrhc
Post by tezrhc on Mar 5, 2024 20:27:31 GMT 1
Fitting an R6 rad to the ypvs. How is that going with hoses and such? Are you running a standard head? I’ve got a Pro Design cool head to go on it, haven’t looked at hoses yet, blocked off lower outlet as well. I’m waiting for the top crankcase to come back from powder coating then I can assemble the engine.
Post by mouse on Mar 11, 2024 9:22:31 GMT 1
For the first time since registering them as historic vehicles, i taxed two of my LC's for free!
Which was nice!
Mouse
Post by headcoats on Mar 11, 2024 10:35:08 GMT 1
For the first time since registering them as historic vehicles, i taxed two of my LC's for free! Which was nice! Mouse Just did the same on the red LC 🤗 Got to wait till April for the yellow one 💛
Post by sidney81 on Mar 16, 2024 20:22:04 GMT 1
Had the LC out for the first time this year after a few mods and tweets ,she's going fantastic 😊
tezrhc
Post by tezrhc on Mar 17, 2024 19:08:22 GMT 1
One of the lugs was missing from the centre tail piece so I’ve had a go at repairing it. Put some filler around the good one to make a mould, used Plastex to make a lug, drilled a hole in each part and used a piece of wire to hold in place while I bridged the gap.
downsy
Post by downsy on Mar 17, 2024 23:27:56 GMT 1
Removed engine 👍
Post by 84rzrider on Mar 18, 2024 1:08:12 GMT 1
Took the white 84 RZ350 out for the 1st time in three months. Noticed instrument lights on the Koso flickering and turn signals coming on but not flashing. Switched to the voltage screen. Read 9.6 so I took it back to the shop. The 8 year old Moto-Batt battery showed a full charge after only 10 minutes on the trickle charger but dropped to 9 volts as soon as the ignition was turned on. I went to O'Reillys auto parts and got a slightly shorter slightly wider power sport battery like I put in the Gray Ghost RZ. 12.75 volts, jumped to 13.6 when I blipped the throttle. I filled in the space in the battery box with some foam and all is well again.
tezrhc
Post by tezrhc on Mar 23, 2024 20:14:52 GMT 1
Removed stickers from side panel and then removed the sticky residue that was left.
tezrhc
Post by tezrhc on Mar 23, 2024 20:21:35 GMT 1
Primed tank and tried the rear centre panel I repaired earlier making sure it fits.
Post by robin on Mar 23, 2024 20:52:28 GMT 1
Fresh engine oil, Drained and flushed the coolant, bled the front and rear brakes, just got to clean and re-oil the air filter and its all done for the riding season
Post by arrdy350 on Mar 25, 2024 22:29:35 GMT 1
I got my F1 started for the first time this evening ( for about a min because it leaked out of the over flows ☹) So Carbs off again 🤬 I don't know what would of caused it as everthing was set up right and cleaned 🤷♂️
Post by derek500 on Mar 26, 2024 14:43:26 GMT 1
Today I arve mostly been spray painting my 350F2 front mudguard and top fairing
Post by jessy03 on Mar 27, 2024 21:03:47 GMT 1
Dragged the LC out and started her up, sounded angry, took her for some fresh fuel. Also finished off a spare Ypvs engine.
Post by sidney81 on Mar 28, 2024 20:19:16 GMT 1
Post by docmartin on Apr 2, 2024 8:13:37 GMT 1
Sunday, got her out from winter hibernation.
Went for a gentle run until got some heat in her, then a good run….
Always amazes me when other bikers make a big effort when they see an LC.
An hour of fun and shenanigans was had.
Post by Jona on Apr 2, 2024 17:34:08 GMT 1
Post by mouse on Apr 4, 2024 9:59:48 GMT 1
Took my 31k's logbook to the post office to register it as 'historic', so no more road tax or MOT's.
That will be all three LC's registered as 'historic' now, YES!
Mouse
