Post by tacky1 on Jan 28, 2024 3:54:02 GMT 1
I’m in the middle of a GSXR1100 (1127) build. Picked up a set of bandit 1200 cylinders and gen1 Hayabusa pistons and sent them out to be bored. That’ll give it 1216 build with low compression. APE stud and nuts. APE valve springs and retainers. Have the turbo kit bought and ready to go. Among for around 300hp @20psi.
Post by 4l04ever on Jan 28, 2024 9:46:53 GMT 1
I've been slowly building this bike up over the last 2 or 3 years It's been made from all the old parts I got from two ex-racers. Lots of bits repaired and straightened. I got the chassis (not bent) from a Andy a forum member and a special cylinder head from Mutts. Any way I started it and too my surprise it started straight away. The carbs have got no idle option so it must be constantly feathered with the throttle to keep it running. I checked the engine temperature and measured 40 degrees on the top of the engine and 2 degrees at the entrance to the radiator. Bollocks it was going so good. Will start to check for the problem in a few weeks. What's with the rear tyre? Are you taking up off-road racing?
Post by Tobyjugs on Jan 28, 2024 10:46:15 GMT 1
I've been slowly building this bike up over the last 2 or 3 years It's been made from all the old parts I got from two ex-racers. Lots of bits repaired and straightened. I got the chassis (not bent) from a Andy a forum member and a special cylinder head from Mutts. Any way I started it and too my surprise it started straight away. The carbs have got no idle option so it must be constantly feathered with the throttle to keep it running. I checked the engine temperature and measured 40 degrees on the top of the engine and 2 degrees at the entrance to the radiator. Bollocks it was going so good. Will start to check for the problem in a few weeks. What's with the rear tyre? Are you taking up off-road racing? Just a spare rim and wheel to move the bike around. I've got some Heidenau tyres to use on it. It going to be my reserve track bike. First I need to find out why the water pump ain't working.
Post by jon on Jan 28, 2024 10:54:30 GMT 1
“First I need to find out why the water pump ain't working.”
The water wasn’t working properly on my 250LC. Turned out to be the impeller spinning on the splines of the shaft. Wonder if yours is the same?
Post by Tobyjugs on Jan 28, 2024 11:05:53 GMT 1
First I need to find out why the water pump ain't working.[/quote] The water wasn’t working properly on my 250LC. Turned out to be the impeller spinning on the splines of the shaft. Wonder if yours is the same? Jon [/quote] Yes this is my first thought as I have had it happen before. Easy to check just loosen the pump cover off.
Post by arrdy350 on Jan 28, 2024 20:27:25 GMT 1
Went to start my Tzr 125 a couple weeks ago but it wouldn't start. So took the carb off today and cleaned the jets and fitted a new float bowl gasket I brought from Yamaha. Put it back together and started first kick 😀 Tzr carb by
Post by tacky1 on Jan 28, 2024 20:58:59 GMT 1
“First I need to find out why the water pump ain't working.” The water wasn’t working properly on my 250LC. Turned out to be the impeller spinning on the splines of the shaft. Wonder if yours is the same? Jon This happened me as well. I tried everything. New head gasket. New rad even though the old one was clear. 😂👍
tezrhc
Post by tezrhc on Jan 28, 2024 22:04:25 GMT 1
Finished wiring, fitted wheel decals, not sure if I like them.
Post by donkeychomp on Jan 28, 2024 22:29:29 GMT 1
I'm sure you'll work it out mate.
Post by 4l04ever on Jan 29, 2024 20:58:56 GMT 1
Engineering club at school. Got the kids having a go at polishing some "random" items.
Post by sheep911uk on Jan 29, 2024 21:10:22 GMT 1
Engineering club at school. Got the kids having a go at polishing some "random" items. They will have something more exciting tomorrow !!!
dex46
Post by dex46 on Jan 30, 2024 20:02:43 GMT 1
IMG_2755 by Andy Dexter, on Flickr Fitted Ramair filters to Frenchy as it came with K&N type filters 🤦♂️ as I don’t have a Std airbox at the moment thought I would pull the carb’s apart at the same time to check what jets were fitted found 210s fitted 😳🤦♂️ no spare jets to hand so out with a 1.5mm drill to make a 300 jet 👍 22.5 pilot jet clip was in the middle so set that to Std 4th from top and repacked the allspeeds. Then out for a test ride runs a lot better pulls well from down below slight stutter around 5-5.5K pulls through ok but will see if I can iron it out
Post by 4l04ever on Jan 30, 2024 20:06:58 GMT 1
IMG_2755 by Andy Dexter, on Flickr Fitted Ramair filters to Frenchy as it came with K&N type filters 🤦♂️ as I don’t have a Std airbox at the moment thought I would pull the carb’s apart at the same time to check what jets were fitted found 210s fitted 😳🤦♂️ no spare jets to hand so out with a 1.5mm drill to make a 300 jet 👍 22.5 pilot jet clip was in the middle so set that to Std 4th from top and repacked the allspeeds. Then out for a test ride runs a lot better pulls well from down below slight stutter around 5-5.5K pulls through ok but will see if I can iron it out I like the idea of drilling the jets out, but you may need bigger. Check what other people are using on an LC with Ramair filters. Maybe 360 to 400.....
Post by 4l04ever on Jan 30, 2024 20:13:12 GMT 1
I’m in the middle of a GSXR1100 (1127) build. Picked up a set of bandit 1200 cylinders and gen1 Hayabusa pistons and sent them out to be bored. That’ll give it 1216 build with low compression. APE stud and nuts. APE valve springs and retainers. Have the turbo kit bought and ready to go. Among for around 300hp @20psi. Which Turbo kit? Fastbyme??
dex46
Post by dex46 on Jan 30, 2024 21:28:36 GMT 1
IMG_2755 by Andy Dexter, on Flickr Fitted Ramair filters to Frenchy as it came with K&N type filters 🤦♂️ as I don’t have a Std airbox at the moment thought I would pull the carb’s apart at the same time to check what jets were fitted found 210s fitted 😳🤦♂️ no spare jets to hand so out with a 1.5mm drill to make a 300 jet 👍 22.5 pilot jet clip was in the middle so set that to Std 4th from top and repacked the allspeeds. Then out for a test ride runs a lot better pulls well from down below slight stutter around 5-5.5K pulls through ok but will see if I can iron it out I like the idea of drilling the jets out, but you may need bigger. Check what other people are using on an LC with Ramair filters. Maybe 360 to 400..... Hi Rob Yeah it’s not the ideal way of jetting 🤣 but it works I roughly went 50% over standard jetting of 190 will plug chop it another day hopefully I will come across a standard airbox one on eBay at moment £160 starting bid 😳
Post by 4l04ever on Jan 30, 2024 21:39:56 GMT 1
Got an engine dropped off by sheep911uk for the School Engineering Club to sort out :-)
Post by masonmart on Jan 31, 2024 3:06:17 GMT 1
Love it dex.
Post by tacky1 on Feb 2, 2024 3:48:58 GMT 1
I’m in the middle of a GSXR1100 (1127) build. Picked up a set of bandit 1200 cylinders and gen1 Hayabusa pistons and sent them out to be bored. That’ll give it 1216 build with low compression. APE stud and nuts. APE valve springs and retainers. Have the turbo kit bought and ready to go. Among for around 300hp @20psi. Which Turbo kit? Fastbyme?? Went with a Proboost kit.
Post by Tobyjugs on Feb 2, 2024 11:38:33 GMT 1
“First I need to find out why the water pump ain't working.” The water wasn’t working properly on my 250LC. Turned out to be the impeller spinning on the splines of the shaft. Wonder if yours is the same? Jon Yes Jon the impeller is loose. Happy days easy fix. I'm glad it was nothing to do with the cylinder head. As you can see it's an aftermarket part. It's difficult to beat original spares unless you are heavily modifying your engine.
Post by jon on Feb 2, 2024 16:16:44 GMT 1
It’s a shit design. They should have moulded it around a hexagon rather than splines IMO.
It makes me wonder if the impellor is actually moulded around the splines shaft, or it’s heated up and pressed into the plastic? Any witness marks?
Post by Tobyjugs on Feb 2, 2024 17:18:04 GMT 1
It’s a shit design. They should have moulded it around a hexagon rather than splines IMO. It makes me wonder if the impellor is actually moulded around the splines shaft, or it’s heated up and pressed into the plastic? Any witness marks? Jon Yes witness marks on the inside of the steel cover. Not much as it didn't run long as i was monitoring the temperature with a Raytec. This one is threaded and came loose on the thread. Its now fitted with another old original impellor. All back together now. If the weather is not too shitty i might start it tomorrow. I need to make some better pictures of the pipes. They are noisy as bugger and look a bit like Allspeeds with JL cans. It makes me wonder if they are a hybrid pipe or original design?
fabiostar
the older i get the faster i was.
Post by fabiostar on Feb 2, 2024 21:32:23 GMT 1
Not my LC as its still in bits but my Aprilia Pegaso was sold and is of to a new home, replaced by a trumpet 675 street triple...
Post by mouse on Feb 7, 2024 17:15:50 GMT 1
Fitted some new ally chain adjusters to my hybrid. Mouse
tezrhc
Post by tezrhc on Feb 7, 2024 18:06:43 GMT 1
Fitted some new ally chain adjusters to my hybrid. Mouse They look good Mouse, are they RGV ? Wouldn’t mind some myself, who supplies them?
Post by donkeychomp on Feb 7, 2024 22:07:07 GMT 1
They are very neat indeed.
Post by mouse on Feb 8, 2024 8:18:02 GMT 1
Fitted some new ally chain adjusters to my hybrid. Mouse They look good Mouse, are they RGV ? Wouldn’t mind some myself, who supplies them? Hi, yes, they are for RGV VJ22 arms. As for who supplies them, afraid i cannot help, i bought them used from a guy on Fleabay, sorry. However check out NK racing, they also make Billet ally ones for RGV arms, which are very nice. Mouse
tezrhc
Post by tezrhc on Feb 8, 2024 10:21:19 GMT 1
They look good Mouse, are they RGV ? Wouldn’t mind some myself, who supplies them? Hi, yes, they are for RGV VJ22 arms. As for who supplies them, afraid i cannot help, i bought them used from a guy on Fleabay, sorry. However check out NK racing, they also make Billet ally ones for RGV arms, which are very nice. Mouse Cheers Mouse, I might get the original re plated.
Post by headcoats on Feb 8, 2024 16:40:51 GMT 1
I had the originals powdercoated,it held up fine
Post by andy748 on Feb 10, 2024 17:24:50 GMT 1
Finished my long rod bottom end off, new Banshee cover.
Post by andy748 on Feb 10, 2024 17:25:23 GMT 1
Clutch side, new oil pump cover.
