Post by marsbar350 on May 31, 2012 16:27:34 GMT 1
lookin good ken
Post by Deleted on May 31, 2012 22:14:17 GMT 1
thanks marsbar, ive spent that long thinking ,should i or shouldnt i,that it was driving me crazy,another thing, when you take a close up of things on the bike ,all of a sudden all these scratches you cant see with the naked eye turn up everywhere
Post by Deleted on May 31, 2012 23:30:07 GMT 1
ive been waiting for over 2 weeks now to get my new engine cases (THANKS MARSBAR 350) vapour blasted, as soon as thats done all i have to do is swap all the internals over,do timeing and oil pump (THANKS ARROW) hook up carbies and fine tune, sounds easy,if all goes well it will hopefully be a weekend job,if nothing elce it will LOOK finished lol, i cant wait to finish,its been going on now for 16 months
Post by marsbar350 on May 31, 2012 23:34:43 GMT 1
good luck with the rebuild ken i was pulling me hair out and it only took me 5 months
Post by Deleted on Jun 1, 2012 2:56:34 GMT 1
because im not very orginised, i would send an order off thinking i will have everything i need to finish a stage so i can move to the next bit,then find i overlooked one little bit and have to wait another 2 or 3 weeks for it,another thing that happened a couple of times i would wreck something and well another 2 or3 weeks,when the parts turns up ,its on in a matter of minutes and then its more waiting, the next one will be much easier because i know what to expect and have learnt so much,one other thing,my bike had parts from later a model that i only picked up when they wouldnt fit when i tried to use them with lc bits
Post by Deleted on Jun 4, 2012 5:01:15 GMT 1
Post by crash on Jun 4, 2012 9:51:27 GMT 1
wow !bling a ding ding
Post by marsbar350 on Jun 4, 2012 11:58:18 GMT 1
Post by Deleted on Jun 4, 2012 14:39:42 GMT 1
pulled the motor apart tonight and the 1st gudgen pin clip i removed dematerialed right before my very eyes and i bent another so i suppose i will have to wait another 2-3 weeks for them new ones to turn up, such is life, by the way im glad i had to pull it apart because 1 oil seal was in wrong, and 1 was missing altogether, and a couple of screws were lose, bugger me, if i had of got it going like it was i reckon its life expectancy would have been short....thanks fellas
Post by Norbo on Jun 6, 2012 12:26:04 GMT 1
Them casings a nd carbs look grate i love the look of vapour blasted alloy .
Post by Deleted on Jun 6, 2012 14:04:41 GMT 1
fhanks norbo, i polished the carb bowls ages ago but now they let the carbies down , i will take them off and do them [properly but having said thatthey look better in the hand, for some reason all my photos do is highlight faults.
Post by Deleted on Jun 8, 2012 1:50:52 GMT 1
most of the motor back in again, all going well should be done in a few weeks, been saying that for 3 months now
Post by rdorvfr on Jun 11, 2012 7:58:40 GMT 1
It's coming along Ken, not long now.
webbo
Post by webbo on Jun 13, 2012 20:37:09 GMT 1
Ken, How did you get that oil tank looking so clean? Like the carbs and cases. Just about to get mine done. ;D
Post by Fingermaus on Jun 13, 2012 22:35:15 GMT 1
Thats looking brilliant Ken, taking shape nicely.
Might be worth getting the bike parts in more light and photographing without a flash, I had the same problem with poor shots until I did this.
Post by Deleted on Jun 13, 2012 22:57:45 GMT 1
gday webbo- the oil tank wasnt to bad,from memory i just used a scotch brite and dish washing detergent fingers- good idea,i will give it a go, i look at it and think it looks good then the photos let it down see ya ,ken
Post by Deleted on Jun 16, 2012 21:47:26 GMT 1
a bit more done, all light etc working,cant believe it,
Post by lb on Jun 17, 2012 8:38:27 GMT 1
Lookin good Ken,also good to put a face to the name Btw,you wouldn't know where I could find a good LC tank by chance? a bit more done, all light etc working,cant believe it,
Post by Deleted on Jun 17, 2012 11:15:42 GMT 1
gday lb, sorry cant help you with a tank, i got a spare a couple of months ago and when i put a bit of weight into undoing the fuel tap the bottom caved in , it happens, finally got the bike finished, but i couldnt start it, didnt seen like it was getting any spark, , leaking head gasket, one carby leaking, but that was just a lose bowl drain screw, when set the air mixture screws i forgot to wind them out 11/2 turns, it was getting dark so i brought it in ,drained the rad tank and will check a few things tomorrow,any ideas on the leaking head gasket? its a yam one so i may need some sealant, any advice on how much sealant and where would be much appeciated, at least my young fella said it looks good,lol
Post by crash on Jun 17, 2012 15:14:16 GMT 1
take the head off then cover the head gasket with vasoline both sides ,refit head gasket then when you start it up again and warm it up it will fry its self together and the seal will be superb!
Post by Deleted on Jun 22, 2012 8:06:23 GMT 1
gday, well bugga me, it goes, it wont idle but fairly smooth around 2-3000 RPM, any advice on where to look to solve idol problem appeciated, it starts 1st kick and running on both cylinders if thats any help,thanks
Post by Deleted on Jun 24, 2012 14:48:32 GMT 1
well i got it to idle today, and went for a ride, the clutch is too heavy to be comfortable over any longer period of time, it has a rattle from the front end i think which disappers over 2 thou,feels like the barrells are fighting each other,, any thoughts on that welcome, gears change smooth but nuetral hard to find when engine running, easy when turned off,cant wait to take it into the higher rev range but for now am content to try and sort out the little bugs, once again , any suggestions / thoughts welcome. ken
Post by rdorvfr on Jul 15, 2012 3:23:34 GMT 1
Im no expert, maybe go back and re-check carby balance first.
Post by Deleted on Jul 15, 2012 10:36:52 GMT 1
hi, i did the carby balancing with the lolly pop method, was surprised how easy it was after i got the sticks the right length,will recheck timing and play with carbies, will pull the clutch cover when my new springs turn up, going to put heavier oil in the gear box as per arrows suggestion, fingers crossed
Post by rdorvfr on Jul 18, 2012 3:24:26 GMT 1
Looking forward to hearing how it goes.
