Post by mellow on Nov 8, 2006 23:39:14 GMT 1
first off u need to set the throttle stop screws while the carbs are off exactly the same. use a 4mm drill bit or 4 mm allen key so that it just slides under the slide. then fit carbs and do ur lolly stick bit
zebrd
Time for Bed!!
Post by zebrd on Nov 9, 2006 0:00:08 GMT 1
first off u need to set the throttle stop screws while the carbs are off exactly the same. use a 4mm drill bit or 4 mm allen key so that it just slides under the slide. then fit carbs and do ur lolly stick bit Aha!!!! Thank you Mellow. Will do that tomorrow night.
Post by mellow on Nov 9, 2006 0:01:55 GMT 1
ur welcome
Post by rufarse on Nov 9, 2006 0:11:50 GMT 1
Hey Mellow Cheers for the help mucker. BTW When Zeb says "I" he actually means me not him!!!!!!!!!!!! he stands and watches!
Post by mellow on Nov 9, 2006 0:14:16 GMT 1
;D hope he makes u loads of cups of tea then
Post by rufarse on Nov 9, 2006 0:15:01 GMT 1
one more for ya Mellow (and others)
pg 155 of haynes, pic 23.3 - is that what you're referring to?
Post by mellow on Nov 9, 2006 0:19:07 GMT 1
thats the throttle cable ?
Post by mellow on Nov 11, 2006 22:37:30 GMT 1
well.....................how u doin is it running?
zebrd
Time for Bed!!
Post by zebrd on Nov 14, 2006 23:22:03 GMT 1
First of all the carbs have been balanced. The Radiator is on now and connected. I have a problem though. The battery may be dead but Ive charged it and put it on the bike, the bike is dead the powervalves dont turn. Ive put the spark plugs in the ht leads to check for a spark and there is nothing. Majority of the wiring is connected, the only ones that we can see that arent are the front indicators and headlight. I do have another brand new battery but I havent filled it and charged it yet. That will be done at the weekend. So I can try out this new battery, but I dont think its the battery. Im sure I read somewhere that you should still get a spark at the plugs even if the battery is dead. (I might be wrong though) Any ideas peeps? Mellow I like the new avatar.......poser. ;D
Post by mellow on Nov 14, 2006 23:23:50 GMT 1
is the kill switch wirin plugged in? goes up with headlight loom
zebrd
Time for Bed!!
Post by zebrd on Nov 14, 2006 23:25:00 GMT 1
I think it is, I will check in a minute.
Post by mellow on Nov 14, 2006 23:26:18 GMT 1
aint it dark there or u got it indoors ;D
zebrd
Time for Bed!!
Post by zebrd on Nov 14, 2006 23:27:06 GMT 1
Its in the master bedroom, centre stage. ;D
Back in a mo.
Post by pablo on Nov 14, 2006 23:32:14 GMT 1
Its in the master bedroom, centre stage. ;D Back in a mo. you can get a spark with no battery if you kick it i think...plug all your wires in zeb
zebrd
Time for Bed!!
Post by zebrd on Nov 14, 2006 23:34:10 GMT 1
The kill switch is wired up.
Pabs, only the headlight and front indicators aint wired up, surely they wont affect me getting a spark?
All the wiring will be finished tomorrow night.
Post by mellow on Nov 14, 2006 23:34:31 GMT 1
u did put the little black earth wire back on near the servo motor/coil area?
zebrd
Time for Bed!!
Post by zebrd on Nov 14, 2006 23:36:16 GMT 1
I think we have but where abouts do you mean on the bike?
Post by pablo on Nov 14, 2006 23:36:43 GMT 1
The kill switch is wired up. Pabs, only the headlight and front indicators aint wired up, surely they wont affect me getting a spark? i wouldnt think so if all the big blocks are plugged in ...hmmm
Post by mellow on Nov 14, 2006 23:37:47 GMT 1
its got a ring connector on it..........in loom just in front of all the stuff under the tank. bolts onto servo mount or where coils mount
zebrd
Time for Bed!!
Post by zebrd on Nov 14, 2006 23:40:03 GMT 1
My tea is ready. I will just go and scoff it and have a look mellow.
Pabs all the block connectors are connected.
Be right back in 10 minutes
Post by vin on Nov 14, 2006 23:41:33 GMT 1
crumble for afters
Post by mellow on Nov 14, 2006 23:43:21 GMT 1
im just off for frosties but tea at this time of night
Post by pablo on Nov 14, 2006 23:43:59 GMT 1
My tea is ready. I will just go and scoff it and have a look mellow. Pabs all the block connectors are connected. Be right back in 10 minutes its not that poxy sidestand cut-out thingy is it?
Post by mellow on Nov 14, 2006 23:46:06 GMT 1
put ur sidestand up.my switch stuck where it hadnt been used.good thought pabs ur thread wreckin goonbag ;D
Post by vin on Nov 14, 2006 23:46:07 GMT 1
I think it should still start without this connected just when you put it into gear it then cuts out
Post by mellow on Nov 14, 2006 23:48:41 GMT 1
yup the likkle blue wire on neutral switch earths it out when stand switch is out/down
Post by pablo on Nov 14, 2006 23:48:42 GMT 1
dunno for sure...big chris had trouble with his...theres summit on the clutch as well aint there?
Post by mellow on Nov 14, 2006 23:50:07 GMT 1
nope
zebrd
Time for Bed!!
Post by zebrd on Nov 15, 2006 0:20:24 GMT 1
previous owner butchered the sidestand switch to high heaven (no surprise there!) and the bike was running fine without it. Here's some piccies, others are under s72.photobucket.com/albums/i175/rufarse/?sc=1&addtype=localThis is the bit we're on about with the confusion There's a yellow/black wire which currently connects to a yellow/green wire, but there's a yellow/black attached to nothing. Also as you can see in the picture, there's a dark blue wire doing naff all on it's own, with nothing attached. From looking at the wiring diagram the sidestand control is skyblue? Also Mellow, black wire you were on about, is it the one on the right hand side of the bike resting over the frame?
Post by mellow on Nov 15, 2006 17:02:07 GMT 1
right zeb me ol mucker................... the yellow/black yellow/green wires are for the indicators.if u have a indicator cancelling unit u connect the yellow/black to the yellow/green if u do not have the cancelling unit u connect the yellow/blacks together the black wire...................that dont look like it to me m8 from here it should come out of the main loom roughly by the servo for the powervalves and have a loop connector on it so a bolt can go through it. the blue wire im pretty sure should b connected to summin......check the loom that comes from the alternator....shoud b a blue connector there sumwhere
