Post by noonster on Jun 19, 2021 16:04:47 GMT 1
having trouble when i stop on my rd350lc, cant get from 1st and into neutral
gears through the gears no probs
i have found when removing the stargear that it as some sharpe edges around the neutral position tooth
should i buy the buy the pro star kit of norbo but still use the original stiff spring, or use the light way spring
or just use a dremmel to clean up the edges on the neutral tooth them put back together
Post by bare on Jun 19, 2021 18:16:00 GMT 1
Star isn't the usual issue. Easiest to try the Oil 'fix' first. I use GL4 gear oil. Eliminated my Finding 1st issues.. entirely. Worth a try?
Cobble up a small Jig. Basically a pivot pin for the Star so you can rotate it uniformly against a grinder wheel.. To ensure all star points get equally flattened, then carefully grind/ polish those flats into smooth rounds. Not rocket science .. just work.. IMO 'upgrading' the follower bearing is more self indulgence than useful.
ajh
Post by ajh on Jun 19, 2021 19:21:04 GMT 1
Post by headcoats on Jun 19, 2021 19:56:53 GMT 1
Dropping from 2nd to neutral just before you stop helps alot
