Post by seanclarky on Mar 13, 2021 0:46:29 GMT 1
Hi guys has anyone used the YSS uprated fork springs for a 4L0? They are 525mm long whereas standard is 495mm. It’s possible to fit them but it’s a struggle. I’m just wondering if they’ve sent me the wrong ones or are they supposed to be that long?
Post by jon on Mar 13, 2021 9:30:02 GMT 1
I can’t remember how long the preload spacer is (or indeed if an LC has them?), but from memory my Hagon springs for a YPVS did away with the preload spacer as they were longer.
Post by earthman on Mar 13, 2021 20:31:32 GMT 1
I know that the Hagon springs are a fair bit longer than what came out of mine, can't remember the actual measurments now.
Post by seanclarky on Mar 13, 2021 22:20:16 GMT 1
I know that the Hagon springs are a fair bit longer than what came out of mine, can't remember the actual measurments now. Yep that’s what I’m thinking, these uprated springs are longer than standard, I’ll give them a try cheers
Post by barnowl on Apr 7, 2023 8:56:59 GMT 1
Hi seanclarky - resurrecting this old thread. I was hoping to know how you got on fitting the YSS springs. I’m trying to fit them to my LC, but they seem too long and compressing them to get the top plug in is a struggle. They sit a good few inches above the Stanchions. Any help appreciated.
Post by Tobyjugs on Apr 7, 2023 9:03:58 GMT 1
Post by seanclarky on May 4, 2023 11:55:10 GMT 1
Hi sorry I've just seen this, yes the YSS springs are longer and a struggle to get the caps on. But I managed it with the help of a mate compressing while I fitted the clip. They made a big difference to the front end and firmed it up alot. I would recommend fitting them, cheers
Post by stanlc7189 on May 4, 2023 13:23:02 GMT 1
I used the method listed in a previous thread with a vice and 2-legged puller. Makes the job of fitting the YSS springs an absolute doddle. Great tip that.
Post by stanlc7189 on May 4, 2023 13:24:39 GMT 1
