Post by steveb64 on Mar 29, 2023 11:13:26 GMT 1
Has anyone got any tricks to get the spring retaining plug back in and the clip in place. I seem to need more hands than the two I have,
hopefully there is a neat trick or someone who can point out my stupidity!!
Post by lcmarky on Mar 29, 2023 11:22:44 GMT 1
block of wood on your chest and another perpendicular piece to push it down will give you 2 hands to use..
Post by JonW on Mar 29, 2023 12:40:04 GMT 1
I fit a top triple clamp bolted to the fork and use a socket on the cap and a bar thru the bar clamp to push the cap in.
Post by elsiefan on Mar 29, 2023 13:08:55 GMT 1
Post by chrisg on Mar 29, 2023 14:11:27 GMT 1
I like the vice and 2 leg puller. So simple but effective.
Post by tdrpete on Mar 29, 2023 14:24:55 GMT 1
I use a large philips screwdriver or a suitable type punch to depress the fork leg and drop the clip into the grove. Can be tricky but is manageable. It is a little bit harder to do with hagon progressive springs. But keep at it you will get it and if you are finding it difficult get a spare pair of hands.
Post by elsiefan on Mar 29, 2023 14:34:49 GMT 1
I like the vice and 2 leg puller. So simple but effective. So did I, but not having a 2 leg puller I had to improvise.
Post by tdrpete on Mar 29, 2023 14:48:45 GMT 1
You gotta make do with what you got, i didnt have a vice at the time either but a great idea nonetheless.
Post by steveb64 on Mar 30, 2023 9:08:25 GMT 1
Thanks for all the help the two leg puller is a great idea.
Post by beardy on Mar 30, 2023 9:59:15 GMT 1
Put the fork leg back into the lower yoke and raise it halfway up between the top yoke. Then get some threaded bar and large washers and nuts and put them through the top yoke and wind down onto the plug 👍🏻
Post by JonW on Mar 31, 2023 1:05:56 GMT 1
Put the fork leg back into the lower yoke and raise it halfway up between the top yoke. Then get some threaded bar and large washers and nuts and put them through the top yoke and wind down onto the plug 👍🏻 Thats a great solution! Two legged puller is good too, but i hate gripping chrome legs in a vice, even if using soft jaws...
Post by midlifecrisisrd on Mar 31, 2023 12:29:16 GMT 1
Piece of piss with a hydraulic press 😁
Don't know how I built bikes before all this machinery 🤣
Post by tdrpete on Mar 31, 2023 13:18:02 GMT 1
Piece of piss with a hydraulic press 😁 Don't know how I built bikes before all this machinery 🤣 Steve With a blue cantilever tool box no doubt.
Post by Chewie01 on Mar 31, 2023 13:50:41 GMT 1
I did my F2 last weekend and just used a vice with a couple of bits of wood to hold the fork leg, then used a big flat bladded screwdriver to push the plug in and a terminal screwdriver to get the clip in place. It was a bit of a struggle session but I thought it was easier to get the clips in than get them out.
Post by midlifecrisisrd on Mar 31, 2023 15:20:37 GMT 1
Piece of piss with a hydraulic press 😁 Don't know how I built bikes before all this machinery 🤣 Steve With a blue cantilever tool box no doubt. Still got one lurking in a cupboard lol Steve
