Flywheel
Feb 5, 2021 16:19:55 GMT 1
via mobile
Post by greeny on Feb 5, 2021 16:19:55 GMT 1
Hi all. Quick question.. What would cause the nut holding flywheel on to come loose and flywheel to then come adrift and clunk and misfire.. Wierd one.... Thanks in advance..
Post by 29davyt on Feb 5, 2021 16:28:09 GMT 1
Post by julianboolean on Feb 5, 2021 17:04:38 GMT 1
Worn taper either on the flywheel or crank, I had a KE125 do this, a new flywheel sorted the problem
Post by carioca656 on Feb 5, 2021 20:19:30 GMT 1
try lapping flywheel onto taper with some grinding paste then clean it off HTH
adie
Flywheel
Feb 6, 2021 1:31:02 GMT 1
via mobile
Post by greeny on Feb 6, 2021 1:31:02 GMT 1
Cheers guys... Best wishes
Post by pdxjim on Feb 6, 2021 2:15:08 GMT 1
Mine came loose a few months ago.
Made a hell of a racket and I was sure something internal was well fcuked.
I lapped the taper well, put a small smear of blue Loctite on the taper, and a bit on the crank threads.
Then put the bike in a high gear and cranked the nut down with a plug-in electric rattle gun.
That fcuker is not coming loose again.
Post by steeley on Feb 6, 2021 7:59:36 GMT 1
Mine came loose a few months ago. Made a hell of a racket and I was sure something internal was well fcuked. I lapped the taper well, put a small smear of blue Loctite on the taper, and a bit on the crank threads. Then put the bike in a high gear and cranked the nut down with a plug-in electric rattle gun. That fcuker is not coming loose again. Hmmm ,that's all well and good till the next time the Rotor needs to come off . Had trouble with one of my LC rotors years ago, an engineer friend said take the rotor off and check the inside taper and any obvious roughness smooth out with a home made arbour /6mm bar with a slot cut in the end with emery paper wrapped round and a drill . Don't go mad ,and then lap the rotor on the shaft with grinding paste . I marked the back plate and took the windings off it was easy to clean the paste off the shaft .
Post by JonW on Feb 10, 2021 23:55:16 GMT 1
Always... and I mean, every time... lap the flywheel with grinding paste. Ive had one spark and weld on when it wasnt perfectly fitted. It eroded the taper and was very hard to get off.
