Post by flames on Aug 1, 2020 14:19:46 GMT 1
Agree with arrow, you need a cross hatch pattern. Spirit of salts look like they done a good job.
I won't be using 3 litres....... unless motor really pee'd me of, then I might wash the bike in it to teach it a lesson.😖
Post by marrcel on Aug 1, 2020 16:42:34 GMT 1
Spirits of salt is acid to dissolve scale. And rust from a tank. Aluminum dissolves with soda na2co3 And with caustic soda its more powerful. I
Post by midlifecrisisrd on Aug 1, 2020 16:50:56 GMT 1
Was trying to post earlier but was getting bombarded by pop ups so gave up
Was going to say oil the stones and run it in and out quickly with the drill at quite a low speed to get the cross hatch pattern
They work on a fresh ish bore but not so good on slightly worn
On a worn ypvs barrel it wouldn't touch the 10mm bit above the exhaust port
Damn it!
Aug 1, 2020 16:53:44 GMT 1
via mobile
Post by flames on Aug 1, 2020 16:53:44 GMT 1
Spirits of salt is acid to dissolve scale. And rust from a tank. Aluminum dissolves with soda na2co3 And with caustic soda its more powerful. I So I can put it in a tank to dissolve rust? Does it go in neat? Or will it work if I water it down?
tlmark
Damn it!
Aug 1, 2020 17:30:42 GMT 1
via mobile
Post by tlmark on Aug 1, 2020 17:30:42 GMT 1
Agreed about the cross hatch pattern I did try to add some with a oiled scotchbright pad it worked quite well. Have to say I was peeved that Athena don’t include a gasket for the rear water hose to head connection what’s that all about? Top end is all built up now. I’ll finish off tomorrow, as it was bloody hot in our garage this afternoon.
tlmark
Damn it!
Aug 2, 2020 11:46:44 GMT 1
via mobile
Post by tlmark on Aug 2, 2020 11:46:44 GMT 1
She’s all finished started 3rd kick. Oil pump stroke, I don’t remember setting when I restored her I don’t know why I guess in the excitement I forgot. When I checked it it was not at .010 thou and it took some searching to find a small washer I could use as the start point and then add some of the factory shims To get it right.
I did also put LC pistons in this time, when it was rebored it came with YPVS pistons both Mikita ones 1.25 oversize but I thought I’d put LC ones as I had the choice.
Not ridden it yet WSBK and F1 on TV so it’ll have to wait for now
Post by stusco on Aug 2, 2020 11:50:04 GMT 1
Spirits of salt is acid to dissolve scale. And rust from a tank. Aluminum dissolves with soda na2co3 And with caustic soda its more powerful. I Spirit of salts worked for me only took a few minutes
Post by arrow on Aug 2, 2020 11:55:51 GMT 1
Lol Mark, 0.01 thou is 1/100 of a thou! If it is 10 thou now then happy days. Enjoy your bike.
Post by marrcel on Aug 2, 2020 12:28:15 GMT 1
Spirits of salt is acid to dissolve scale. And rust from a tank. Aluminum dissolves with soda na2co3 And with caustic soda its more powerful. I Spirit of salts worked for me only took a few minutes Just curious if the steel lining didn’t corode.
Post by stusco on Aug 2, 2020 12:34:33 GMT 1
It never even marked the liner but i was careful just dabbed some on with a cotton bud then wiped off when bubbled
tlmark
Post by tlmark on Aug 2, 2020 12:50:07 GMT 1
It never even marked the liner but i was careful just dabbed some on with a cotton bud then wiped off when bubbled Yup I copied you process it only fizzed on what looked like piston Remnants.
