Post by arrow on Jul 27, 2020 18:29:18 GMT 1
What ever method is used to clean and check the oil passage way in both carbs it matters not. As long as its thorough and complete.
Damn it!
Jul 27, 2020 18:46:16 GMT 1
via mobile
Post by flames on Jul 27, 2020 18:46:16 GMT 1
What ever method is used to clean and check the oil passage way in both carbs it matters not. As long as its thorough and complete. Ever thought of expanding into carb refurbs Gary? π
Post by tony2stroke on Jul 27, 2020 18:50:52 GMT 1
What ever method is used to clean and check the oil passage way in both carbs it matters not. As long as its thorough and complete. Ever thought of expanding into carb refurbs Gary? π That's Muttnuts territory, and does a good cheap job too
Post by arrow on Jul 27, 2020 18:57:02 GMT 1
Ever thought of expanding into carb refurbs Gary? π That's Muttnuts territory, and does a good cheap job too Correct.
Damn it!
Jul 27, 2020 18:58:54 GMT 1
via mobile
Post by flames on Jul 27, 2020 18:58:54 GMT 1
Cool. Didn't know anyone on here did them. He might be getting some more to do in the not too distant future.π
neil
my 125
Post by neil on Jul 27, 2020 19:03:24 GMT 1
It's good you found something obvious.π
Post by tony2stroke on Jul 27, 2020 20:56:31 GMT 1
Cool. Didn't know anyone on here did them. He might be getting some more to do in the not too distant future.π Never seen a complaint about Muttsnuts work on here, or Arrow for that matter, I think your in safe hands with either doing work on your precious bike bits.
Post by flames on Jul 27, 2020 21:57:25 GMT 1
Cool. Didn't know anyone on here did them. He might be getting some more to do in the not too distant future.π Never seen a complaint about Muttsnuts work on here, or Arrow for that matter, I think your in safe hands with either doing work on your precious bike bits. Ive seen from muttsNutts posts that he knows his stuff. Arrow rebuilt a pump for me a few years ago, I still can't get over what an amazing job he done. It was like he sent me a brand new one back.
Post by marrcel on Jul 27, 2020 22:43:28 GMT 1
Can it be crap from a previous oil change? Never thought about cleaning these spiggots.
Post by arrow on Jul 27, 2020 23:05:17 GMT 1
Can it be crap from a previous oil change? Never thought about cleaning these spiggots. Its the drillings in the carb that get blocked up. The final exit hole is tiny. Mine were blocked up by media from the cleaning process. I guess it can also be an age thing. We all know how the fixed air jet can get blocked up.
tlmark
Damn it!
Jul 28, 2020 10:52:04 GMT 1
via mobile
Post by tlmark on Jul 28, 2020 10:52:04 GMT 1
Just finished hot soapy water flush. Seem perfect now π€π»
I would definitely recommend the syringe and short length of tubing to check and flush the oil way clean
New pistons on order so just clean up the bore And go again π
Post by arrow on Jul 28, 2020 11:28:18 GMT 1
Just finished hot soapy water flush. Seem perfect now π€π» I would definitely recommend the syringe and short length of tubing to check and flush the oil way clean New pistons on order so just clean up the bore And go again π And set oil pump to 10 thou minimum stroke.
Post by tony2stroke on Jul 28, 2020 11:40:44 GMT 1
I hope that's the end of your problem.
Post by beardy on Jul 28, 2020 14:12:42 GMT 1
Glad youβve gotten to the bottom of it. I know what Iβll be checking soon along with a few other forum members too.
tlmark
Post by tlmark on Jul 30, 2020 12:31:51 GMT 1
New pistons came today and a honing tool is coming tomorrow Bit of luck and it might be back on the road over the weekend
Post by stusco on Jul 30, 2020 14:03:33 GMT 1
I used spirit of salts (drain cleaner )to dissolve the smeared aluminium,i just dabbed it on with a cotton bud and watched It bubble then washed off .
Post by shaunthe2nd on Jul 30, 2020 14:14:18 GMT 1
Sorry you had to experience this but appreciate you sharing it. Hope you are back on the road soon.
Damn it!
Jul 30, 2020 17:57:57 GMT 1
via mobile
Post by flames on Jul 30, 2020 17:57:57 GMT 1
I used spirit of salts (drain cleaner )to dissolve the smeared aluminium,i just dabbed it on with a cotton bud and watched It bubble then washed off . Did you have to do anything else in particular? I have some barrels I need to get fit. Not sure I can get away without a re bore but want to try as they are +1.75 already but they are tuned and went very well before I messed with it.π
Damn it!
Jul 30, 2020 18:00:37 GMT 1
via mobile
Post by flames on Jul 30, 2020 18:00:37 GMT 1
New pistons came today and a honing tool is coming tomorrow Bit of luck and it might be back on the road over the weekend What sort of honing tool did u get? I was looking to get one a while ago and was advised to get the ones with the stone balls as the ones with 3 bars can catch in the ports if not careful.
Post by stusco on Jul 30, 2020 18:23:29 GMT 1
I used spirit of salts (drain cleaner )to dissolve the smeared aluminium,i just dabbed it on with a cotton bud and watched It bubble then washed off . Did you have to do anything else in particular? I have some barrels I need to get fit. Not sure I can get away without a re bore but want to try as they are +1.75 already but they are tuned and went very well before I messed with it.π On mine there were no scores so once the acid had done its stuff i rinsed them thoroughly sprayed with wd it completely removed the aluminium but the smear wasnβt serious,ive done about 1000 miles since with no probs just do a little bit at a time
Damn it!
Jul 30, 2020 18:41:16 GMT 1
via mobile
Post by flames on Jul 30, 2020 18:41:16 GMT 1
Did you have to do anything else in particular? I have some barrels I need to get fit. Not sure I can get away without a re bore but want to try as they are +1.75 already but they are tuned and went very well before I messed with it.π On mine there were no scores so once the acid had done its stuff i rinsed them thoroughly sprayed with wd it completely removed the aluminium but the smear wasnβt serious,ive done about 1000 miles since with no probs just do a little bit at a time Nice one thank you. Not sure if mine is scored. It's hard to tell because of the aluminium, will definitely give that a go and check . Fingers crossed.π
tlmark
Damn it!
Jul 31, 2020 8:22:43 GMT 1
via mobile
Post by tlmark on Jul 31, 2020 8:22:43 GMT 1
Yeah itβs a 3 stone one I spoke to the guy who did my motor He said it should be ok?
tlmark
Post by tlmark on Jul 31, 2020 9:50:49 GMT 1
I used spirit of salts (drain cleaner )to dissolve the smeared aluminium,i just dabbed it on with a cotton bud and watched It bubble then washed off . Excellent I'll give somme of that a go, thanks.
Damn it!
Jul 31, 2020 19:32:21 GMT 1
via mobile
Post by flames on Jul 31, 2020 19:32:21 GMT 1
Β£14.75 for 6 X 500ml on Amazon. I just ordered some. Hopefully it will save me a rebore.
Post by mick858 on Jul 31, 2020 19:56:35 GMT 1
Β£14.75 for 6 X 500ml on Amazon. I just ordered some. Hopefully it will save me a rebore. I thought you said you were a tight git!
Post by Tobyjugs on Jul 31, 2020 20:23:22 GMT 1
A two stone with two guides hone tool will be much better than a 3 stone hone tool. What is really important is the Lenght of the hone stones. Try to get a tool with long hone stones. These will give you a much straighter hone.
Post by flames on Jul 31, 2020 22:46:51 GMT 1
Β£14.75 for 6 X 500ml on Amazon. I just ordered some. Hopefully it will save me a rebore. I thought you said you were a tight git! I am... It was cheaper to bulk buy..... remember I also have a habit of melting pistons.
Post by bare on Aug 1, 2020 1:18:07 GMT 1
Hmmmm.. I've been running a bit of premix oil in the Gas tank.. Yess the pump is in and working.. for more than 12 years now. NO unexpected seizures.. mercifully. Net oil ratio is ~25 to 1 . It's Only too much Oil when it misfires... Which it has Never, ever done. Oil is cheap insurance ... pointless rebuilds are not.
PS; Buy / use a Ball Hone. Best of breed IMO. Leave the 3 piece springy hone things for redoing the brake cylinders on your Austin 7.
tlmark
Post by tlmark on Aug 1, 2020 13:27:06 GMT 1
I got the spirit of salts from homebase Β£3.50 for 500ml
word of caution this stuff stinks and used neat is very corrosive, It did seem to work I'm not sure how your going to use 3 liters though I used maybe a teaspoon full at the most.
The honing tool may be not be ideal but it did the job pretty well certainly good enough for this job.
the advise I would give and not how did my first go, is to do it from the bottom up not the top down.
There are some witness marks but no gouges.
Lunch break now
then put it back togeather
Post by arrow on Aug 1, 2020 13:36:57 GMT 1
Thats not ideal like that you need two patterns at 45Β° each. You have to move it in and out fast.
