Post by nokturnal on Apr 9, 2020 22:31:36 GMT 1
where did you buy the crank? its an LC crank? not a YPVS made to fit?
Post by 4l04ever on Apr 10, 2020 1:00:56 GMT 1
I got mine from Grampian.
Norbo has LC cranks in stock too, and exchange ones.
Post by 4l04ever on Jun 24, 2020 1:35:53 GMT 1
Post by shaunthe2nd on Jun 24, 2020 20:55:37 GMT 1
Great thread, thanks for sharing and keep us posted.
Post by flames on Jun 24, 2020 21:05:52 GMT 1
Looks fantastic already!
Post by 4l04ever on Jun 28, 2020 17:51:50 GMT 1
Post by Tobyjugs on Jul 1, 2020 22:07:05 GMT 1
Just noticed on my PC monitor that I can see strange wear on bottom rings...anyone else seen anything like that. It was not evident by eye. Top ring looks to have sealed very well, so hardly any blow-by getting to 2nd ring. Piston ring wear on a two stroke engine like this is more complex due to the extra flexing of the piston rings moving over the exhaust ports etc. The wear on each end of the piston ring is normal. Minimal wear should be found at the sides where the gudgeon pins are.
2taol
Post by 2taol on Jul 4, 2020 19:05:42 GMT 1
love to see projects taking shape, nice progress
Post by 123 on Jul 4, 2020 19:51:16 GMT 1
great work nice paint
Post by 4l04ever on Aug 30, 2020 19:53:08 GMT 1
Post by 4l04ever on Aug 30, 2020 19:54:31 GMT 1
Post by 4l04ever on Aug 30, 2020 19:55:46 GMT 1
Post by 4l04ever on Aug 30, 2020 19:56:55 GMT 1
Post by 4l04ever on Aug 30, 2020 19:58:52 GMT 1
Fitted reed blocks. Did leak down test and found a small hole in side of inlet where the wall was very thin from fitting YPVS reed blocks. Ordered some JB Weld.
Post by flames on Aug 30, 2020 20:17:20 GMT 1
Looking like it is coming along nicely apart from hole in inlet. Have you fitted 2 base gaskets and a spacer because of mods to head? Have your barrels been skimmed as well?
Has motor been tuned as well?
Another build i am really looking forward to coming together. You are doing an amazing job as always. I admire your attention to detail.
Post by 4l04ever on Aug 30, 2020 20:30:58 GMT 1
Yes, I have 2 sets of base gaskets, got a 1mm spacer between them. Ended up with 0.25mm Siamese base gasket on the bottom, then the 1mm spacer plate, then a 0.25mm gasket on the right cylinder and a 0.4mm gasket on the left. This is only possible on this engine due to having separate heads :-)
The cylinders were only skimmed a small amount to get them dead flat. The spacer is more to replace the missing head gasket. The cylinders are ported, and makes 57hp. Has Zeeltronic ignition, standard carbs, modified airbox, TSA exhausts. Dyno setup.
What is interesting, is that in different engine casings and using a different crank, but same pistons, the base gaskets were the same, so either this crank or these casings are 0.1mm to 0.15mm higher on the left cylinder, but compensated with different base gasket.
Post by 4l04ever on Aug 30, 2020 20:35:22 GMT 1
Squish measurements :-
Lower base gasket 0.25mm Siamese Spacer plate = 1.00mm Upper base gaskets 0.25mm Right, 0.40mm Left
Left Cylinder
Front = 1.01mm Rear = 1.01mm Left = 1.02mm Right = 1.02mm
Average = 1.015mm
Right Cylinder
Front = 1.03mm Rear = 1.04mm Left = 1.03mm Right = 1.02mm
Average = 1.03mm
Post by flames on Aug 30, 2020 20:39:41 GMT 1
I would like to get a zeeltronic for mine for mine.Do they make much difference? 57hp is a result. When i get round to my engine i need to measure both sets of barrels to work out how much has been skimmed off the top of my tuned ones. When i get round to that , i may ask for some advice from you as i know i need to run 2 sets of base gaskets and a spacer. Will need to know what thicknesses i need to suit.
Post by 4l04ever on Aug 30, 2020 20:41:56 GMT 1
To run a more optimum squish, you will probably need to get your heads re-profiled, as the compression can get too high with the standard combustion chamber. You need good squish and volume to work well :-)
Post by flames on Aug 30, 2020 20:58:23 GMT 1
To run a more optimum squish, you will probably need to get your heads re-profiled, as the compression can get too high with the standard combustion chamber. You need good squish and volume to work well :-) And that is the reason i will be on +2mm pistons......didn't do anything with volume on last build..... Worst thing is, when i first got the bike, it went like stink. started first kick every kick and revd cleanly from about 3k. The barrels were skimmed and the head had been skimmed to death!!! but never had an issue with detonation. Wish i had had kept the spacer in a safe place so i knew how thick it was.....or better still......i wish i hadn't been on a session down the pub when i decided to remove it. Anyway, sorry for butting in to your thread. Will ask more when i get round to doing my engine.....but on another thread.
Post by 4l04ever on Sept 6, 2020 19:23:51 GMT 1
Post by 4l04ever on Sept 6, 2020 19:26:10 GMT 1
Post by 4l04ever on Sept 6, 2020 19:27:24 GMT 1
Post by 4l04ever on Sept 6, 2020 19:29:06 GMT 1
Final headlight bracket fitted.
Post by flames on Sept 6, 2020 19:48:17 GMT 1
That is class........that you have 2 builds on the go and can still steam through them this quick and still do such a great job is amazing. Love the headlight brackets.
Post by 4l04ever on Dec 17, 2020 23:50:21 GMT 1
Getting back on this one again now. Just fitting a Koso Mini 3 Dual Temperature gauge.
Post by 4l04ever on Dec 17, 2020 23:53:25 GMT 1
Pics Just need to make a bracket for the display...
Post by midlifecrisisrd on Dec 18, 2020 9:49:14 GMT 1
Not had a peek for a while
Brilliant build
Post by 4l04ever on Dec 18, 2020 10:25:14 GMT 1
The list of jobs is getting shorter too. Just getting a high security insulated roller garage door sorted, so should be warmer in there to do a few more jobs.
Post by tell7437 on Dec 20, 2020 0:17:46 GMT 1
I have an o ringed head for my ypvs but don't have the o rings, any clues where to buy them would be a great help, also what silicon did you use on the head. Cheers Trevor
