Post by wallcraft on May 25, 2021 22:33:09 GMT 1
Nice girth on that then 😮
Post by 4l04ever on May 25, 2021 22:58:08 GMT 1
The new rad is about 50mm wider than the old one and about 30mm taller. The new core is 36mm thick compared to around 20mm before.
The old rad still let the temperature get up to low 80s in the hot weather, but want it more like 60 to 70...
Post by 4l04ever on Aug 21, 2021 15:22:34 GMT 1
Made radiator grill. Just need to get it polished.
Post by donkeychomp on Aug 21, 2021 21:45:14 GMT 1
You made that? Fantastic work Rob!
Post by boulding59 on Aug 21, 2021 21:48:19 GMT 1
Made radiator grill. Just need to get it polished. Wow looks great 👍🏼
Post by 4l04ever on Aug 21, 2021 22:57:05 GMT 1
I got the mesh and stainless bar, and Nick at Tuffweld got the ends cut and bent, then he welded it together and cut the corners off. I drilled the holes in the sides allowing room for some foam strips to be fitted between the rad and the grill. Going to cut some vinyl Japanese symbols to go on the sides after it is polished.
Post by boulding59 on Aug 22, 2021 8:00:03 GMT 1
I got the mesh and stainless bar, and Nick at Tuffweld got the ends cut and bent, then he welded it together and cut the corners off. I drilled the holes in the sides allowing room for some foam strips to be fitted between the rad and the grill. Going to cut some vinyl Japanese symbols to go on the sides after it is polished. Looking forward to seeing it finished sounds good
Post by 4l04ever on Aug 30, 2021 20:51:24 GMT 1
Got grill polished. Sprayed the radiator with XCP rust blocker clear coat. Fitted the grill.
Post by 4l04ever on Aug 31, 2021 21:26:46 GMT 1
Put the new vinyl stickers on. Did a heat cycle too Gets neutral really easy.
Post by 4l04ever on Sept 1, 2021 11:14:13 GMT 1
It says "Liquid Cooled" in Japanese.
I like the Japanese symbols, as it goes with the Japanese RZ style decals.
Post by donkeychomp on Sept 1, 2021 21:27:07 GMT 1
I sure hope so! You hear of people getting tattoos in foreign languages... Alex
Post by 4l04ever on Sept 1, 2021 21:34:17 GMT 1
Use this website :- jisho.org/My daughter used this website while studying Japanese at Uni.
Post by 4l04ever on Sept 1, 2021 21:41:49 GMT 1
直穿き
This means going commando :-)
Post by donkeychomp on Sept 1, 2021 22:25:28 GMT 1
Post by shaunthe2nd on Sept 1, 2021 22:42:42 GMT 1
直穿きThis means going commando :-) Now why did you translate that? ...
Post by shaunthe2nd on Sept 1, 2021 22:45:56 GMT 1
Coming along though Rob, great work.
Post by 4l04ever on Sept 2, 2021 18:32:47 GMT 1
Passed MOT :-)
Now taxed and all legal. Went to the biker Cafe for a shakedown run. Got to adjust the chain guard as the chain keeps tinkling it. Need to clean right carb as has a slight leak, so need to check needle valve and seat. I have a stainless clock bracket, but the clocks keep bouncing as it is not as rigid as an OEM bracket, so I will change back to a green one. The rev counter is reading low, so will have to swap that out, so will do that at the same time I get the clock bracket off.
Overall, not too bad for a first ride.
Post by Tobyjugs on Sept 2, 2021 18:37:03 GMT 1
Great news. Did anyone ask about the Japanese writing? Hows your new rad performing `Rob
Post by 4l04ever on Sept 2, 2021 20:23:23 GMT 1
Only one other bike at the Cafe so not many people seen it yet.
Rad is a bit too efficient for this cooler weather. Sticking around 50c
Post by 4l04ever on Sept 2, 2021 20:24:30 GMT 1
Just finished modifying chainguard mount so chain clears better now.
Post by donkeychomp on Sept 2, 2021 21:16:47 GMT 1
Nice one Rob!
Post by 4l04ever on Sept 4, 2021 20:14:03 GMT 1
Sorted right carb. The o-ring was passing fuel on the needle valve seat. Replaced seat, needle and o-ring. Now leak free :-)
Looks like the speedo also needs looking at, as seems to oscillate about +/- 2mph all the time...
Will sort another set of clocks and swap it all over in one go.
Temps still sitting around 49c to 52c, so need to make a blank to cover part of the radiator. I will try cutting some acrylic and bend the end over and put in behind the grill.
Post by 4l04ever on Sept 5, 2021 20:33:38 GMT 1
Took it out again today for a 130 mile run. Temps were between 52c and 57c, so not far away from where I want to be.
I am getting used to caning it again :-)
