Post by pdxjim on Jan 24, 2020 23:59:35 GMT 1
"Stage 2" tuned bike. Porting, pipes, etc, etc. Standard 4L0 wheels and tire sizes. What's best all round fast road gearing? Already went to the expense of having custom ally 520 rear sprocket made in standard size, so just needing advice on the front, please ... I ask because when I "tuned" my TDR, I went up one on the front for "touring" but it would always fall in a hole between 5th and 6th unless riding WFO. So now back to standard gearing on that one even with a 55 section rear tire. The RD400 guys here go down one tooth in front on a tuned bike because it'll pull higher RPM and get you the same top speed (and better wheelies).
Post by pdxjim on Jan 25, 2020 0:14:56 GMT 1
... and for 520 conversion on 4L0, I assume I just use LC2/RZ/YPVS/Banshee front sprocket?
Post by JonW on Jan 25, 2020 8:03:17 GMT 1
... and for 520 conversion on 4L0, I assume I just use LC2/RZ/YPVS/Banshee front sprocket? yes. with the YPVS spacer.
Post by pdxjim on Jan 25, 2020 8:54:04 GMT 1
... and for 520 conversion on 4L0, I assume I just use LC2/RZ/YPVS/Banshee front sprocket? yes. with the YPVS spacer. Indulge me please Jon ... Why do I need the RZ spacer? If the rear 520 sprocket is thinner and the front 520 sprocket is thinner by the same amount, then shouldn't they still be in line? Cheap enough at $11.00 but I'm still not understanding why it's needed. www.partzilla.com/product/yamaha/90387-257N4-00
Post by pdxjim on Jan 25, 2020 9:21:33 GMT 1
Post by Tobyjugs on Jan 25, 2020 10:03:11 GMT 1
If your bike is original and you only change the thickness of both sprockets you do not need to change the front sprocket spacer.
As a rough guide one tooth difference up front is the same as 3 teeth on the back sprocket. There are programs on the internet you can use to see the effect of changing your sprockets
Post by JonW on Jan 25, 2020 13:07:38 GMT 1
Ooops sorry I was thinking you had a YPVS engine in there, my bad.
Post by pdxjim on Feb 3, 2020 3:58:36 GMT 1
Right. Got the 520 front sprocket. Got the standard 4L0 spacer and nut. Got a new tab washer. As I suspected (and have read in past posts) the CS nut bottoms out on the splines before tightening down on the sprocket. Looks like I need a washer/spacer on the outside between the sprocket and the tab washer. Am I correct that "clutch thrust washer" 360-16154 will fit and give the appropriate clearance? www.partzilla.com/product/yamaha/360-16154-00-00Crude measure as pictured looks to be +/- 1" ID which is what the splines measure.
Post by bare on Feb 3, 2020 4:09:47 GMT 1
An inexpensive Large washer from the Hardware store can work 'fine' as long as it's 3mm + thick.
Post by pdxjim on Feb 3, 2020 5:46:23 GMT 1
Thanks, but this answer seems a bit out of character for you Mr Bare, sir.
Perhaps I'm over thinking it, but a cut washer from the hardware store seems a bit crude for this application?
Post by midlifecrisisrd on Feb 3, 2020 9:42:35 GMT 1
Think last time I messed around with this issue I used one of the thrust washers that goes behind and between the clutch basket
Post by 4l04ever on Feb 3, 2020 11:17:39 GMT 1
Yes, the big clutch washers are the perfect size for this application.
Post by bare on Feb 3, 2020 18:22:42 GMT 1
Thanks, but this answer seems a bit out of character for you Mr Bare, sir. Perhaps I'm over thinking it, but a cut washer from the hardware store seems a bit crude for this application? IMO you Are.. Washer is ONLY a spacer, betwixt Nut and end of shaft threads threads.. no more / no less. But if you have spare Yama bits you are willing to waste there.. Use them then.
Post by Tobyjugs on Feb 3, 2020 18:32:52 GMT 1
Or make a bespoke nut to fit.
Post by pdxjim on Feb 3, 2020 19:51:44 GMT 1
Thanks, but this answer seems a bit out of character for you Mr Bare, sir. Perhaps I'm over thinking it, but a cut washer from the hardware store seems a bit crude for this application? IMO you Are.. Washer is ONLY a spacer, betwixt Nut and end of shaft threads threads.. no more / no less. But if you have spare Yama bits you are willing to waste there.. Use them then. Hardware store washer is $1.00, proper Yamaha thrust washer is $5.00. Less than a pint all in, so not much of a “waste” really 🤷🏻♂️ Thanks for the replies, all 👍
Post by JonW on Feb 3, 2020 22:33:30 GMT 1
Washer from stock is free... drive to hardware store and pay $1 for washer plus fuel money and time as well...
Post by pdxjim on Feb 3, 2020 22:46:47 GMT 1
Washer from stock is free... drive to hardware store and pay $1 for washer plus fuel money and time as well... Thankfully, I have a decent hardware store (exactly) 161 meters from my doorstep. Still think I'd rather pay $5.00 for the proper part. ... that said, now I'm thinking the clutch thrust washer will probably rust quickly as it's designed to live in an oil bath and not plated. Can't win this one I guess.
Post by doohanno1 on Feb 3, 2020 22:56:24 GMT 1
" Less than a pint all in, so not much of a “waste” really " Ah but think of that lovely extra pint you could get..🍻😜🕺.. Anyway ' if Castrol did pints'..
Post by bare on Feb 5, 2020 17:54:50 GMT 1
Washer from stock is free... drive to hardware store and pay $1 for washer plus fuel money and time as well... Thankfully, I have a decent hardware store (exactly) 161 meters from my doorstep. Still think I'd rather pay $5.00 for the proper part. ... that said, now I'm thinking the clutch thrust washer will probably rust quickly as it's designed to live in an oil bath and not plated. Can't win this one I guess. Hey ! whatever blows your jets . However this ISN'T a 'proper' part... it's a Bodge . Often regular washers are on hand... grab 'n go. Mevbe your repurposed Yama one is on hand ? If not.. getting one is far more complex.
Post by beardy on Feb 5, 2020 18:38:37 GMT 1
I’m sure once it’s covered in gear/chain/engine oil it’ll be fine
Post by pdxjim on Oct 23, 2020 0:15:23 GMT 1
Well, loathe as I am to admit defeat, I must say our man bare may be correct on this one. At the left is a proper clutch thrust washer, and at the right is an M24 washer from the local hardware store. To add insult to injury, the hardware store item was actually free, as my mate owns the shop and gave it to me gratis.
smoke
Post by smoke on Nov 2, 2020 12:50:33 GMT 1
Hi, Anyone know where I can buy a 520 rear sprocket for my 4l0? Smoke
Post by midlifecrisisrd on Nov 3, 2020 9:31:36 GMT 1
Hi, Anyone know where I can buy a 520 rear sprocket for my 4l0? Smoke B and C express Steve
smoke
Post by smoke on Nov 3, 2020 9:54:25 GMT 1
Great! Thanks a lot Midlifecrisisrd! Smoke
