rickymac
Hi all new to this forum and owner of a barn find 250lc
Post by rickymac on Jul 4, 2020 22:41:42 GMT 1
Post by dusty350 on Jul 4, 2020 22:43:43 GMT 1
Looking VERY nice
rickymac
Post by rickymac on Jul 12, 2020 12:56:51 GMT 1
Few more bits added, made clock bracket.
rickymac
Post by rickymac on Jul 12, 2020 12:57:13 GMT 1
rickymac
Post by rickymac on Jul 12, 2020 12:59:27 GMT 1
Abs sensor hole at bottom of fork is the same size as the koso speed sensor, so M5 tapped hole for the grub screw glue some magnets to the abs ring and hopefully jobs a gud un.
Post by mak595 on Jul 12, 2020 18:59:37 GMT 1
Abs sensor hole at bottom of fork is the same size as the koso speed sensor, so M5 tapped hole for the grub screw glue some magnets to the abs ring and hopefully jobs a gud un. Good to know as I've got a set of koso clocks as well !
Post by flames on Jul 12, 2020 19:29:42 GMT 1
I absolutely love them gold wheels. And they go so well with red frame.i hope the bodywork is going to have at least a little black in it? Perfect combination.π
jay
2 stroke or not 2 stroke
Post by jay on Jul 12, 2020 20:52:36 GMT 1
Looks sweet ricky
avb
andys vapour blasting
Post by avb on Jul 12, 2020 21:26:43 GMT 1
the swingarm looks just the right length and suits the bike wheel colour does look good
rickymac
Post by rickymac on Jul 12, 2020 21:43:29 GMT 1
I absolutely love them gold wheels. And they go so well with red frame.i hope the bodywork is going to have at least a little black in it? Perfect combination.π No not got any black in it
rickymac
Post by rickymac on Jul 16, 2020 23:07:33 GMT 1
Koso clocks wired up
rickymac
Post by rickymac on Jul 16, 2020 23:07:52 GMT 1
rickymac
Post by rickymac on Jul 16, 2020 23:08:55 GMT 1
Next job wire in ignitech
rickymac
Post by rickymac on Jul 24, 2020 15:30:36 GMT 1
Started wiring spaghetti junction
rickymac
Post by rickymac on Jul 24, 2020 15:31:47 GMT 1
Post by mak595 on Jul 24, 2020 17:36:19 GMT 1
I'll probably be picking your brains as I've got the same koso clocks and ignitech box to wire in !!!
Post by flames on Jul 24, 2020 19:42:48 GMT 1
That red is something special. Almost looks like it's still in liquid form.
rickymac
Post by rickymac on Jul 24, 2020 21:34:39 GMT 1
I'll probably be picking your brains as I've got the same koso clocks and ignitech box to wire in !!! No probs hopefully I wonβt have a π₯
rickymac
Post by rickymac on Jul 26, 2020 21:49:40 GMT 1
Ignitech wired in and we have a spark
rickymac
Post by rickymac on Jul 26, 2020 21:55:03 GMT 1
Pump on, another top job by the pump god Arrow.
avb
Post by avb on Jul 27, 2020 18:37:33 GMT 1
Ignitech wired in and we have a spark have you got any anti vibration under the ignitech? they are sensitive bits of kit
rickymac
Post by rickymac on Jul 27, 2020 18:53:26 GMT 1
Ignitech wired in and we have a spark have you got any anti vibration under the ignitech? they are sensitive bits of kit Got self adhesive sponge underneath and on the strap
avb
Post by avb on Jul 27, 2020 18:55:09 GMT 1
Nice on π
rickymac
Post by rickymac on Aug 2, 2020 22:35:10 GMT 1
We have a runner Hopefully up to mutts Nutts for pipes and setting up soon.
kopite30
http://www.motomovers.uk
Post by kopite30 on Aug 3, 2020 18:24:32 GMT 1
Looking sweet as bud nice one
rickymac
Post by rickymac on Aug 3, 2020 19:22:24 GMT 1
Looking sweet as bud nice one Cheers mike
Post by mak595 on Aug 4, 2020 7:45:54 GMT 1
Cool, got my pipes made from Alonze customs (Jim makes the pipes for DaveW) Jim has left the rear mounting brackets off so i can weld them on where i want, with running R1 rear sets, the standard mounting points would be out. Got a pair of carbon cans off Norbo
rickymac
Post by rickymac on Aug 4, 2020 7:53:25 GMT 1
Stock l/h pipes very close to hitting the swing arm
rickymac
Post by rickymac on Aug 4, 2020 7:54:11 GMT 1
Plenty space other side
2taol
Post by 2taol on Aug 4, 2020 12:22:29 GMT 1
I had the same issue with my setup, same swinger but with small can microns. I ended up cutting, adding a section and rewelding the pipes and also adding a specer to the footrest hanger.
