Post by dusty350 on Nov 12, 2020 8:39:48 GMT 1
The ignition is another part to go on the Shambits list of parts that aren't quite right !! You might be able to peel your decal off and restick it, but I bought a new one anyway.
Post by sidney81 on Nov 12, 2020 11:27:01 GMT 1
The ignition is another part to go on the Shambits list of parts that aren't quite right !! You might be able to peel your decal off and restick it, but I bought a new one anyway. I have had a pick at it think it might come off ok I'll get a new one but yes on the list and in room 101
Post by midlifecrisisrd on Nov 12, 2020 12:08:36 GMT 1
Now this switch decal has me thinking
Do you think it's been assembled wrong
Usually there are 2 screws holding the barrel onto the base
If you remove them, rotate 180 degrees (you will have to take the switch gubbins out too) and refit is it then correct and working?
Post by sidney81 on Nov 12, 2020 13:53:10 GMT 1
Now this switch decal has me thinking Do you think it's been assembled wrong Usually there are 2 screws holding the barrel onto the base If you remove them, rotate 180 degrees (you will have to take the switch gubbins out too) and refit is it then correct and working? Steve hi ,yes the holes are offset so when you spin it they don't line up !??
Post by midlifecrisisrd on Nov 12, 2020 15:14:58 GMT 1
Bugger βΉ
Post by sidney81 on Nov 12, 2020 15:33:41 GMT 1
I cant see how you get it apart to turn it ,if you can that is π
Post by dusty350 on Nov 12, 2020 17:12:33 GMT 1
Its sealed as far as I can see. Offset bracket is permanently fixed to the switch body so can only go on one way to match the fixing holes on the back plate. So can only go on in an upside down postion π
Dusty
Post by sidney81 on Nov 15, 2020 22:01:36 GMT 1
hi everyone been working on the footrest hangers ,ive finished them off !got them in the sink and rubbed them down with wet n dry started with 400 grit and went down to 1200 ,then got set up in the old garage ready to make a mess with the polishing mop they came out ok not perfect but im happy with the finish think they look nice so i also polished the alloy spacers i made up that sit behind then wheeled her out for a obligatory out door photo session IMG-20201115-WA0001 by Chris, on Flickr when finished with the wet n dry PXL_20201115_120750979.PORTRAIT-01.COVER by Chris, on Flickr when i finished with the mop ,with cheesy grin PXL_20201115_124732973.PORTRAIT-01.COVER by Chris, on Flickr PXL_20201115_130028275 by Chris, on Flickr PXL_20201115_125904735.PORTRAIT-01.COVER by Chris, on Flickr PXL_20201115_125758761.PORTRAIT by Chris, on Flickr also found the headlight brackets hit the tank on full lock bugger ,look at that in the week dont think its to much of a issue chris
2taol
Post by 2taol on Nov 15, 2020 22:51:44 GMT 1
looking good, those hangers polished up nice. So far the roller is quite bling π
Post by sidney81 on Nov 15, 2020 23:13:59 GMT 1
looking good, those hangers polished up nice. So far the roller is quite bling π Thanks bud they did come up nice ,and I hate polishing ha ha π
2taol
Post by 2taol on Nov 16, 2020 0:21:01 GMT 1
i hate it too, until I get a nice result, such a messy task, cant be good to be inhaling that.
Post by yamark on Nov 16, 2020 20:49:02 GMT 1
Great work, looking very nice
Post by sidney81 on Nov 16, 2020 21:11:14 GMT 1
Great work, looking very nice thanks mark ,means alot πI'm enjoying this build π
Post by sidney81 on Nov 19, 2020 21:44:05 GMT 1
Post by 400c on Nov 20, 2020 0:41:16 GMT 1
looking very tidy
Post by sidney81 on Nov 20, 2020 8:11:52 GMT 1
Post by sidney81 on Nov 20, 2020 14:09:34 GMT 1
Hi the headlight brackets have been drawn up π€£I'm getting two sets cut ,one set with cut outs in and another set solid?! They come out at Β£4 each so cheep!! Here's the drawing my man done for me at work π Chris
2taol
Post by 2taol on Nov 21, 2020 9:33:24 GMT 1
They look great Chris, that is cheap for sure to get them done. 3 or 4mm alu is suspect?
Post by sidney81 on Nov 21, 2020 9:39:46 GMT 1
They look great Chris, that is cheap for sure to get them done. 3 or 4mm alu is suspect? Thank you !! Going for 5 mm alu ππ
Post by jon on Nov 21, 2020 9:42:54 GMT 1
I have to say I actually prefer the cutout design on your card mock ups.
Why not get all three designs done at that price and decide later?
Post by sidney81 on Nov 21, 2020 10:01:00 GMT 1
I have to say I actually prefer the cutout design on your card mock ups. Why not get all three designs done at that price and decide later? Jon hi Jon I'm with you I do to prefer the cut out ones so I am getting them done and also solid ones so I can choose but I think it will be the cut out ones π
Post by dusty350 on Nov 21, 2020 11:39:14 GMT 1
I agree on cut out versions. It would pick up on the cut outs in your footrest plates too, keeping a "theme". Plus they look more trick, and bespokeπ
Dustyπ
Post by sidney81 on Nov 21, 2020 11:42:52 GMT 1
I agree on cut out versions. It would pick up on the cut outs in your footrest plates too, keeping a "theme". Plus they look more trick, and bespokeπ Dustyπ hi dusty yep cool looking like the cut out ones π I agree they are nicer π
Post by Tobyjugs on Nov 21, 2020 11:42:54 GMT 1
I made my brackets from 3mm aluminium plate. I found this thick enough for my use.
5mm plate might stick out like a sore thumb where it connect to the fork fittings.
Post by sidney81 on Nov 21, 2020 11:45:46 GMT 1
I made my brackets from 3mm aluminium plate. I found this thick enough for my use. 5mm plate might stick out like a sore thumb where it connect to the fork fittings. hi bud I see what you mean but it should be fine as the naff ones that came with the kit are 5 mm and looks fine so I've kept them the same thickness thsts the only reason ,but yes 3 mm would be more than adequate ,thanks for the comment ππ
Post by yamark on Nov 22, 2020 20:41:36 GMT 1
Hi Chris, a no brainer for me- the cut out brackets look top draw. Your "CAD" design looks way better than those black curved horrors
Mark
Post by sidney81 on Nov 22, 2020 21:09:22 GMT 1
Mark Β hi mark ,ha ha glad you agree the curved ones are horrible !and thanks yep cut out ones it will be πthanks for the comment πππ
Post by 4l04ever on Nov 23, 2020 0:07:06 GMT 1
Post by sidney81 on Nov 24, 2020 21:08:33 GMT 1
Post by dusty350 on Nov 24, 2020 22:14:25 GMT 1
The headlight brackets look great Chris, really nice And the muddie looks great cut down. Not seen that done before but I think it works really well It's really coming on now mate Dusty
