Post by philip on Feb 16, 2019 7:02:27 GMT 1
I have located V Force Reeds to RD350LC (not YPVS model) the question is that are they worth the expense and how long do the reeds last.
Thanks for any info
Philip
Post by jon on Feb 16, 2019 10:43:01 GMT 1
I’ve seen a thread on hear recently about someone having bought some v force reeds to fit an LC. From memory they didn’t fit.
Of course you can open up the inlets on an LC barrel, but the walls re dangerously thin.
I’d be interested to know if the ones you’ve found do fit?
As far as are they worth it? As a single modification from standard I’d say no they are not worth the expense. However as part of a host of tuning mods, I’d say yes definately.
Post by headcoats on Feb 16, 2019 11:18:20 GMT 1
You need to remember too that when the Vforce reeds need replacing you need X4 per reed block !
I would like to see someone dyno some TZR 250 reed blocks to see how they perform ?
Post by Tobyjugs on Feb 16, 2019 11:19:37 GMT 1
In general they work better than standard reeds. I have done some dyno tests with the YPVS V3 reeds and they worked best against a standard pair and a modified pair of standard reeds with the standard intake system and a standard billet intake manifold. I also modified a billet intake manifold to suit the carbs and then the modified reeds worked better than the V3 reeds but it was only 1.5 up on the top of the curve.
The V4 YPVS reeds are way too big to fit in a 4LO intake and as Jon pointed out it is a bit of a squeeze with the standard YPVS reeds.
It is easier to add a spacer in front of the Standard YPVS reeds then you don't have to grind so much out of the 4LO intakes, again the spacer in front of the reeds drop peak hp and you gain a little in mid range.
Post by jackjabba on Feb 16, 2019 11:25:57 GMT 1
I think Dave did some tests (ypvs) on his dyno and saw good gains across the rev range. Not seen any for an LC so will be interested to see.
Post by Norbo on Feb 16, 2019 11:48:48 GMT 1
I have some Billet X Blocks that do the same power but at half the price . But are for ypvs so not a straight fit to an lc .
Post by 0h5h1t on Feb 17, 2019 13:04:12 GMT 1
I have some Billet X Blocks that do the same power but at half the price . But are for ypvs so not a straight fit to an lc . any Dyno graphs to show that Norbo.
intersting to see your billet x blocks against standard reed blocks and vforce4's
Post by Tobyjugs on Feb 17, 2019 13:27:38 GMT 1
I have read that the Xblocks perform as good as or better than the V-force reeds with lower powered engines but I have never seen a dyno chart to prove this.
Post by muttsnuts on Feb 17, 2019 20:19:20 GMT 1
I have some VForce reeds that fit an LC inlet with no modification, they are waiting for me to find a spare couple of hours to test them, oh and a bike I suppose would help as well ! I'll publish up some results when I've done it, but that might be a while as I am snowed under right now, meanwhile a graph of the VForce 4's vs stock YPVS reeds fitted to a 350 YPVS
Post by doohanno1 on Feb 17, 2019 20:40:20 GMT 1
I have some VForce reeds that fit an LC inlet with no modification, they are waiting for me to find a spare couple of hours to test them, oh and a bike I suppose would help as well ! I'll publish up some results when I've done it, but that might be a while as I am snowed under right now, meanwhile a graph of the VForce 4's vs stock YPVS reeds fitted to a 350 YPVS Are the ypvs ones a plug and play fit or do intakes need modding.?
Post by muttsnuts on Feb 17, 2019 20:45:46 GMT 1
straight fit, I stock them if you require any
Post by botty on Feb 17, 2019 20:46:42 GMT 1
I have some VForce reeds that fit an LC inlet with no modification, they are waiting for me to find a spare couple of hours to test them, oh and a bike I suppose would help as well ! I'll publish up some results when I've done it, but that might be a while as I am snowed under right now, meanwhile a graph of the VForce 4's vs stock YPVS reeds fitted to a 350 YPVS Are the ypvs ones a plug and play fit or do intakes need modding.? Plug and play. Got them on three Ypvs motors
Post by doohanno1 on Feb 17, 2019 20:56:04 GMT 1
Are the ypvs ones a plug and play fit or do intakes need modding.? Plug and play. Got them on three Ypvs motors In the real world can you feel a difference when fitted.The fact you fiited them three times may answer my question..
Post by botty on Feb 17, 2019 21:51:02 GMT 1
Put them in fresh builds so unable to comment.
Went off the results of Dave’s dyno results. Plus being the latest technology, have to be better than the 30 year old oe items
Post by pdxjim on Feb 17, 2019 23:20:50 GMT 1
I believe the ones you need are VForce3 #V384A to fit aircooled and LC.
Post by headcoats on Feb 18, 2019 10:44:38 GMT 1
The V3's had no reed stops but the V4's , they have them
Post by hudtm60 on Feb 18, 2019 17:53:32 GMT 1
in short: VForce Reeds of any kind do not fit in an unmodified 4L0....http://rdlccrazy.proboards.com/thread/41050/vforce4-reeds-on-4l0
Post by pdxjim on Feb 18, 2019 19:27:02 GMT 1
in short: VForce Reeds of any kind do not fit in an unmodified 4L0....http://rdlccrazy.proboards.com/thread/41050/vforce4-reeds-on-4l0 Just inquired with an LC owner/tuner here in the States says VForce3 #V384A (RM100) fits 350LC cyls with 6mm spacers and no modification to the cyls. Mounting holes on cages must be taken out to 9mm, and stuffers modded to match manifolds. www.2strokeworld.net/forum/index.php?topic=31.0
Post by JonW on Feb 18, 2019 22:38:00 GMT 1
I thought the YZ85 VF reeds fitted the LC as the 250 ypvs is the same size, with minimal fettling of the cylinders or a spacer.
daveg
ProClassic
Post by daveg on May 6, 2021 14:30:05 GMT 1
Hi Guys, My Vforce 3 reeds really need changing anyone got a good address? THe petals are no longer sealing the hole especially the inside ones. Is there any way of heating them up to "bend" them back? ANyone treid anything to bring them flat again?
Post by tacky1 on May 6, 2021 14:46:36 GMT 1
Post by crogthomas on May 7, 2021 15:19:35 GMT 1
Hi Guys, My Vforce 3 reeds really need changing anyone got a good address? THe petals are no longer sealing the hole especially the inside ones. Is there any way of heating them up to "bend" them back? ANyone treid anything to bring them flat again? There is a link to a company making them in this thread: rdlccrazy.proboards.com/thread/52812/ebay-force-reeds-china
