Post by dave1967 on Jun 18, 2013 23:35:08 GMT 1
Cant for the life of me remember what these are for or where they go What goes into the two holes on the triangular piece the bit right by the wiring plug in pic Have got the engine in..does it all look ok from what you can see..please tell me it doesn't have to come back out to fit something ive forgotten.
guernseyrob
1986 350 YPVS N1 & 1985 350 31k YPVS
Post by guernseyrob on Jun 19, 2013 0:10:44 GMT 1
Hi Dave,
From memory I think the chrome grab rail that goes over the tail piece (and passes through 2 holes in it each side) then bolts into the two smaller holes in each bracket in the first picture, not 100% sure but think the other larger hole in the brackets then bolts down through the plastic tail piece onto those triangular brackets on the frame that you're asking about in piccie 2.
Someone pls correct me if wrong, (trying to picture it in my head as my bike shed is elsewhere so I can't quick take a peek).
Rob.
Post by Tone on Jun 19, 2013 6:26:33 GMT 1
Post by dave1967 on Jun 19, 2013 19:19:36 GMT 1
Oh I see..so you cant fit those then till tail piece gies on?
Post by Yogi on Jun 19, 2013 21:15:41 GMT 1
Hi mate you fit the grab rail over the tail unit,then bolt both brackets to the grab rail through the tail unit and then bolt onto the frame all in one,hope this helps abit
