Post by chrisb3666 on Mar 24, 2013 17:42:55 GMT 1
And after......ignore the colour of my fingers, they have had a a very vigorous scrub and are back to normal! Attachments:
Post by chrisb3666 on Mar 24, 2013 18:22:35 GMT 1
Ha Ha , thanks, my wife just can't understand it but she is very patient, I have bits hanging up again waiting for the next coat of paint! Another bit of a setback today again. Brake bleed nipple sheared off on the rear caliper and one of the front caliper pistons is seized solid> Ah well, two steps forward, one step back!
Post by 4ce on Mar 24, 2013 20:48:29 GMT 1
Comming on great bounds Chris.
Post by Norbo on Mar 26, 2013 19:51:55 GMT 1
its coming together fast mate and looks like top job . cant wate to see it in the flesh at the ride
crip
Post by crip on Apr 1, 2013 20:41:46 GMT 1
Exactly! Everyone is different and if a resto is for show use only, I can sort of understand it, but my bikes are all restored to ride and if people like them, all well and good. If not, who gives a monkeys! Hear hear.... ;D
Post by steelerd on Apr 1, 2013 21:36:08 GMT 1
awesome job mate keep it coming
Post by chrisb3666 on Apr 3, 2013 10:31:09 GMT 1
Sorry haven't updated for a few days, family came first for a couple of days over Easter, quite right too! Anyway, got on with the engine rebuild on Monday, got it back from from Kevin with new pistons etc installed. Attachments:
Post by chrisb3666 on Apr 3, 2013 10:33:18 GMT 1
Got it back together but a couple of problems. One of the powervalve disc covers, usually held in by an allen head bolt, had been held in by a self tapper, obviously the original threads were stripped, and also.....
Post by chrisb3666 on Apr 3, 2013 10:35:19 GMT 1
......and one of the teeth of the water drive was snapped off, (actually, I'm sure I did it, as I heard a snap about 10mins after I had fastened the pump to the engine!), took it off and saw the break! Attachments:
Post by chrisb3666 on Apr 3, 2013 10:37:21 GMT 1
Never mind, onward and upward as they say!. New water pump drive ordered, new cables ordered, new bolts ordered for the cylinder head and barrels so all will be waiting on my return from jollies. Attachments:
Post by chrisb3666 on Apr 3, 2013 10:38:15 GMT 1
In the meantime, started fastening on the peripherals that won't get in the way of the engine refit.... Attachments:
Post by chrisb3666 on Apr 3, 2013 10:41:57 GMT 1
Also checked out the wiring harness, it is complete, everything accounted for (I think!) and a tidy up plus remove half a dozen of those crap blue connectors and replace with proper Japanese type connectors will have ready for refitting. So, although disappointed not to get the engine in, it has progressed and I have the sequence of events mapped out in my head to complete. While I'm away, has anyone had the problem of the powervalve cover before and how did you overcome it! Thanks Chris Attachments:
Post by Norbo on Apr 3, 2013 11:46:46 GMT 1
Sorry haven't updated for a few days, family came first for a couple of days over Easter, quite right too! Anyway, got on with the engine rebuild on Monday, got it back from from Kevin with new pistons etc installed. I hope you got some wire wool on them barrels befor you fitted the new gaskets and head i cal see loads of left over black from the old gaskets. If you need any bits getting in for it and i can help then just drop me a line and ill be more then happy to do what i can to save you a few quid on the build.
Post by copper99 on May 2, 2013 22:15:43 GMT 1
Hows the 500 coming along ?
The VIP will need ot be riding it in a few weeks eh?!
Post by Norbo on May 2, 2013 22:19:02 GMT 1
I was just thinking the same not long now .
Post by midlifecrisisrd on May 3, 2013 8:23:30 GMT 1
Watching this eagerly as my next job is a 500
Post by chrisb3666 on May 4, 2013 7:16:47 GMT 1
Hi Everyone, Not much progress to report I'm afraid! Had a couple of weeks away for the Qatar GP and I also forgot I was going to Imola the weekend after I got back to ride my RG500 in the Imola Miglia 200, great fun it was too! This weekend is now make or break. About to get stuck in to the bike, engine ready to go in so we'll see what I can get done over the next few days. I'll be posting latest pics tonight so fingers crossed no more unpleasant surprises, Cheers Chris
Post by Deleted on May 4, 2013 8:20:17 GMT 1
Good luck chris hope it comes on leaps and bounds this week end
Post by LC_BOTT on May 4, 2013 12:29:22 GMT 1
Not a lot of time left. hope you've had all the carbs cleaned and set-up correctly, they are a pain in the #### for this bike for some reason, always seem to be leaking and overflowing, no matter how many times they are stripped and cleaned.
Post by chrisb3666 on May 5, 2013 9:42:23 GMT 1
Hi, You're right of course, not long left and a mountain to climb! Anyway, engine went in yesterday, I have today and tomorrow to get the plumbing, electrics and cable run, then we'll see where we are at. LC Bott, I cleaned the carbs out yesterday, one was really gummed up but OK now, main jets are 250 rather than standard 195's as the bike had bespoke expansion chambers on, but also came with the standard exhausts. At the moment I'm going to put the standard exhausts back on but I need the 195 jets before the carbs can go on, but, enough to do anyway! I'll either post again tonight, or more likely tomorrow night and we'll see what progress has been made and if there is still a chance! Cheers Chris Attachments:
Post by chrisb3666 on May 6, 2013 20:19:35 GMT 1
Well, not a bad weekend, got a bit more done than what I expected to be truthful. Engine bolted in, electrics wired up and seem to be working after I briefly connected the battery off my 350YPVS (but needed charging, bit down on volts). I also ran the cables in and they all seem to be in the right places, new drive sprocket fitted and chain fitted, but link still needs to be crimped. Front exhausts painted and fitted, including silver painted end cans. Now the frustrating bits, couldn't fit the airbox and final routing of harness because the top radiator hose doesn't fit! I didn't want to fit the carbs because I need 195 main jets for the standard exhausts, which meant I can't final fix the cables and set the oil pump up. Still, I managed to strip the brakes down and I'll see if I can get a quick powder coating job done and if I can get the main jets and top radiator hose quick I'll be able to progress during the week a little, so not throwing the towel in just yet!
Post by chrisb3666 on May 6, 2013 20:32:27 GMT 1
For some reason the photos won't upload, I'll try again in the morning
Post by Norbo on May 7, 2013 8:54:04 GMT 1
The engin looks nice and clean and all back in place. i realy need to put a day on my bike for day . the valves are blowing oil every where. Sutch a small job half a day max to strip it all down clean and put back to gether but its finding the time . I admire the work you have done in the time you have had.
simch
Post by simch on May 12, 2013 9:50:27 GMT 1
Looking forward to seeing this done. Good cause too.
Post by chrisb3666 on May 14, 2013 14:09:17 GMT 1
Hi Again, I have been busy, honest, just haven't had time to upload updates! Anyway, here we go, Rear brake fitted.......just a decal to go on Attachments:
Post by chrisb3666 on May 14, 2013 14:11:00 GMT 1
and front brakes fitted, but new lines and bolts required, plus decal.... Attachments:
Post by chrisb3666 on May 14, 2013 14:12:10 GMT 1
Wiring harness and cables ran in.... Attachments:
Post by chrisb3666 on May 14, 2013 14:14:29 GMT 1
quite complicated to get the harness and cables in the correct places, but actually it has gone back together with not as much anxiety as I thought I was going to have! Attachments:
Post by marsbar350 on May 14, 2013 14:16:55 GMT 1
nice work chris are you on schedule sure bradders wouldnt mind the odd decal missing ;D
Post by chrisb3666 on May 14, 2013 14:26:06 GMT 1
HI, I'm sure Brad wouldn't mind but if the decal was all that was left I would be a very happy man! I think I can still get it running, whether I would be OK letting Brad ride it without a good testing is another matter! Anyway, let's see, I'm still waiting for the water pump gear drive to arrive from Singapore. If I get it done I can get it on a dyno which would give it a good run, Thanks Chris
