Post by chrisb3666 on Mar 19, 2013 9:25:18 GMT 1
I should also mention the fact that I'm colour blind so it absolutely really means the colour doesn't matter!
Post by Deleted on Mar 19, 2013 11:36:29 GMT 1
Looks great so far, Chris...
Post by lcrider on Mar 19, 2013 14:43:03 GMT 1
Turned out really well! Now, to lacquer or not??? Lacquer them its protection and makes then shine more
Post by chrisb3666 on Mar 19, 2013 17:26:34 GMT 1
Hi I did lacquer them in the end and they do look better for it. Bit more protection too as you say, let's see how they weather during the summer, not a big job to get them powder coated next winter if need be, Cheers Chris
Post by bryan on Mar 19, 2013 17:59:10 GMT 1
Turned out really well! Now, to lacquer or not??? you never have to polish the bloody things either.
Post by chrisb3666 on Mar 20, 2013 22:05:29 GMT 1
Painting underway again! Been away on business for a couple of days, forgot to factor in the non-productive days, which is usually Mon -Fri! Attachments:
Post by chrisb3666 on Mar 20, 2013 22:07:08 GMT 1
Forks inserted and looking quite good! Attachments:
Post by chrisb3666 on Mar 20, 2013 22:08:16 GMT 1
cylinders and head before. Attachments:
Post by chrisb3666 on Mar 20, 2013 22:10:53 GMT 1
I forgot how long it takes to actually mask off, but the best results follow the best preparation, so hopefully this prep is good! Attachments:
Post by chrisb3666 on Mar 20, 2013 22:13:26 GMT 1
Painted, not looking bad but need to remove the masking, that will reveal if the prep was good! Attachments:
Post by chrisb3666 on Mar 20, 2013 22:16:07 GMT 1
Casings primed Attachments:
Post by marsbar350 on Mar 20, 2013 22:17:24 GMT 1
goin at a fair rate of knotts here chris ;D
Post by chrisb3666 on Mar 20, 2013 22:17:15 GMT 1
..and painted Attachments:
Post by chrisb3666 on Mar 20, 2013 22:18:31 GMT 1
but I'm beginning to panic already at the work left to do! They are incredibly complex bikes.
Post by chrisb3666 on Mar 20, 2013 22:22:10 GMT 1
Oh dear, need to get stuck into this at the weekend! Actually the engine itself is fine, cranks very clean, so probably a refresh of the top end and back together. If I can get this done and in the frame over the weekend I will feel I actually have a chance! Attachments:
Post by marsbar350 on Mar 20, 2013 22:24:22 GMT 1
they look tricky to build ::)if i start rushing.i start making mistakes more haste less speed
Post by chrisb3666 on Mar 20, 2013 22:37:57 GMT 1
and this where I am at the moment. Once the front wheel goes in, I will then concentrate on getting the engine ready, I really want it in at the weekend. Then the serious plumbing and electrical work starts and all the other bits to go on but I still have the radiator to sort, the brackets for the oil tank, expansion tank etc and i forgot I'm away for the Qatar MotoGP followed by a jolly at Abu Dhabi! Two weeks out of the available time left and I absolutely forgot about it! Holy crap, there's not much time left!! Looks like a lot of late nights and early mornings! Attachments:
Post by copper99 on Mar 21, 2013 0:08:19 GMT 1
Cracking work mate...will keep an eye on this one with interest.
Post by chrisb3666 on Mar 23, 2013 21:51:07 GMT 1
Looking good, but a disaster this morning! Details to follow! Attachments:
Post by chrisb3666 on Mar 23, 2013 21:57:15 GMT 1
Started to refresh the top end this morning, plan was to have the engine in the frame by close of play today. Removed the rear pistons, in turn, and replaced the small end bearings, re-fitted and got to the front right piston and was disappointed to the state of it! I hadn't noticed before because I'd checked the cylinders as they came off and they were fine, so didn't suspect anything was wrong with the piston. Pleased I decided to check though, no matter the disappointment. Attachments:
Post by marsbar350 on Mar 23, 2013 22:00:29 GMT 1
bad luck chris can you get away with a hone ,new piston
Post by chrisb3666 on Mar 23, 2013 22:06:30 GMT 1
What to do now though? I'm away 3 days this week, then away for two weeks after Easter for the MotoGP and a jolly, running out of time. Time to jump in the van with the cylinder, piston and cylinder and hightail to Kevin Armstrong at Armstrongs, Westgate Road. Kev had a quick look, no problem, he can sort by next weekend for me. Full set of new pistons required, plus rings etc obviously but not the complete disaster I was thinking it was. Engine will be dropped off with Kevin Monday morning and hopefully picked back up on Wednesday when I return. Thanks Kevin! Attachments:
Post by marsbar350 on Mar 23, 2013 22:09:06 GMT 1
thats good news chris a bit expensive
Post by chrisb3666 on Mar 23, 2013 22:09:44 GMT 1
In the meantime, I'll drop back onto restoring and painting various bits and pieces, such as the radiator and clip ons. I need to have a good day tomorrow of getting the rolling chassis built up a bit more. Attachments:
Post by chrisb3666 on Mar 23, 2013 22:15:51 GMT 1
Got a bit done anyway after my mini-depression! Just means that the sequence of building I had in mind will change. Also, actually restoring original parts is so much more satisfying than just buying pattern parts and fitting! Nothing wrong with pattern parts if you can't get the originals or need to build to a budget. I'll post progress tomorrow evening, hopefully it will look quite substantial! Cheers Chris ps if any of you guys are on the other forums, would you mind posting a link to this in order to advertise the ride out, if that isn't breaking any protocol though. Attachments:
Post by chrisb3666 on Mar 23, 2013 22:19:01 GMT 1
Hi, It is good news and also expensive, but I will be keeping the bike so it is the right choice to replace the lot with a decent set. Cheers
Post by chrisb3666 on Mar 24, 2013 17:35:33 GMT 1
This is where I am at the moment. I really need to get the engine in and start working around it. I have it in the back of the van to drop with Kevin in the morning, hopefully I'll have it back for the weekend. Attachments:
Post by chrisb3666 on Mar 24, 2013 17:37:08 GMT 1
Front view Attachments:
Post by chrisb3666 on Mar 24, 2013 17:37:53 GMT 1
Rear view Attachments:
Post by chrisb3666 on Mar 24, 2013 17:39:02 GMT 1
Front fairing mounting bolts before...... Attachments:
