Post by peter007 on Nov 4, 2018 16:48:26 GMT 1
Stripped the head and barrels off my 350 4LO Ready to lift bottom end out now for a full rebuild ! 🤞
Post by Tobyjugs on Nov 4, 2018 17:56:57 GMT 1
Beautiful job on the pipes Tobyjugs, may i ask whose work? Mouse The pipes were made by PS Tuning, The pipe plan came from Kenny. I asked Piet for compactness as you won't see them when the fairing is in place. Piet is well known for very good 50 cc race and sprint pipes. I asked Kenny for a plan and asked Piet gingerly if he would make them to that spec. Tuners are a rare and delicate species and have to be handled with respect!!!
Post by mouse on Nov 5, 2018 8:09:05 GMT 1
Beautiful job on the pipes Tobyjugs, may i ask whose work? Mouse The pipes were made by PS Tuning, The pipe plan came from Kenny. I asked Piet for compactness as you won't see them when the fairing is in place. Piet is well known for very good 50 cc race and sprint pipes. I asked Kenny for a plan and asked Piet gingerly if he would make them to that spec. Tuners are a rare and delicate species and have to be handled with respect!!! Well he has made a beautiful job, quite something to get someone to build something from somebody else's design, well done you! Mouse
Post by Yogi on Nov 5, 2018 18:40:32 GMT 1
I sent my bike away to get some pipes made. I think i sent it to the snake charmer by accident. Well he certainly did charm them
Post by marsbar350 on Nov 9, 2018 21:48:37 GMT 1
took the 392 down to nk racing for some brake caliper adaptor brackets forgot the new calipers post on monday
Post by donkeychomp on Nov 9, 2018 23:25:37 GMT 1
Got my engine casings back from being vapour blasted. Wow what a difference!
Post by alankelly on Nov 9, 2018 23:46:58 GMT 1
Painted barrels and head👍
Post by ian350n on Nov 10, 2018 10:31:31 GMT 1
Hi ive managed to get the brake calipers apart and get the very stuck pistons out.Also got the discs off the wheels with some extreme violence(from previous butchery).
Post by stusco on Nov 10, 2018 10:32:31 GMT 1
It’s only 09:30 just had my breakfast
Post by mikee on Nov 10, 2018 11:01:26 GMT 1
Still in bed , but it’s sunny 😎
Mike
Post by firmstools on Nov 10, 2018 19:04:58 GMT 1
Left the LC out in the rain all day, But its for a good cause, having the garage floor tiled today
Post by Dangerous on Nov 10, 2018 22:24:21 GMT 1
Just looked at it and realised how much I love the thing.🏍🏍🏍😁
Post by hudtm60 on Nov 11, 2018 18:09:30 GMT 1
first step of rebuild: after giving the cases (another because I couldn't remember if I already did it) good bath and blow out, installed sump plug with new washer....was going to launch into the rest of it....but think I should get the gearshift bush installed while it's in pieces...it's a struggle because part of me says it should be untouched, all original, nothing changed or added..yet I've already got it rebored, got new Mikata's and a PJME crank on the shelf AND I've (poorly) repainted it.... and I wonder why I can't get on with anyone but the dog.
Post by alankelly on Nov 12, 2018 21:02:46 GMT 1
Cured paint on barrels in the family oven while all are out👍
Post by Tobyjugs on Nov 13, 2018 22:57:01 GMT 1
Thought i would make another +4 4LO crank but when i opened up the donor crank i found the center pin was an integral part of the inside crank webb. Bugger!!! Oh well plan B Left is +4 crank webb right is 4LO crank webb with removable center pin.
Post by donkeychomp on Nov 13, 2018 23:26:32 GMT 1
Cured paint on barrels in the family oven while all are out👍 Very sneaky but I like it Alex
Post by mt on Nov 18, 2018 16:53:29 GMT 1
Post by stusco on Nov 18, 2018 17:11:11 GMT 1
Finished painting rg engine ready to put together after two crank rebuilds and a big bore kit ,pockets now empty !!and that’s only half the engine done!,
Post by ian350n on Nov 18, 2018 20:56:02 GMT 1
Amazed it would even start
Post by mattybeckett on Nov 18, 2018 21:10:13 GMT 1
Amazed it would even start Hopefully you had the brass balls out at the same time and cleaned the passage ways 👍
Post by mt on Nov 18, 2018 21:58:57 GMT 1
Amazed it would even start Hopefully you had the brass balls out at the same time and cleaned the passage ways 👍 No I didn’t. How do they come out ?
Post by Yogi on Nov 18, 2018 22:04:23 GMT 1
Swapped the whole bike on to a different frame and swinger
Post by doohanno1 on Nov 18, 2018 22:33:54 GMT 1
Amazed it would even start Hopefully you had the brass balls out at the same time and cleaned the passage ways 👍 Jeez , i thought that was a picture from " Dynorod " monthly..
Post by donkeychomp on Nov 18, 2018 22:53:13 GMT 1
Love that paintwork Yogi!
Post by mattybeckett on Nov 19, 2018 0:06:39 GMT 1
Hopefully you had the brass balls out at the same time and cleaned the passage ways 👍 No I didn’t. How do they come out ? Drill a small hole in them and screw self tapper in, then prise out with pliers .
Post by hudtm60 on Nov 23, 2018 0:41:26 GMT 1
daily(ish) rider....no garage queen.
Post by markhoopy on Nov 23, 2018 19:16:15 GMT 1
Popped it outside to get it started and warmed through as we do every month. Ten minutes later and it's ticking over nicely .. noticed water dripping from somewhere behind the radiator Looks like the head gasket might need changing as the water was coming from the header tank unfortunately. With only 109 miles put on the clock over the last five years it could well be time for a new owner come springtime. By far the nicest model 350 YPVS, water leak or not
Post by sparx on Nov 23, 2018 19:32:37 GMT 1
Doesn’t do them any good that standing lark. My hybrid did less than 250 miles this year So mine will be going too
Post by hudtm60 on Nov 23, 2018 23:18:15 GMT 1
got the bush installed....
Post by donkeychomp on Nov 24, 2018 1:24:29 GMT 1
Nada. So cold in the workshop!
