YPVS 350 F2 Crank Cases Required Sept 16, 2012 17:45:46 GMT 1 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by Madasahatter on Sept 16, 2012 17:45:46 GMT 1 After a full engine rebuild i found a small oil leak See hearrdlccrazy.proboards.com/index.cgi?board=general&action=display&thread=17418Tuns out it seems to be leaking thru the bearing jornals looks porusIm in desperate need of a set of casingsSo if there are any out there for sale.. i'm your man
YPVS 350 F2 Crank Cases Required Sept 18, 2012 16:41:48 GMT 1 Quote Select PostDeselect PostLink to PostMemberGive GiftBack to Top Post by Madasahatter on Sept 18, 2012 16:41:48 GMT 1 Cheers Butch, appreciate all your help ;D ;D ;D
