davslc
Post by davslc on Dec 30, 2011 17:32:50 GMT 1
made a start on the wheels ,going satin black and polished
davslc
Post by davslc on Dec 31, 2011 17:02:46 GMT 1
Post by billy on Dec 31, 2011 23:24:28 GMT 1
Looking good as usual. I hate doing wheels, I got a set of wheels to paint but the mere thought of doing it is bloody depressing lol. It's well worth the effort afterwards though.
davslc
Post by davslc on Jan 1, 2012 10:28:53 GMT 1
Looking good as usual. I hate doing wheels, I got a set of wheels to paint but the mere thought of doing it is bloody depressing lol. It's well worth the effort afterwards though. i know mate got back one to do yet but then its rolling ;D
Post by Norbo on Jan 1, 2012 11:02:20 GMT 1
I love the blue spring on the shoker
davslc
Post by davslc on Jan 1, 2012 16:27:01 GMT 1
davslc
Post by davslc on Jan 2, 2012 19:07:27 GMT 1
well all wiring done everything works with exception to side light front and rear brake light but i cant test that as pedal not fitted yet ,even new led indicators work at right speed but the flasher unit has an annoying bleep . will have to disconnect this somehow
davslc
Post by davslc on Jan 5, 2012 20:12:54 GMT 1
finally got round to doing rear wheel ,what a nightmare had to nitromorse it back to bare metal as it had around 6 coats of different paints on it ,any way all done now , decided on polishing brake drum rather than paint (i know it isnt up to your standards on here ) but believe me its mint to what it was so its now rolling ;D ;D ;D ;D ;D i know its got a lump out of it but just wanted to get it back on its wheels may get another one later on
Post by Norbo on Jan 5, 2012 20:28:07 GMT 1
LOL I remember doing all the lettering in on my bikes all them years back . i still think it looks good .
davslc
Post by davslc on Jan 5, 2012 21:41:59 GMT 1
thats the idea mate brings back lots of past memories ,sat doing it LOL
Post by billy on Jan 5, 2012 23:43:32 GMT 1
Nice work. I also like white letters on tires lol, I think it looks nice.
jackup
Of all the things I've lost I miss my mind the most
Post by jackup on Jan 6, 2012 2:12:10 GMT 1
You need to ditc that k&n for a standard air box
davslc
Post by davslc on Jan 6, 2012 6:56:27 GMT 1
You need to ditc that k&n for a standard air box possibly will do mate ,but this is the set up it came on so will see how it runs when i get to that stage and go from there ,it has fibre reeds so think they are an upgrade a and looks like its had some mild porting so not sure if it will run standard air filter cheers dav
davslc
Post by davslc on Jan 6, 2012 17:43:18 GMT 1
all fluids in and no leaks as yet just need some petrol/oil mix and see if it starts
Post by ozzy on Jan 6, 2012 18:31:44 GMT 1
nice work..
davslc
Post by davslc on Jan 6, 2012 19:08:40 GMT 1
thanks
davslc
Post by davslc on Jan 9, 2012 19:58:19 GMT 1
well decide to go down the red route so here is my first panel painted ,will get it all painted then flat it ,fit to bike to decal up the laquer over . ;D and yes it is dry
Post by Deleted on Jan 10, 2012 1:02:08 GMT 1
looking good, well done, just one question, ive heard a few people talk about flatening after painting, this is probably a bit of a dumb question, but what the hell does it mean? is it a light rub with something? if you could be so kind to give me some sort of procedure for this. i want to start doing my own painting, thanks
davslc
Post by davslc on Jan 10, 2012 6:59:48 GMT 1
Hi Ken when painting i always flat between coats using 1000 grit wet and dry paper, this consists of water with a small amount of washing up liquid in and wet sanding using the 1000 grit paper taking care on the edges not to rub through the paint ,try and get as much of the orange peel out as possible (this is paint that has little dimples looks like an orange skin ) then keep reapplying coats until happy ,then flat the finished paint with the water solution and 2500 wet and dry ,then polish to a finish using a rubbing compound tcut could be used for this but i use 3m finishing polish .
do not apply any silicone based polish for at least 2 weeks after finishing as the paint needs to cure and breath.
But a good paint job is all in the preperation.
hope this helps dav
Post by Deleted on Jan 10, 2012 7:10:25 GMT 1
thanks for that dav, very helpfull, when you are rubbing back with the wet and dry ,is it in any particular pattern, like circles or just up and dwwn, thanks and have some karma
davslc
Post by davslc on Jan 10, 2012 7:36:09 GMT 1
Thanks one direction only mate , works for me but i am sure someone more experienced will be along and correct me if i am wrong back at ya
Post by gerumgoin on Jan 10, 2012 10:18:14 GMT 1
Hi mate,how many coats do you generally like to put on?also when using celulose paint i had a go on a gs125 tank and did 50/50 in my gloss black,do you ever use more thinners on the last coat
davslc
Post by davslc on Jan 10, 2012 10:41:10 GMT 1
Did these out of aerosol but when I use the gun on celly 50/50 then add an extra 10% thinners for last coat ,like to use 2 pack normally.
These have had three coats of primer ,two mars red then three ford radiant red will get about three coats of lacquer once decals are on.
Post by gerumgoin on Jan 10, 2012 13:50:26 GMT 1
Nice to know mate cheers,when the weather gets better i will start spraying again,lol i got to laugh but since dad wanted some projects to do with me after i was laid off,we have built a new outhouse and in the middle of building a place to spray up his garden. started off 5 gpz500s, 1 gpz400 ninja, 1 sr125, 4 cg125, 3 gs125 still got one left,and atm belive it or not 9 RD125 frames with v5 not enough parts to go on them lol,and 2 mbx125,plus 1 mbx125 framefuk knows whats going to happen when i get a job again,WHEN . ;D
davslc
Post by davslc on Jan 10, 2012 18:31:21 GMT 1
started off 5 gpz500s, 1 gpz400 ninja, 1 sr125, 4 cg125, 3 gs125 still got one left,and atm belive it or not 9 RD125 frames with v5 not enough parts to go on them lol,and 2 mbx125,plus 1 mbx125 framefuk knows whats going to happen when i get a job again,WHEN . ;D with all that lot you aint got time for a job LOL and if you get em done wont need a job for a while
davslc
Post by davslc on Jan 11, 2012 18:27:45 GMT 1
2 days on 2nd side panel now god knows how many coats of paint its had i know its been white twice black twice red three times day glow orange once day glow lime green once yellow lilac just about got the primer right will be ready for paint tomorrow all being well ,then on to tail piece
Post by Fingermaus on Jan 11, 2012 21:55:47 GMT 1
This build is fantastic Dav.Really like what you've done so far. Top work with the paint too.
I work in Normy.Useless but true fact.
Post by Deleted on Jan 11, 2012 22:20:19 GMT 1
funny thing that ,with all the previous colours, the bloke who painted mine said mine had been white twice,blue twice,yellow and red plus it still had 2 sets of decals on it. with the last paint job the stripes and yamaha logo were painted on aswell. but it ended up very good.
davslc
Post by davslc on Jan 12, 2012 7:28:38 GMT 1
cheers fingermaus and Ken that looks very clean mate ,nice job
davslc
Post by davslc on Jan 12, 2012 17:44:44 GMT 1
front mudguard done and ready for final flat ;D also painted the black on the side panel flatted and stickered ready for lacquer then one panel done
