iainw
Post by iainw on Dec 7, 2011 15:26:53 GMT 1
Does anyone know where I can get these from or have the Yamaha part number? Mine has none in and the gap is closed.
It's an '81 350LC whith a 4L1 mark on the pump.
Post by Norbo on Dec 7, 2011 15:49:47 GMT 1
This will be the very small one at the botomif the pump spline yes .
Post by arrow on Dec 7, 2011 17:10:12 GMT 1
I make my own. Any correct size washers will do. Just rub them down on a sheet of 600 wet/dry to get the thickness you require. Just done a pump for a club member, the gap was minus 0.13mm! Ie a had to make a 0.39mm shim to get a gap of 0.25mm if that makes sense.
Post by Tone on Dec 7, 2011 17:55:29 GMT 1
If you mean the shims to alter the minimum stroke the parts numbers are 137-13137-00-03 which is .03mm or about 1 thou thick 137-13137-00-05 which is .05mm or about 2 thou thick 137-13137-00-10 which is .1mm or about 4 thou thick You should be able to get these from most big Yam dealers Tony
Post by arrow on Dec 7, 2011 18:07:44 GMT 1
Just to be clear, the first 2 are 0.3mm and 0.5mm thick. Can't comment on the last one, never seen them.
iainw
Post by iainw on Dec 7, 2011 18:54:55 GMT 1
They're the ones though I couldn't find any in the LC shop. The Haynes manual says the gap should be 0.15mm, mines fully closed and there's no shims in there. I've just tried a small washer and gapped it at 0.2mm so here goes with the wet and dry! Thanks for the tip Arrow.
Post by arrow on Dec 7, 2011 19:58:56 GMT 1
Leave it at 0.2 matey. No problem.
Post by Tone on Dec 7, 2011 20:23:51 GMT 1
I've just measured the ones I've got with my digital vernier and they all measure as my reply i.e .03mm , .05mm and .1mm. If they were .3mm and .5mm they would be 12 thou and 20 thou thick !! If you multiply mm by 4 you get the equivalant in thou i.e spark plug gap of 0.7mm = 28 thou. iainw, are you making sure the plunger is right out to it's limit before measuring. I usually watch the plunger with the bike ticking over and hit the kill switch when its right out and check it several times to make sure its out to its limit. Tone
iainw
Post by iainw on Dec 7, 2011 20:48:27 GMT 1
I've just measured the ones I've got with my digital vernier and they all measure as my reply i.e .03mm , .05mm and .1mm. If they were .3mm and .5mm they would be 12 thou and 20 thou thick !! If you multiply mm by 4 you get the equivalant in thou i.e spark plug gap of 0.7mm = 28 thou. iainw, are you making sure the plunger is right out to it's limit before measuring. I usually watch the plunger with the bike ticking over and hit the kill switch when its right out and check it several times to make sure its out to its limit. Tone The Haynes says they are available in 0.03 and 0.05mm. Pump's off the bike. I've got it in my hand and I'm turning the gear with my pinky in the hole. It runs with no gap, but when I put an ordinary washer in I get the gap to 0.2mm at its widest.
Post by arrow on Dec 7, 2011 21:00:25 GMT 1
The motor will be far better off left on the 0.2mm gap. My haynes manual states 0.3 and 0.5 for the shims, as does the Yamaha parts book.
Post by arrow on Dec 7, 2011 21:11:33 GMT 1
Also check the engine number for the correct gap. Only engine numbers prior to 4LO100101 have the smaller spec. gap. HTH.
Post by arrow on Dec 7, 2011 21:19:37 GMT 1
See pic. Attachments:
Post by oldelsieboy on Dec 7, 2011 21:30:18 GMT 1
Also check the engine number for the correct gap. Only engine numbers prior to 4LO100101 have the smaller spec. gap. HTH. Surely thats only relevant if the bike is completly standard as it left the factory, original early barrels, carbs, oil pump etc. OEB
iainw
Post by iainw on Dec 7, 2011 21:32:03 GMT 1
That's right, mines an '81 engine No 4L0-1014xx, so gap is reduced to 0.15mm.
I can now get it to 0.2mm, you reckon that's near enough and OK?
Post by arrow on Dec 7, 2011 21:32:14 GMT 1
Sure, but how would you determine the correct gap due to any modyfications ?
Post by arrow on Dec 7, 2011 21:34:20 GMT 1
That's right, mines an '81 engine No 4L0-1014xx, so gap is reduced to 0.15mm. I can now get it to 0.2mm, you reckon that's near enough and OK? You should be on the later (larger) gap then.
Post by Tone on Dec 7, 2011 21:43:35 GMT 1
On the very first LCs the standard minimum stroke was 0.15 - 0.2mm or 6 - 8 thou but Yamaha sent out a bulletin to its dealers to reduce this down to 0.1 - 0.15mm 0r 4 - 6 thou and to make a new full throttle mark on the pulley 4mm down from the original as some of the bikes had an over oiling issue and were fouling plugs.
iainw
Post by iainw on Dec 7, 2011 21:44:14 GMT 1
That's right, mines an '81 engine No 4L0-1014xx, so gap is reduced to 0.15mm. I can now get it to 0.2mm, you reckon that's near enough and OK? You should be on the later (larger) gap then. One of us is misunderstanding the book. "...gap should be 0.20-0.25mm on unmodified 1980 models. In the case of the modified 1980 machines and all 1981 versions, engine numbers 4L1 100101 (250cc) or 4L0 100101 (350cc) onwards the setting is reduced to 0.15mm." The later gap is smaller, not larger.
Post by arrow on Dec 7, 2011 21:46:27 GMT 1
Hang on a mo, I'll get a decent pic from the book.
Post by arrow on Dec 7, 2011 21:49:56 GMT 1
Here; Attachments:
iainw
Post by iainw on Dec 7, 2011 21:51:05 GMT 1
Thanks for all the replies chaps! You've been very helpful, lots of good advice from everyone.
I'm going to take that washer down until the gap is 0.15mm, wot it says in the book.
Cheers, Iain
Post by Tone on Dec 7, 2011 21:53:50 GMT 1
Just had a look in my Genuine Yamaha workshop manual and your right as you say the original ones were set to 0.20-0.25mm or 8 to 10 thou.
Post by arrow on Dec 7, 2011 22:01:06 GMT 1
Later modded to 0.15 then modded again later to the standard 0.2~0.25.
Post by Tone on Dec 7, 2011 22:19:59 GMT 1
Didn't think they went back up to 0.2 - 0.25mm. As iainw says and the Genuine Yamaha data book I have says engine number 4L1/4L0-100101 and on the pump minimum stroke is set to 0.1-0.15mm (4 to 6 thou) as standard.
Post by arrow on Dec 7, 2011 22:30:48 GMT 1
Ok thanks for that can we agree to differ ? And can I give you some figures on the air cooled bikes, I suspect the lc's are much the same. The aircooled 250 pump kicks out about 80:1 at tickover revs. This becomes about 20:1 at full bore. Now some of the guy's run there bikes on premix 30:1 or 25:1 in some cases and the engine loves it, so why run on 80:1 ? It was all to do with emissions at the time I gap both my pumps big, the aircooled is on about 0.4mm this will give around 45~50:1 at tickover far better IMO. This also gives more oil at partial throttle settings. Full speed oiling is unaffected of course. The engine loves it and does not have excessive smoke. The modern oils take care of this latter fact very well. Moral of the story; chuck as much oil through the motor as you can get away with. If the engine is in good nick it will not have a lot of smoke. It will last longer and run better. We could not do this years ago with the crap oils, for obvious reasons.
Post by nikfubar on Dec 8, 2011 13:10:07 GMT 1
Just to be clear, the first 2 are 0.3mm and 0.5mm thick. Can't comment on the last one, never seen them. Think you will find Tone was correct 0.03 NLA 0.05 & 0.1mm I tried to get the 0.03mm ones to correct my setting & they kept getting 0.003, subsequently found the 0.03 are NLA
Post by arrow on Dec 8, 2011 13:49:19 GMT 1
What do you mean they kept getting 0.003 ?
Post by nikfubar on Dec 8, 2011 14:12:35 GMT 1
Three times I ordered the 0.03mm shims & 0.003 ones kept arriving, after this I asked them to find out what was going on & they came back with, they had been sent the 0.003 as the 0.03 were NLA & suggested I used 10 of them to get the clearance I needed, t**ts so I did as you suggested & sanded down a thicker one.
Post by arrow on Dec 8, 2011 14:15:45 GMT 1
0.003mm is 3 microns. A ciggy paper is 30 microns. If a 3 micron shim did exist me thinks only NASA would be using them.
Post by nikfubar on Dec 8, 2011 14:22:56 GMT 1
It is the thickness of a fag paper
