Post by Tone on Dec 8, 2011 14:27:04 GMT 1
Hi nik As arrow says are you sure they were that thin? The ones I have are .03mm, .05mm and 0.1mm which is the same as 1 thou, 2 thou and 4 thou. Tone
Post by nikfubar on Dec 8, 2011 14:32:13 GMT 1
I've proberbly f**ked up here maybe it was 0.3mm I was after & they sent me 0.03mm. It was a while ago & the old memorys not what it used to be ;D
Post by arrow on Dec 8, 2011 14:33:13 GMT 1
The plot thickens. Here is a gen Yam 0.5mm shim that I sanded down a bit on a previous occasion. Attachments:
Post by arrow on Dec 8, 2011 14:37:15 GMT 1
I've proberbly f**ked up here maybe it was 0.3mm I was after & they sent me 0.03mm. It was a while ago & the old memorys not what it used to be ;D Hey, no worries, whats a ciggy paper between friends..
Post by nikfubar on Dec 13, 2011 16:24:38 GMT 1
Sussed it now it was the 0.3mm shims I was after which are apparently NLA & it was the 0.03mm ones which they kept sending which incidently are the same thickness as a green ciggy paper (I measured )
