webbo
Post by webbo on Dec 6, 2011 23:38:58 GMT 1
As I have finally got my LC after a 30 year gap I thought I'd better start a rebuit thead. Bought from Poland, originally from Germany. Piston exploded and owner took head and barrel off decided it was too much to repair and spent the last 10 years n a garage.Looked like this when I got it Spent a few evenings over the last couple of weeks dismantling and the barrell was badly scored And the crank has a bent rod and will need a rebuild. Hoping that I can save the webs. This how it looks now. Will post more pics as it goes on. Cheers Webbo
Post by JonW on Dec 7, 2011 0:05:09 GMT 1
good start! interested to see what youre going to do...
Post by Norbo on Dec 7, 2011 11:06:04 GMT 1
Well at least the tubs are nice and new
Post by JonW on Dec 7, 2011 12:10:54 GMT 1
I have lids on most of my tubs now... keeps the spiders out
Post by marsbar350 on Dec 7, 2011 13:43:41 GMT 1
brings back memories! bike bits all over the garage come to think of it,still the same now
Post by billbott on Dec 7, 2011 13:48:00 GMT 1
Well at least the tubs are nice and new ;D
webbo
Post by webbo on Dec 7, 2011 14:50:20 GMT 1
Good news! ;D I had my barrels re bored to see if they were salvageable as I was let down on some replacements and they are serviceable. Just need to sort the crank now. Is it best to rebuild or exchange? Cheers.
Post by lcowner on Dec 7, 2011 15:28:47 GMT 1
i think its cheaper and less of a headachs to exchange
webbo
Post by webbo on Dec 7, 2011 18:29:25 GMT 1
Well at least the tubs are nice and new Unlike the rusty old shit in them! ;D Sat down last night and wrote a list of what I wanted to do, costed it up..........then wrote another list of what I can afford to do All good fun though!
Post by 1260dave on Dec 7, 2011 23:13:37 GMT 1
Well at least the tubs are nice and new Unlike the rusty old shit in them! ;D Sat down last night and wrote a list of what I wanted to do, costed it up..........then wrote another list of what I can afford to do All good fun though! you will spend what you originaly costed, ha ha he he
webbo
Post by webbo on Dec 11, 2011 19:02:15 GMT 1
Still stripping bits apart. Come to a bit of a problem, the tops of the fork have had water ingress and I have got 1 clip out and the other has rusted away but the plugs wont come out, any Ideas anyone? Cheers.
Post by billy on Dec 14, 2011 17:03:36 GMT 1
Still stripping bits apart. Come to a bit of a problem, the tops of the fork have had water ingress and I have got 1 clip out and the other has rusted away but the plugs wont come out, any Ideas anyone? Cheers. Remove the bolt at the bottom of the fork leg and pull the lower leg/s off. Then use a long, 5 mm steel rod (maybe a 6 mm will work aswell, not sure) and stick it through the hole at the bottom of the stanchions (the same hole where the M8 allen bolt for the lower legs should go) until it reaches the inside of the top plug, then tap like mad. You can make it with a shorter rod aswell, (it won't get stuck in the spring area or anything) but then you gotta "slam" the bugger in so it hits the top plug from behind. I used a rod that were some 50 cm long. I'd use a longer one if I could but that's all I had at the moment.
webbo
Post by webbo on Dec 15, 2011 0:21:03 GMT 1
Thanks for that Billy. I'l give it a go tomorrrow.
webbo
Post by webbo on Jan 16, 2012 23:40:33 GMT 1
Bit of an update. Finally got the forks apart. Polished the bottems and rebuilt them. Loads of bits being powder coated, re zinced and been spending money left right and centre!. Just got these back today!! Like new just waiting for a crank from Norbo and then I can rebuild the engine.,....Can't wait.
Post by shane2011 on Jan 16, 2012 23:53:41 GMT 1
hi webbo youre getting on really well with your rebuild!!
webbo
Post by webbo on Jan 31, 2012 19:16:39 GMT 1
Much excitment in the Webbo garage! Picked up powder coated stuff and the rest of my vapour blasted bits! Frame looks great, nice job on all the bits with all the treads protected and gasket surfaces kept clean. Also popped into Fowlers and bought some bits as I was in such a good mood. ;D Going to polish the wheels and paint them as original. Just waiting for some bits that I'm having rezinced and my crank and some bits from Norbo! I 've found a pair of original pipes that I have rubbed down and sprayed, then rubbed the runs out and re sprayed again I'm still on the hunt for a speedo or clock set. Couple of pics of me shiney bits!
Post by arrow on Jan 31, 2012 19:28:40 GMT 1
Its nice when you get the parts back and they look like that.
Post by andyburts on Jan 31, 2012 22:39:53 GMT 1
your about 3 weeks ahead of me :-) ... im waiting for zincky bits , n powdery bits , had me bore n pistons , but not stipped bottom end yet ... looking at your casings im thinking vapour blast too ( if thats what you had ? _ ,, cracking thread .... looks like its all coming together a treat ..... what colour scheme are you going with ??
webbo
Post by webbo on Jan 31, 2012 23:26:20 GMT 1
The bike was origanally white/blue so hats what it's going back to. It's worth vapour blasting the cases but beware! You will end up buying new bolts etc for them 'cos the old ones will let the overall appearance down. I've found that the bits that I thought were ok to reuse with a buff up just don't cut the mustard! So its new bits or re paint/powder coat, re zinc etc. I've stopped adding up the money
Post by tunneruk on Feb 1, 2012 8:22:13 GMT 1
Looking good fella! It's amazing how quickly the big lumps go back together and just as amazing how many little jobs take up all the time! I thought you were going to have a go at the wheels yourself? Seeing it all in bits takes be back to when mine was at that stage.... (All the way back to the beginning of December LOL)
Don't talk to me about the money ...................
webbo
Post by webbo on Feb 1, 2012 12:05:49 GMT 1
I am doing the wheels myself but the only paint stripper you can buy now is crap and didn't touch them so decided to get the vapour blasted. Just got lots of polishing and masking to do now
Post by tunneruk on Feb 1, 2012 13:40:30 GMT 1
I am doing the wheels myself but the only paint stripper you can buy now is crap and didn't touch them so decided to get the vapour blasted. Just got lots of polishing and masking to do now Ah I see, they look like they're painted white in the photo. Looks like you're doing a proper job fella! Nice one, I love rebuild threads ;D
webbo
Post by webbo on Mar 4, 2012 22:59:44 GMT 1
Well after a bit of diversion due to a 50th birthday and a weeks snowboarding I have go back into the rebuild this w/end. Managed to finish the engine ;D probably the most satisfying part of a bike rebuild, Also started putting the backend together, And got all my green bits back, I started to do the wheels myself but just haven't got the time to do them so the people I used for the rest of the powder coating etc are finishing them for me. Still got a list as lomg as me arm to buy, clean, polish, paint etc! Loving it though. ;D ;D ;D
Post by arrow on Mar 4, 2012 23:09:34 GMT 1
Lookin' good dude, the motor looks like a new'un.
dazaha350
wild side of life
Post by dazaha350 on Mar 4, 2012 23:16:36 GMT 1
nice job, love watching these come together
Post by marsbar350 on Mar 4, 2012 23:18:12 GMT 1
thats a crackin rebuild webbo give norbo the hurry up ;D and be on the road soon
Post by marsbar350 on Mar 4, 2012 23:21:19 GMT 1
whats the bike on the bench? not a X7 is it
webbo
Post by webbo on Mar 5, 2012 8:55:00 GMT 1
Well spotted! 'Tis indeed a '79 X7. I bought it as is. It's been rebuilt but just needs a few bits replacing to finish it as a very tidy rideable bike. All I need now is an aircooled RD to finish my set. ;D ;D
Post by billy on Mar 9, 2012 23:32:31 GMT 1
Aaahhhh, nice project. I love the green stuff!
Post by Deleted on Mar 10, 2012 11:18:24 GMT 1
Looks very nice its great when shinny things come back from the painters
