avb
andys vapour blasting
Post by avb on Apr 11, 2024 10:29:43 GMT 1
I've tried fitting a F2 rear mc to an lc frame but its fouling the return spring The hanger is spaced 12mm and used norbos mounting plate Any ideas on a fix Thanks Andy
Post by headcoats on Apr 11, 2024 10:45:29 GMT 1
I had a game with mine and used a thinner spring (doesn't need a strong return spring) Seen some where the actual spring goes over the rod
Post by midlifecrisisrd on Apr 11, 2024 10:50:01 GMT 1
I welded a tab onto the pedal to move the spring over Steve
Post by lcmarky on Apr 11, 2024 11:26:35 GMT 1
avb
Post by avb on Apr 11, 2024 12:02:02 GMT 1
Using the metmachex arm means there's even less room
Post by lcmarky on Apr 11, 2024 12:27:43 GMT 1
Using the metmachex arm means there's even less room I've spaced my footrest assemblies out so manage the lack of space.
Post by tony2stroke on Apr 11, 2024 14:11:50 GMT 1
Change the spring for a slimmer 1, it won't have to travel as far, so doesn't need to be so fat now with the new set up.
Post by headcoats on Apr 11, 2024 16:07:14 GMT 1
Post by headcoats on Apr 11, 2024 16:20:58 GMT 1
Looks like a YPVS master cylinder too
avb
Post by avb on Apr 12, 2024 12:20:28 GMT 1
Hopefully took a few cardboard cuts and welded this on
Post by JonW on Apr 13, 2024 9:09:12 GMT 1
Looks like a YPVS master cylinder too I like that! Easy to make as well
Post by headcoats on Apr 13, 2024 10:48:59 GMT 1
My only thought would be, would that spring cut into the rubber shroud over time 🤔
Post by midlifecrisisrd on Apr 13, 2024 11:06:46 GMT 1
That was my thought
I'd want to make a fitting on the lathe to locate the sping onto the body, not the rubber shroud
