Post by masonmart on Mar 29, 2023 17:01:41 GMT 1
I bought my F1 partly restored and an finding out now that apart from some nice painting on tank and panels it is really partly restored. I've just spent a few hours separating the front callipers and master cylinder from the 2 front callipers, all the bolts are painted or just seized solid but something seems odd. I believe that the shoes for the 57V should be held in by two pins but they are actually held by a larger diameter bolt with an Allen key head. All of these were seized, all of the cylinders are seized. Are these possibly wrong for the bike. The callipers have been held fast in various vices and look pretty rough compared with how I want this bike to be.
Post by midlifecrisisrd on Mar 29, 2023 18:00:22 GMT 1
Everything after the 83/84 bikes used the caliper with the single pad pin
Post by masonmart on Mar 29, 2023 18:44:21 GMT 1
Everything after the 83/84 bikes used the caliper with the single pad pin Steve Thank you Steve. My parts book for the 57V shows two pins though, Could it be that mine is a Euro model?
Post by jon on Mar 29, 2023 18:53:17 GMT 1
Everything after the 83/84 bikes used the caliper with the single pad pin Steve Isn’t that the other way round, or am I missing the point? Jon
Post by Shytalk on Mar 29, 2023 18:55:24 GMT 1
Everything after the 83/84 bikes used the caliper with the single pad pin Steve Thank you Steve. My parts book for the 57V shows two pins though, Could it be that mine is a Euro model? F1 calipers do have 2 pins, and 2 pistons, so you have the wrong ones on there, single central pin is presumably from the earlier LC2 - it might be that you have the wrong fork lowers if that's the case too, as the brakes have differing spacings for the fork fixings, as ever pictures provide the best evidence.
Post by Shytalk on Mar 29, 2023 18:56:11 GMT 1
Everything after the 83/84 bikes used the caliper with the single pad pin Steve Isn’t that the other way round, or am I missing the point? Jon Steve's having a senior moment bless him,
Post by midlifecrisisrd on Mar 29, 2023 19:02:26 GMT 1
Everything after the 83/84 bikes used the caliper with the single pad pin Steve Thank you Steve. My parts book for the 57V shows two pins though, Could it be that mine is a Euro model? Sorry, its been a long day lol Yes 2 pins with allen key heads. I was getting confused with the older calipers with the 2 thinner pins with the little hex heads and R clips We need a pic of your forks and calipers Steve
Post by midlifecrisisrd on Mar 29, 2023 19:03:45 GMT 1
Everything after the 83/84 bikes used the caliper with the single pad pin Steve Isn’t that the other way round, or am I missing the point? Jon Heads up my ass lol, too long in the car today, brain feels like fudge 😵💫 Steve
Post by wwwRD350LCnet on Mar 29, 2023 19:07:29 GMT 1
Here it is
Post by masonmart on Mar 29, 2023 19:43:11 GMT 1
My callipers have only one piston. Should an F1 have 2?
Post by abar121 on Mar 29, 2023 20:07:15 GMT 1
Yes.
As above sounds like you have the earlier forks and calipers.
Post by Gunny on Mar 29, 2023 20:11:44 GMT 1
Post by masonmart on Mar 29, 2023 20:17:52 GMT 1
So the question is. My parts book for an F1 57V shows a single piston and two pins and I have a single piston and single pin. Gunny's pics show 2 pistons and 2 pins. I'd love to know what I have and can I get some pins for it
Post by midlifecrisisrd on Mar 29, 2023 20:19:07 GMT 1
My callipers have only one piston. Should an F1 have 2? Should be opposing piston so yes 2 Does your front muddy have a U shaped bracket in it that bolts to the fork legs like a standard muddy or has it got a plate across the top that bolts to the fork legs like a brace Steve
Post by midlifecrisisrd on Mar 29, 2023 20:20:03 GMT 1
Norbo does the pins I'm sure for both types
Post by masonmart on Mar 29, 2023 20:21:53 GMT 1
My callipers have only one piston. Should an F1 have 2? Should be opposing piston so yes 2 Does your front muddy have a U shaped bracket in it that bolts to the fork legs like a standard muddy or has it got a plate across the top that bolts to the fork legs like a brace Steve Steve The mudguards and panels and all other painted bits are boxed up so I can't see now.
Post by midlifecrisisrd on Mar 29, 2023 20:21:57 GMT 1
Both types on his site Steve
Post by Gunny on Mar 29, 2023 20:28:51 GMT 1
Should be opposing piston so yes 2 Does your front muddy have a U shaped bracket in it that bolts to the fork legs like a standard muddy or has it got a plate across the top that bolts to the fork legs like a brace Steve Steve The mudguards and panels and all other painted bits are boxed up so I can't see now. Do you have a fork leg to hand ? The mudguard mounting for F1 should be boltholes facing up 2 each side, earlier 31k boltholes facing each other on the side
Post by dusty350 on Mar 29, 2023 20:33:04 GMT 1
Post by dusty350 on Mar 29, 2023 20:40:54 GMT 1
Post by Chewie01 on Mar 29, 2023 20:45:57 GMT 1
What's the callipers hole spacing between the 2 mounting bolts? The later one have a 83mm spacing.
Post by masonmart on Mar 29, 2023 20:53:37 GMT 1
Thanks guys, I believe that what I have is LC2 callipers. What is an LC2? I unpacked the callipers to get them coated but they are a disgusting mess. The forks are packed still, they look very good. I'll get the pins from Norbs. Need shoes too?
Post by abar121 on Mar 29, 2023 20:56:41 GMT 1
As far as I understand, an LC2 is the first two years of RD350 YPVS production for Europe, '83 and '84. Have a look under models, here: rd350lc.net/The N1/F1 came out in 1985 with quite a few changes. Are you sure the frame / engine you have are F1? If you are after originality, maybe post some more pictures on here of the other components, to be identified as F1 or not.
Post by midlifecrisisrd on Mar 29, 2023 21:33:29 GMT 1
F1 forks should also be black
31k prefix covers 4 models
83 was 1st lc2 and model code was 31k (250 was 29l)
84 was also lc2. Different paint and a few small changes
85 was F, full fairing, lots of changes including forks/brakes and was model 57v
85 also had the N, naked bike but other than paint was same as F1. Model code 1JF
Post by midlifecrisisrd on Mar 29, 2023 21:35:26 GMT 1
Should just to confuse, all 4 bikes vin number started 31k
Post by masonmart on Mar 29, 2023 21:51:37 GMT 1
As far as I understand, an LC2 is the first two years of RD350 YPVS production for Europe, '83 and '84. Have a look under models, here: rd350lc.net/The N1/F1 came out in 1985 with quite a few changes. Are you sure the frame / engine you have are F1? If you are after originality, maybe post some more pictures on here of the other components, to be identified as F1 or not. Abar, my frame number says its a 1985 Euro model F1. I'll be unpacking the bits more tomorrow so I can have a look at the forks, etc. These callipers and Master cylinder aren't F1. If I put non-standard parts on then I may as well put good quality, what fits the F1, did I see Triumph?
Post by Chewie01 on Mar 29, 2023 21:55:04 GMT 1
You can put Triumph callipers on, I have them on my F2 but you need to make sure your fork legs have the 83mm spacing for the calliper mounts.
Post by masonmart on Mar 29, 2023 22:06:34 GMT 1
You can put Triumph callipers on, I have them on my F2 but you need to make sure your fork legs have the 83mm spacing for the calliper mounts. Do you use a Triumph master cylinder too? Which Triumph model? Will measure the forks tomorrow
Post by Chewie01 on Mar 29, 2023 22:11:20 GMT 1
Post by Chewie01 on Mar 29, 2023 22:16:07 GMT 1
