Post by JonW on Nov 6, 2022 23:26:30 GMT 1
superb! Loving the pair together, ying and yang almost.
Post by steeley on Nov 7, 2022 8:12:16 GMT 1
Hi nice build . I noticed on your front brakes you have the brake hose going in the top with the bleed nipple at the bottom . I have the same brakes on my LC and have the feed on the bottom with the bleed in the top . All you need to do to get them bled up is to take them off and wedge the pads and bleed with nipple up . Its a bit of a faff but doable . They are good brakes .
Post by 17again on Nov 7, 2022 12:05:45 GMT 1
Hi nice build . I noticed on your front brakes you have the brake hose going in the top with the bleed nipple at the bottom . I have the same brakes on my LC and have the feed on the bottom with the bleed in the top . All you need to do to get them bled up is to take them off and wedge the pads and bleed with nipple up . Its a bit of a faff but doable . They are good brakes . that is what is did took them off much easier
Post by tout on Mar 21, 2023 21:24:31 GMT 1
real tasty job, classic and period. Top marks for the crossbow.
might be just the pics but your blue bike looks lower at the rear ? crossbow stance bang on. lovely job.
tbones
Post by tbones on Mar 30, 2023 20:56:00 GMT 1
got some more of the front end back together now including the calipers back on i do have a white mudguard being painted so they will properly be swapped over a bit later. not sure on these blue hoses and they might be a bit long whe the bike in back on its wheels
