Post by JonW on Aug 25, 2022 13:39:51 GMT 1
I wonder if when its done you can entice Gaynor to come and do another shoot with it? According to google shes only 42... i could try but wouldn't know how to found her and i am sure she would not forget a 350lc surely I bet shes still with an agency as she has/had a film career so probably still has management.
Post by 17again on Aug 25, 2022 18:59:00 GMT 1
i could try but wouldn't know how to found her and i am sure she would not forget a 350lc surely I bet shes still with an agency as she has/had a film career so probably still has management. i start looking but then i get lost when i start seeing photos
Post by donkeychomp on Aug 25, 2022 21:21:46 GMT 1
Curly Wurlys are the LC currency. You could try tempting her with a few of those...
Post by JonW on Aug 26, 2022 0:19:44 GMT 1
I think that might put her off if it was a phone call outa the blue lol
Post by 17again on Sept 4, 2022 15:31:38 GMT 1
fitted the ebay rad today which need to grinding to make fit still have to buy some new bolts for the grill cover
Post by 17again on Sept 4, 2022 15:34:09 GMT 1
also rebuilt the rear master and fitted with a spare hose i had left lying around as the new brembo has the banjo in a different place. do you think it looks ok? its a bit long.
Post by JonW on Sept 5, 2022 0:58:22 GMT 1
Hmm, I always worry that a hose that sticks out could catch on something, so to my eyes its not ideal.
Otherwise its coming along very nicely!
Post by dusty350 on Sept 5, 2022 7:52:13 GMT 1
It's looking lovely🙂
Dusty🙂
Post by 17again on Sept 10, 2022 16:41:56 GMT 1
header tank and HRC reservoir fitted
Post by 17again on Sept 10, 2022 17:14:32 GMT 1
started to put the front end together now ands i found that the headlight brackets were starting to go rusty where they are metal on metal. so i use a small rubber stripe whch you can see has puff up a little not sure if i am happy with that. vinyl on order thanks midlifecrisisrd
Post by dusty350 on Sept 10, 2022 19:28:49 GMT 1
Didn't realise the original header tank bracket was still on the frame, so that's a right result for re attaching the tank And I've had the same headlight brackets on different bikes in the past - they look upside down to me, but can obviously mount either way, so whatever floats yer boat ! Looking great. Dusty
Post by 17again on Sept 10, 2022 21:43:38 GMT 1
Didn't realise the original header tank bracket was still on the frame, so that's a right result for re attaching the tank And I've had the same headlight brackets on different bikes in the past - they look upside down to me, but can obviously mount either way, so whatever floats yer boat ! Looking great. Dusty that is how they were fitted but now you say it i can see it. i might ty them the other way around thanks
Post by sidney81 on Sept 11, 2022 7:21:01 GMT 1
Love the rad looks really cool 😎 as is the rest of the bike 👍
Post by dusty350 on Sept 11, 2022 7:49:09 GMT 1
The last bike I had recently that had those headlight brackets was my 430e. They were a very common aftermarket option back in the day, and virtually all the ones I used to see were mounted this way up; 20200816_092249 by dusty miller, on Flickr But, they were work equally as well either way and other components may mean having them bolted high to drop the headlight lower, hence "upside down". Very much a period aftermarket part, and still look good today Dusty
Post by 17again on Sept 11, 2022 8:31:27 GMT 1
The last bike I had recently that had those headlight brackets was my 430e. They were a very common aftermarket option back in the day, and virtually all the ones I used to see were mounted this way up; 20200816_092249 by dusty miller, on Flickr But, they were work equally as well either way and other components may mean having them bolted high to drop the headlight lower, hence "upside down". Very much a period aftermarket part, and still look good today Dusty nice bike dusty, yes i looked back through my post where i seen hasters black lc and they are the same way as yours.
Post by headcoats on Sept 11, 2022 8:49:00 GMT 1
Headlight brackets pointed to the stars is not big or clever !
Post by yamark on Sept 11, 2022 16:51:29 GMT 1
started to put the front end together now ands i found that the headlight brackets were starting to go rusty where they are metal on metal. so i use a small rubber stripe whch you can see has puff up a little not sure if i am happy with that. vinyl on order thanks midlifecrisisrd Beautiful build, the blue and polished parts look so right. As for the rubber, would it be possible to cut 2 parallel smaller strips, so all the rubber is hidden? Great work, following with interest, cheers, Mark
Post by 17again on Sept 11, 2022 18:00:14 GMT 1
started to put the front end together now ands i found that the headlight brackets were starting to go rusty where they are metal on metal. so i use a small rubber stripe whch you can see has puff up a little not sure if i am happy with that. vinyl on order thanks midlifecrisisrd Beautiful build, the blue and polished parts look so right. As for the rubber, would it be possible to cut 2 parallel smaller strips, so all the rubber is hidden? Great work, following with interest, cheers, Mark could be a good idea i might pen around the middle and cut them out. worth a try.
Post by 17again on Sept 25, 2022 15:25:55 GMT 1
got some more of the front end back together now including the calipers back on i do have a white mudguard being painted so they will properly be swapped over a bit later. not sure on these blue hoses and they might be a bit long whe the bike in back on its wheels
Post by dusty350 on Sept 25, 2022 20:58:03 GMT 1
Looking really lovely Max Posted your carb parts on Friday - should see them early this week Dusty
Post by 17again on Sept 29, 2022 17:31:38 GMT 1
microns now fitted
Post by dusty350 on Sept 29, 2022 18:54:06 GMT 1
Looking fantastic Max Those old bean can Microns are, I think, the best sounding pipes ever for an Lc Dusty
Post by 17again on Sept 29, 2022 19:13:26 GMT 1
Looking fantastic Max Those old bean can Microns are, I think, the best sounding pipes ever for an Lc Dusty thanks duty almost there now. i have been positive with covid so had plenty of full days in the garage this week. i had it running now too. i took the baffles out today as i was convince from the sound of them they were empty. nope they were full.
Post by stusco on Sept 29, 2022 20:02:13 GMT 1
Any chance of a vid of it running 😁
Post by 17again on Sept 30, 2022 7:51:45 GMT 1
Any chance of a vid of it running 😁 i will try an do one yes
Post by 17again on Oct 1, 2022 15:27:35 GMT 1
Post by 17again on Oct 1, 2022 15:31:43 GMT 1
couple of videos here
Post by 17again on Nov 6, 2022 17:06:05 GMT 1
Post by arrdy350 on Nov 6, 2022 18:20:30 GMT 1
That looks very nice sounds great too with the Microns 🙂😎👍
Post by dusty350 on Nov 6, 2022 18:42:00 GMT 1
Agree, you've made a lovely job of the rebuild Dusty
