Post by ringding on Dec 2, 2018 21:03:34 GMT 1
Very close to having finished the wiring on the 4L1. But not sure if something is supposed to be mounted on the spur that is under the coils (you can just see it between them in this picture). Any clues? Thanks.
Post by LC_BOTT on Dec 2, 2018 22:33:25 GMT 1
Indicator self cancelling unit.
Post by LC_BOTT on Dec 2, 2018 22:34:23 GMT 1
Indicator self cancelling unit. Small solid encapsulated block with a big rubber band round the outside.
Post by ringding on Dec 3, 2018 7:50:13 GMT 1
Aha, I think I've mounted that vertically behind the headstock, thanks.
Post by JonW on Dec 6, 2018 3:06:18 GMT 1
Is this true on an OEM bike? Indicator self cancelling unit. Small solid encapsulated block with a big rubber band round the outside. I ask as Ive aways done this: Aha, I think I've mounted that vertically behind the headstock, thanks. I thought this tab was some thing for another market.
Post by LC_BOTT on Dec 6, 2018 8:19:14 GMT 1
Aha, I think I've mounted that vertically behind the headstock, thanks. Yes I think you're both right, just read this thread, which also has help with some of the wiring problems people have. (Must have a look at mine now, see where it's fitted ) rdlccrazy.proboards.com/thread/45196/flasher-relay-4l0
