peacey
Post by peacey on Aug 31, 2018 12:53:57 GMT 1
Does anyone know what the black wired bullet connectors for on the 4L0 loom flasher relay connector?
Post by mattybeckett on Aug 31, 2018 13:09:22 GMT 1
Does anyone know what the black wired bullet connectors for on the 4L0 loom flasher relay connector? Something to do with the self cancelling indicators depending which relay you have fitted.
Post by earthman on Aug 31, 2018 14:17:31 GMT 1
Does anyone know what the black wired bullet connectors for on the 4L0 loom flasher relay connector? Something to do with the self cancelling indicators depending which relay you have fitted. I take it that one relay is different in the amount of pins it has??
Post by mattybeckett on Aug 31, 2018 16:56:48 GMT 1
Something to do with the self cancelling indicators depending which relay you have fitted. I take it that one relay is different in the amount of pins it has?? No . You swap one of the wires over into the black if using self cancelling relay.
Post by oldelsieboy on Aug 31, 2018 17:18:52 GMT 1
Does anyone know what the black wired bullet connectors for on the 4L0 loom flasher relay connector? Connecting the "spare" black to the the yellow/black on the relay plug bypasses the self cancel indicator circuit. For the self cancel to work the yellow/black at the plug must be connected to the yellow/green on the loom, a 3 pin relay must be fitted, with the pins oriented correctly, an indicator cancel relay fitted to the loom behind the headstock & a working reed switch fitted to the speedo head. HTH
OEB
Post by earthman on Aug 31, 2018 17:42:31 GMT 1
Does anyone know what the black wired bullet connectors for on the 4L0 loom flasher relay connector? Connecting the "spare" black to the the yellow/black on the relay plug bypasses the self cancel indicator circuit. For the self cancel to work the yellow/black at the plug must be connected to the yellow/green on the loom, a 3 pin relay must be fitted, with the pins oriented correctly & a working reed switch fitted to the speedo head.
HTH
OEB Thanks for the info, I know that my German bike doesn't have the little box of tricks up near the headstock, that is part of the self cancel system too, I believe.
Post by oldelsieboy on Aug 31, 2018 17:46:04 GMT 1
Connecting the "spare" black to the the yellow/black on the relay plug bypasses the self cancel indicator circuit. For the self cancel to work the yellow/black at the plug must be connected to the yellow/green on the loom, a 3 pin relay must be fitted, with the pins oriented correctly & a working reed switch fitted to the speedo head. HTH
OEB Thanks for the info, I know that my German bike doesn't have the little box of tricks up near the headstock, that is part of the self cancel system too, I believe. It is, I will edit my previous post to include it. OEB
peacey
Post by peacey on Aug 31, 2018 23:19:24 GMT 1
Thanks for the help guys
