Post by stusco on Jul 1, 2018 19:59:41 GMT 1
Post by oldelsieboy on Jul 1, 2018 20:06:24 GMT 1
Just remembered to post a pic of my re riveted clutch basket
Post by stusco on Jul 1, 2018 20:29:06 GMT 1
As you can see I still can’t work the pictures
Post by 17again on Jul 1, 2018 20:32:46 GMT 1
was it a need basket fitted?
my clutch rattles a bit
Post by stusco on Jul 1, 2018 21:10:35 GMT 1
Just replacing the wonky clutch dampers
Post by 17again on Jul 1, 2018 22:05:58 GMT 1
Does this make the clutch rattle when they are worn as my basket is not worn where the plates go.
Post by markhoopy on Jul 1, 2018 22:58:12 GMT 1
Does this make the clutch rattle when they are worn as my basket is not worn where the plates go. If you hold the back of the clutch in one hand - the one with the drive gear - then hold the front part with the 'tangs' with your other hand and try twisting them can you see or feel any movement between the two? There are four rubber dampers between the two parts of the clutch drum that can wear over time, and to replace them you drill out the four rivets holding the two halves together. Stusco posted a question about the rivets here: rdlccrazy.proboards.com/thread/44513/clutch-dampers
Post by 17again on Jul 2, 2018 17:36:03 GMT 1
thanks mark
Post by bare on Jul 2, 2018 17:48:28 GMT 1
Yama designed the Main gear and clutch to have 4 to 6mm of rotational play. Yama San fitted two sizes of Rubber bungs to achieve this play. Yes they can (rarely tho) deteriorate. In which case the play is excessive. Measure it..First. Replacement /aftermarket bungs are Nowhere near as durable as the oems though.. Caveat Emptor. That said: Seriously unlikely the bike will be around another 30 years ..either :-) Main brass bushing is often the rattly clutch Noise source... Check it
Post by jon on Jul 2, 2018 20:11:44 GMT 1
Yama designed the Main gear and clutch to have 4 to 6mm of rotational play. Yama San fitted two sizes of Rubber bungs to achieve this play. Yes they can (rarely tho) deteriorate. In which case the play is excessive. Measure it..First. Replacement /aftermarket bungs are Nowhere near as durable as the oems though.. Caveat Emptor. That said: Seriously unlikely the bike will be around another 30 years ..either :-) Main brass bushing is often the rattly clutch Noise source... Check it Bare, I’ve seen that the original rubbers were 2 different sizes. Didn’t take a photo though so can’t remeber if the larger ones are the drive side? Can you remember? Jon
Post by stusco on Jul 2, 2018 20:32:10 GMT 1
Post by reggieperrin on Jul 2, 2018 21:36:17 GMT 1
I have to go through the same process in the next few weeks but to replace a damaged basket, not because of wear... One of the engines I am about to use arrived with two of the 'tangs' missing..... God knows what force they used and in what direction to break them..!!
Post by dusty350 on Jul 2, 2018 21:55:11 GMT 1
Post by arrow on Jul 2, 2018 22:07:27 GMT 1
I have to go through the same process in the next few weeks but to replace a damaged basket, not because of wear... One of the engines I am about to use arrived with two of the 'tangs' missing..... God knows what force they used and in what direction to break them..!! I broke a tang off my clutch basket, it fell off the bench!
Post by jon on Jul 3, 2018 6:37:00 GMT 1
I have to go through the same process in the next few weeks but to replace a damaged basket, not because of wear... One of the engines I am about to use arrived with two of the 'tangs' missing..... God knows what force they used and in what direction to break them..!! People botching holding it to do the centre nut up perhaps? Jon
